A Lenz2 Vertical Axis Wind Turbine
Quentin_Plsn
Post by Quentin_Plsn »
Hello everyone,
Here is a Lenz2 wind turbine that I modelled only with Sketcher, Part Design and A2plus. With FreeCAD 0.19 on Debian 11. At first, I started from a DIY tutorial to make a first version by reverse engineering, then I upgrade my wind turbine to obtain this result.
It's not meant to be manufactured, it was just for fun and learning, but I published the 3D model on GrabCAD and someone used it in a 1/35 scale zombie/apocalypse diorama.
Capture d’écran de 2022-10-06 15-48-02.png (209.35 KiB) Viewed 1891 times
HoWil
Re: A Lenz2 Vertical Axis Wind Turbine
Post by HoWil »
Very nice.... especially the DIY tutorial =)
