Optics in FreeCAD
thschrader
Re: Optics in FreeCAD
Post by thschrader »
something to play with...
http://satu0king.github.io/LightXlab/simulator/
https://www.youtube.com/watch?v=AxHcLncRkbM
marcin_ose
Post by marcin_ose »
Excellent work. With some headscratching, we may soon be able to figure out how to couple cheapo 500W laser diode stacks to fibers for building laser cutters for metal. 500W laser Diodes are available for around $1000 like https://www.alibaba.com/product-detail/ ... 61539dmDmO. And this guy talks about how to simulate the raytracing - https://www.aphys.kth.se/polopoly_fs/1. ... s_2009.pdf . It is great that FreeCAD can be extended to just about anything.
Founder, Open Source Ecology
http://opensourceecology.org/
DeepSOIC
Post by DeepSOIC »
It's always fun to re-read old discussions :P
Kunda1 wrote: Fri Jan 12, 2018 8:28 pm
ian.rees wrote: Fri Mar 17, 2017 4:42 am Bonus points for hooking this up with FEM and melting something with focused light ;). -Ian-
This sounds awesome.. can this seriously be done?
I recently found out, there is a program called "Comsol". It cost some serious $$$$$, but apparently it can do pretty much anything physics-related, mechanics, cfd, electrodynamics, acoustics, plasma physics, semiconductors, ..., and custom equations. And allows to tie all these disciplines into one problem. I'm slowly looking into attending a course, it looks like it can elevate engineering caps to a whole new level.
thschrader
DeepSOIC wrote: Tue Dec 11, 2018 1:25 pm It's always fun to re-read old discussions :P
It cost some serious $$$$$....
Yep.
1x basic module + 40 addons ==> 34000 USD
In germany, a nurse must work 2 years for that... ;)
pricelist:
http://collaborate.bu.edu/engit/Comsol? ... celist.pdf
The linked pricelist is the Educational Discount Plan. I wonder what FreeCAD charges from universities :mrgreen: .
saso
Post by saso »
Just a few videos from an commercial optical design package... Putting everything together what has been shown and discussed in this topic does show some good potential
https://www.youtube.com/watch?v=fwTl236-CYM
https://www.youtube.com/watch?v=qeHdZlcwof8
https://www.youtube.com/watch?v=DJQADlaJvPc
https://www.youtube.com/watch?v=7SIXXMCZ5kA
https://www.youtube.com/watch?v=YtzhNVgeU1I
https://www.youtube.com/watch?v=ScsAYxixy98
christi
Post by christi »
I have started to create a workbench for optics:
https://github.com/chbergmann/OpticsWorkbench
Work is still in progess, but you can already draw some sketches and use it as optical mirrors
spanner888
Post by spanner888 »
christi wrote: Sat Jul 03, 2021 7:39 pm Work is still in progess, but you can already draw some sketches and use it as optical mirrors
Looks especially nice for simpler use cases than many optics tools I have looked at...and not used.
However in my own dumb user klutz fashion, I have not quite understood how to define the elements. It would be very usefull if you could share the FreeCAD model of your example, so I can get past whatever sillyness I have done to cause below (just two sketches, each with one line, and one sketch made into a mirror, then adding a Ray gives below)
08:06:28  Illegal storage access...
08:06:28  Traceback (most recent call last):
  File "C:\Users\spanner888\AppData\Roaming\FreeCAD\Mod\OpticsWorkbench\Ray.py", line 40, in execute
    self.redrawRay(fp)
  File "C:\Users\spanner888\AppData\Roaming\FreeCAD\Mod\OpticsWorkbench\Ray.py", line 64, in redrawRay
    self.traceRay(fp, pos, linearray)
  File "C:\Users\spanner888\AppData\Roaming\FreeCAD\Mod\OpticsWorkbench\Ray.py", line 95, in traceRay
    isec = line.Curve.intersectCC(edge.Curve)
<class 'RuntimeError'>: Illegal storage access! Please save your work under a new file name and restart the application!
If I select the second sketch, then the mirror and try to create a ray, then get the same error again.
Then I tried making another sketch with a rectangle and made that an absorber, but still get above error trying to add a Ray, so your example file would help me work out how to correctly use your addon.
johnwang
Post by johnwang »
Has anyone play with this KDP-2 from http://ecalculations.com/ An old Fortran design program
And there is a Koko which is based on KDP-2, its longer-term plan is to integrate with FreeCAD
https://github.com/dinosauria123/Koko
christi
Post by christi »
I have created a new discussion thread in the Open Discussion section:
https://forum.freecadweb.org/viewtopic.php?f=8&t=59860
I will answer your posts there.
