Tour camera animation
JMG
Postby JMG » Fri Nov 14, 2014 11:20 pm
Hi everyone!
I want to share with you a new animation, but this time, what is moving is you!
Little video: Tour Camera
Quick start guide:
Download the model here
Open it, switch to "Perspective View", toggle the visibility of one of the sketches called "track..", select one line of the sketch and paste this code:
from pivy import coin
import time
from FreeCAD import Base
cam = FreeCADGui.ActiveDocument.ActiveView.getCameraNode()
trajectory = Gui.Selection.getSelectionEx()[0].Object.Shape.Edges
for edge in trajectory:
  startPoint = edge.valueAt( 0.0 )
  endPoint = edge.valueAt( edge.Length )
  dirVector = ( endPoint - startPoint ).normalize()
  currentPoint = startPoint
  while (currentPoint - startPoint).Length < edge.Length:
    currentPoint = currentPoint + dirVector
    cam.position.setValue(currentPoint + Base.Vector( 0,0, 10) )
    cam.pointAt( coin.SbVec3f( endPoint[0], endPoint[1], endPoint[2]+10) , coin.SbVec3f( 0, 0, 1 ) )
    Gui.updateGui()
    time.sleep(0.005)
More info and improved version in my blog.
P.D.: I've already posted this at the FreeCAD google+ page, but I don't know up to which point is connected with the forum, if this feels like spam, please tell me and I will post only here or there ;)
FreeCAD scripts, animations, experiments and more: http://linuxforanengineer.blogspot.com.es/
Open source CNC hot wire cutter project (NiCr): https://github.com/JMG1/NiCr
Exploded Assembly Workbench: https://github.com/JMG1/ExplodedAssembly
danielfalck
Re: Tour camera animation
Postby danielfalck » Sat Nov 15, 2014 3:46 pm
Please post your FreeCAD adventures in both places, but post here first :)
You are doing some very interesting things.
jmaustpc
Postby jmaustpc » Sat Nov 15, 2014 4:07 pm
yes, I also think you should post in both if you want to, as a lot of people will not look at both location. :)
sgrogan
Postby sgrogan » Sat Nov 15, 2014 4:10 pm
@JMG
Way Cool!
Please keep posting here!
JMG
Postby JMG » Sat Nov 15, 2014 5:17 pm
Thanks for your replies, I was a bit concerned about that ;)
I'll keep both places up to date :D
About the tour camera, I have improved it: now it works over tracks built up from several sketches and moves smoothly.
I created a mini tutorial too.
NormandC
Postby NormandC » Sat Nov 15, 2014 5:30 pm
JMG wrote:if this feels like spam
How can anything related to FreeCAD feel as spam? :D
jmaustpc
Postby jmaustpc » Sun Nov 16, 2014 3:56 am
OH, actually quite easily Norm...like this :D
spamcan.fcstd
(924.21 KiB) Downloaded 76 times
which looks like this
Jim
clintonsam75
Postby clintonsam75 » Mon Nov 17, 2014 7:27 am
That's very clever. I think this is the first time I've seen the camera move instead of an object on a YouTube video concerning FreeCAD.
microelly2
Postby microelly2 » Mon Nov 17, 2014 8:28 am
I have seen the animation of JMG already last week and placed the idea into my workbench.
http://youtu.be/GzNVr-lprMo
Next step will be to use perspective camera and create 3D
microelly2
Postby microelly2 » Mon Nov 17, 2014 6:28 pm
Todays result with the moving camera
http://youtu.be/pigAHmIVKr8
The base for the camera path is the blue DWire which is 100 above the earth
The camera directs to the gray cylinder (0,0,0).
The red path is the way of the camera in height 1000
The Foot point of the camera is simulated by the blue cube.
The camera is still orthogonal.
The red cube rotates with center (20, -100, 0)
The green square rotates arount the origin (0, 0, 0)
Render time was 100 sec for 1000 frames.
