Thanks Microelly2.microelly2 wrote: ↑Sat Mar 24, 2018 7:38 pmPlacer can now have a group as target or can be the group of parts itself.
https://github.com/microelly2/Animation ... f75de2bb73
I cannot make it work properly. I have tried to use both approaches with the same result.
I am trying to make an group of objects rotate about an axis, where the objects are not located at the same placement and none of them is at the origin (0,0,0).
Using a rotator I can move a single object by using the "rot center relative" to true.
When I use a placer, the relative placement of the different objects in a group changes when the animation is run:
It is like if all objects in the group would move its origin to the same location x0,y0,z0.
I simply do not know how to fill in the placer so as to achieve what I want. This is done with two rotators, and only one gear of the full center body rotates. It also rotates at 1:1 speed gear-pinion, which is wrong as the ratio is 1:2.5, so the big gear should be 0.4 of the rotation speed of the small gear.
Do you know what I am doing wrong?
