Exploded assembly animation
JMG
Re: Exploded assembly animation
Postby JMG » Tue Jul 14, 2015 8:26 am
Remove the exploded animation workbench you have and download it from this repository (I have fixed the bug that timthelion (thanks) said):
https://github.com/JMG1/FreeCAD_Explode ... nWorkbench
I have written instructions there ;)
Your file with some animation:
Explusionszeichnung V10 test explusion.FCStd
(389.09 KiB) Downloaded 141 times
Hope it helps :)
FreeCAD scripts, animations, experiments and more: http://linuxforanengineer.blogspot.com.es/
Open source CNC hot wire cutter project (NiCr): https://github.com/JMG1/NiCr
Exploded Assembly Workbench: https://github.com/JMG1/ExplodedAssembly
JMG
Postby JMG » Mon Mar 14, 2016 11:08 am
Hi all!
I have published the second version of the exploded assembly animation workbench, you can download it here:
Shocase video: https://www.youtube.com/watch?v=lzYR7I2h7KQ
Javier.
triplus
Postby triplus » Tue Mar 15, 2016 9:53 am
For now i have only looked at the video and it looks really good.
P.S. Will test the workbench when i find the time.
emills2
Postby emills2 » Wed Mar 16, 2016 7:08 am
the functionality in the video looks amazing :)
paul18
Postby paul18 » Wed Mar 16, 2016 7:43 am
Hi JMG
Amazing module and quite intuitive; I've tested it in a sub-assembly (modelled by Assembly2 module) and it's a "maravillosa" :D
Of course I've to go deeper and to find a way to generate videos for example, but I think it's becoming one of my favorite modules.
Thanks for your work ... and congretulation for it
Paul
triplus
Postby triplus » Wed Mar 16, 2016 9:26 am
I did a few tests today and i get good results when using Fasteners WB and after animate the elements by adding BoltGroups for animation purposes.
After i tried to test point to point animation tool. I select 2 corner points of different cubes and press on the point to point tool. The cubes moved together. If i want to animate them after i get this:
ExplodedAssembly-master/EAInit.py", line 335, in Activated
    v = PB.Point - PA.Point
'Part.Edge' object has no attribute 'Point'
I am guessing i am doing something wrong when selecting the points?
JMG
Postby JMG » Wed Mar 16, 2016 9:52 am
Thanks you for your feedback :)
@triplus
The objective of the 'point to point' tool is to help to place together the parts before starting to explode them, but your idea of creating trajectories from point to point is interesting. I'll think about it :)
Javier.
triplus
Postby triplus » Wed Mar 16, 2016 10:17 am
I see your module has "mini assembly" capability as well. ;) Good to know that. I will go over the video and tools again probably over the weekend and test the module more in depth.
P.S. If you would provide an option to do a (by using a built in support for POV-Ray) render at each step that would be cool!
microelly2
Postby microelly2 » Wed Mar 16, 2016 10:33 am
triplus wrote:P.S. If you would provide an option to do a (by using a built in support for POV-Ray) render at each step that would be cool!
+1
paul18
Postby paul18 » Wed Mar 16, 2016 12:56 pm
Just an idea: I've been thinking it might be interesting to model directly the trajectory under FreeCAD (typically lines or curves in the draft workbench for example); then an option allows-us to click on and to chose it instead of a pre-selected one.
