Hello,
I fixed, the Sketcher::SketchObjectPython :
-The functions of Sketcher::SketchObject were not accessible when creating and using a SketchObjectPython
-When creating a SketchObjectPython, the C++ execute() function is not called but the new execute function from the python code. This is a problem because the shape of the sketch was never computed. For this i created a function recomputeShape(), which is called by the c++ execute() and can be also called by python (so we can call it in the python execute() function).
I am really not sure it was the way to go, please tell me if you want it in an other way.
Here is the commit :
https://github.com/guilhemdesq/FreeCAD_ ... 8ea5f6db3b
Fixed SketchObjectPython
Re: Fixed SketchObjectPython
There is now a more general way to do this.
class SketcherClass:
def __init__(self, obj):
obj.Proxy = self
def execute(self, fp):
fp.recompute() # when used inside the execute() method of a custom feature class it invokes the method of the C++ base class
s=App.ActiveDocument.addObject("Sketcher::SketchObjectPython")
sketcher=SketcherClass(s)
s.ViewObject.Proxy=0
Hi, thanks for this feature, I am learning to use it for a while and always note there was examples with slightly different code.
I find the Sketch Python Feature object sometime fails to update recently - unknown to me is whether I have the code wrong or the difference in AppImage I download from time to time, or between Windows and Fedora Linux I work on at different time...
Before I could more systematically track down when it works or fails, some general explanation of the code / difference is appreciated:-
Version: 0.17.13483 (Git)
Build type: None
Hash: 0ac32464e45fa9648cdaf702ebda06650dabe9dc
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 7.1.0
Locale: English/HongKong (en_HK)
- In the execute() method, once there was 'return false', then later it was 'fp.recompute()'
- It seems 'fp.recompute()' works right? I have no idea what they means in fact.
- Running in AppImag version shown below, both 'fp.recompute()' in 'return false' are commented out in execute() method, it seem still works in Fedora Linux ?????? (But I remember this does not works in Window 7 machine with something like FreeCAD_0.17.13387_x86_dev_win.7z)
- Copying from somewhere else I forgot, there was 'return none' in __init__(), is it correct?
- Anywhere more document I can study on?
wmayer wrote: ↑Sat Nov 19, 2016 3:27 pm There is now a more general way to do this.Code: Select all
class SketcherClass: def __init__(self, obj): obj.Proxy = self def execute(self, fp): fp.recompute() # when used inside the execute() method of a custom feature class it invokes the method of the C++ base class s=App.ActiveDocument.addObject("Sketcher::SketchObjectPython") sketcher=SketcherClass(s) s.ViewObject.Proxy=0
OS: Linuxwmayer wrote: ↑Tue Oct 20, 2015 10:47 pm With git commit e7a3dc48e834591e5553 sketcher can now be used in Python as custom feature.
So, from now on a Python feature doesn't need to have an execute() method any more. If it's not there then the execute() method of the related C++ class is called instead.
If your Python feature must have an execute() method but you also want to call the execute() of the C++ class you must return "False".
Examples:Code: Select all
class SketchFeature: def __init__(self, obj): obj.Proxy = self def execute(self, obj): return False SketchFeature(App.ActiveDocument.addObject("Sketcher::SketchObjectPython")) App.ActiveDocument.ActiveObject.ViewObject.Proxy=1
Build type: None
Qt version: 4.8.6
OCC version: 7.1.0
Hi, tested both in a Fedora Linux and Win 7...
Found it need 'fp.recompute()' in excute() for Win 7 to work.
Though not need 'fp.recompute() to work in Fedora Linux.
So, add 'fp.compute()' anyway.
FreeCAD_0.17.12813_x86_dev_win.7z
FreeCAD_0.17.13483.glibc2.17-x86_64.AppImage
class SketchFeature():
self.Type = "SketchFeature"
obj.addProperty("App::PropertyLink","Test1","Test2","Test3")
obj.Proxy = self
obj.ViewObject.Proxy=0 #Not tested obj.ViewObject.Proxy=0 or 1 matters/means?
return None
#fp.recompute commented out NOT WORKING in Win7
#fp.recompute commented out or not both WORKS IN Linux Fedora
fp.recompute() # inside execute() method of custom feature class - invokes method of C++ base class
#return False # this is the line quoted in FC discussion earlier than above line
def onDocumentRestored(self, fp):
return None
