PR #1469 Qt5 compatible NaviCube
nyholku
Postby nyholku » Thu May 24, 2018 7:00 pm
I finally rebased my branch and created a pull request.
wbr Kusti
pablogil
Re: PR #1469 Qt5 compatible NaviCube
Postby pablogil » Fri May 25, 2018 7:40 am
I can't wait to see it merged and try it out
:D
dulouie
Postby dulouie » Fri May 25, 2018 8:45 am
Yes, this nice cube is waiting in the queue for too long.
Postby wmayer » Sat May 26, 2018 1:53 pm
Your Qt5 port of NaviCube didn't compile on any platform and due to exclusive use of QOpenGLTexture of course didn't work for Qt4 either. Thus, I switched back to your original implementation based on GLuint and did the Qt5 port myself.
Also, I added the option to switch it off and fixed several issues like slow rendering due to creation of an image which is never used, several memory leaks and possible crashes if the GL context gets destroyed.
nyholku
Postby nyholku » Sat May 26, 2018 5:14 pm
Brilliant! Thank you very much.
easyw-fc
Postby easyw-fc » Tue May 29, 2018 7:58 am
would it be possible to trig 'Zoom to fit' when clicking on a view already selected?
i.e. I click on 'Top' and the activeView is already the Top View, then 'Zoom to fit' is triggered.
Postby NormandC » Tue May 29, 2018 5:00 pm
Do you mean that it works on Qt4?
EDIT: sorry, should have checked commits before asking!
git commit ddf881a1
Thanks!!! :D
Time to fire up the freecad-daily version! :)
triplus
Postby triplus » Sat Jun 02, 2018 11:42 am
Congratulations!
efyx
Postby efyx » Wed Jul 04, 2018 7:19 am
Is it possible to provide some improvements like:
- ability to change display mode: shaded view/wire view etc.. It could remove view panel completely
- rotate to normal view, it means when you have sketch plane active, when you rotate model you can by pressing this button back it to normal view
- stretch rotation arrows (top/botto/left/right) to easier aim. Sometimes it is hard to rotate by these arrows and I don't know why, maybe coordinate system symbol of cube do this
Postby NormandC » Sun Oct 07, 2018 7:32 pm
When switching FreeCAD's language from the system locale (in my case French) to English, the NaviCube automatically switches position to Top Left. This is pretty annoying. Because of my work on the wiki, I am constantly switching between English, French and sometimes other languages.
Do I need to create a bug report?
Thanks.
P.S. There was a similar issue with TechDraw preferences sometime ago, where a change of language would affect TechDraw preferences. I wonder if it's a similar issue.
https://forum.freecadweb.org/viewtopic.php?f=35&t=27383
wmayer wrote:
Sat Mar 10, 2018 9:04 pm
The point is that when changing the language a preference page receives an event and to call a function translateUi. This function is generated by Qt's uic compiler and always clears combo boxes. So, developers must take special care about this behaviour and explicitly save & restore the current index.
wandererfan wrote:
Mon Mar 12, 2018 12:01 pm
The problem may occur with other preference pages - I've seen a few without save/restore around the retranslate(), but I've never inspected them to see if the page has comboBoxes.
Shouldn't saveSettings(); and loadSettings(); calls be added to https://github.com/FreeCAD/FreeCAD/blob ... iewImp.cpp?
