The following changes since commit f068e723eaf9ab9588a0196efbd25c0dbdd636c9:
Remember last tab selected in PropertyView (2015-04-15 09:12:30 +1200)
are available in the git repository at:
https://github.com/PrzemoF/FreeCAD_sf_master.git fem_v6
for you to fetch changes up to ea5c01f7e14e5d5460bba2ba390f029a75bb6d7f:
FEM: Fix typo in fem_console_message name (2015-04-15 15:39:23 +0100)
Przemo Firszt (14):
FEM: Sort materials within each category
FEM: Change way of converting ccx output to unicode
FEM: Catch ccx errors and print to FEM console in red
FEM: Use default True value for material dirs
FEM: Use built-in None material if there was no previous material
FEM: Rename chooseMat to choose_material
FEM: Group all helper functions together
FEM: Fix typos
FEM: Make sure cursor gets restored if write_calculix_input_file fails
FEM: Disable "open editor" and "run ccx" buttons.
FEM: No need to check length, empty list evaluates to False
FEM: Fix typo. Rename MathObject to MaterialObject
FEM: Fix rare crash related to the date of compilation of ccx
src/Mod/Fem/MechanicalAnalysis.py | 129 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++---------------------------------------------
src/Mod/Fem/MechanicalAnalysis.ui | 6 +++++
src/Mod/Fem/MechanicalMaterial.py | 81 +++++++++++++++++++++++++++++++++++++-------------------------------
3 files changed, 125 insertions(+), 91 deletions(-)
FEM: different fixes
Re: FEM: different fixes
The encode and decode methods have the ability to ignore errors or to replace offending characters.
https://docs.python.org/2/library/codec ... se-classes
IMHO for log messages errors='replace' makes more sense then the default errors='strict' combined with handling the exception.
Because in your current solution the whole message gets lost (and replaced).
just tested, looks good to me on debian jessie.
Saw in CalculiX manual the maximum lenght for material name is 80 charakters http://web.mit.edu/calculix_v2.7/Calcul ... de216.html
Should we check this too?
Merged.
