Improved handling of document's license
Merged, abandoned or rejected pull requests are moved here to clear the main Pull Requests forum.
f3nix
Postby f3nix » Sun Sep 06, 2015 4:56 pm
this is a small improvement of document's license handling.
* One can edit the "Other" license URL.
* The document does not get the "All rights reserved" licence by default.
The following changes since commit de442b18539a4af57ca9e5a7f797bb0311c9c3ce:
Improved handling of document's license. (2015-09-06 18:45:24 +0200)
are available in the git repository at:
git://github.com/f3nix/FreeCAD
for you to fetch changes up to de442b18539a4af57ca9e5a7f797bb0311c9c3ce:
Cheers,
Mateusz
yorik
Site Admin
Re: Improved handling of document's license
Postby yorik » Mon Sep 07, 2015 6:40 pm
There is something in your commit, I don't know what, that makes it very difficult to know what has changed becuase all the file content is marked as changed:
https://github.com/f3nix/FreeCAD/commit ... 0311c9c3ce
Besides, the "All rights reserved" license by default is on purpose: If the user doesn't do anything to specify a "cooler" license, he remains in possession of all his rights. Forcing anything else on the user without him explicitely choosing it would be wrong.
DeepSOIC
Postby DeepSOIC » Mon Sep 07, 2015 7:07 pm
shoogen taught me that adding ?w=1 to address bar in github will hide whitespace differences, which helps a lot in this case:
https://github.com/f3nix/FreeCAD/commit ... c9c3ce?w=1
I wonder what has actually happened... maybe line endings were changed?
f3nix
Postby f3nix » Mon Sep 07, 2015 7:16 pm
sorry about that. The file was encoded in ISO 8859-2 and my IDE complained about it. So I clicked update to UTF-8. I have not noticed that the diff looks so strange. Too little coffee I guess. ;)
Cheers,
Mateusz
f3nix
Postby f3nix » Mon Sep 07, 2015 7:27 pm
I miswrote the description of the second change. If You choose "Other license" as default and do not enter the URL the default URL won't be "All rights reserved".
Cheers,
Mateusz
Here is the diff:
diff --git a/src/App/Document.cpp b/src/App/Document.cpp
index a146f99..2711d12 100644
--- a/src/App/Document.cpp
+++ b/src/App/Document.cpp
@@ -1,5 +1,5 @@
- *   Copyright (c) J<FC>rgen Riegel          (juergen.riegel@web.de) 2002     *
+ *   Copyright (c) Jürgen Riegel          (juergen.riegel@web.de) 2002     *
  *   This file is part of the FreeCAD CAx development system.              *
@@ -668,7 +668,7 @@ Document::Document(void)
             license = "Other";
     std::string licenseUrl = App::GetApplication().GetParameterGroupByPath
-        ("User parameter:BaseApp/Preferences/Document")->GetASCII("prefLicenseUrl","http://en.wikipedia.org/wiki/All_rights_reserved");
+        ("User parameter:BaseApp/Preferences/Document")->GetASCII("prefLicenseUrl","");
     ADD_PROPERTY_TYPE(License,(license.c_str()),0,Prop_None,"License string of the Item");
     ADD_PROPERTY_TYPE(LicenseURL,(licenseUrl.c_str()),0,Prop_None,"URL to the license text/contract");
diff --git a/src/Gui/DlgSettingsDocumentImp.cpp b/src/Gui/DlgSettingsDocumentImp.cpp
index f2fb904..f2a3806 100644
--- a/src/Gui/DlgSettingsDocumentImp.cpp
+++ b/src/Gui/DlgSettingsDocumentImp.cpp
@@ -1,5 +1,5 @@
- *   Copyright (c) 2002 J<FC>rgen Riegel <juergen.riegel@web.de>              *
+ *   Copyright (c) 2002 Jürgen Riegel <juergen.riegel@web.de>              *
@@ -128,6 +128,8 @@ void DlgSettingsDocumentImp::changeEvent(QEvent *e)
 void DlgSettingsDocumentImp::onLicenseTypeChanged(int index)
+    prefLicenseUrl->setReadOnly(true);
     switch (index) {
         case 0:
             prefLicenseUrl->setText(QString::fromAscii("http://en.wikipedia.org/wiki/All_rights_reserved"));
@@ -158,6 +160,7 @@ void DlgSettingsDocumentImp::onLicenseTypeChanged(int index)
             break;
         default:
             prefLicenseUrl->setText(QString::fromAscii(""));
+            prefLicenseUrl->setReadOnly(false);
triplus
Postby triplus » Mon Sep 07, 2015 7:30 pm
yorik wrote:There is something in your commit, I don't know what, that makes it very difficult to know what has changed becuase all the file content is marked as changed:
Reading this:
https://en.wikipedia.org/wiki/All_right ... solescence
Probably not setting any licence by default could be an option.
Site Admin
Postby wmayer » Mon Sep 07, 2015 9:19 pm
Are you sure? When you delete your user.cfg then in the preferences page License is set to "All rights reserved" and URL shows the appropriate value. If you switch to "Other" and create the a new document and check
App.ActiveDocument.License # ==> 'Other'
App.ActiveDocument.LicenseURL # ==> ''
which is correct behaviour.
However, your code is definitely wrong. When you start again with an empty user.cfg then the preferences page for License and URL shows the correct values "All rights reserved" and "http://en.wikipedia.org/wiki/All_rights_reserved". But when creating a document
is an empty string which is clearly wrong.
f3nix
Postby f3nix » Mon Sep 07, 2015 10:06 pm
Hi wmayer,
thanks for taking the time and looking into it. My code is wrong. I'll have to take a second look at it.
As a side note. This is what I wanted to fix:
rm ~/.FreeCAD/user.cfg
Start FreeCAD. Default license is „All rights reserved”
Create new document.
u'All rights reserved'
u'http://en.wikipedia.org/wiki/All_rights_reserved'
Change the license to „Other”. Create new document.
u'Other'
u''
Exit FreeCAD. Start it again. Create new document.
u'Other'
Is it a correct behaviour?
Thanks! :)
Cheers,
Mateusz
yorik
Site Admin
Postby yorik » Mon Sep 07, 2015 11:11 pm
I get normal behaviour here...
With a fresh config, if I change the default license to "Other", the default URL field is empty. On new document creation, even after restarting, the License is correct: "Other" and the URL empty...
But indeed the license URL field should be editable so one can change the URL if one wishes. git commit 98e9dd0
f3nix
Postby f3nix » Tue Sep 08, 2015 4:43 am
yorik wrote:But indeed the license URL field should be editable so one can change the URL if one wishes. git commit 98e9dd0
Thank You! :)
Cheers,
Mateusz
