Qt4/Qt5 neutral compilation fixes
Merged, abandoned or rejected pull requests are moved here to clear the main Pull Requests forum.
f3nix
Postby f3nix » Mon Jan 04, 2016 10:02 pm
this is the first batch of Qt5 compatibility changes. This changes are Qt4/Qt5 neutral (they do not use features specific to a particular Qt version).
Compilation and linking tested with:
1. Qt 4.8.7, GCC 5.3.1 - 64-bit
2. Qt 4.8.6 MSVC 2013 - 64-bit
3. Qt 5.5.1 GCC 5.3.1 64-bit
4. Qt 5.5.1 MSVC 2013 64-bit
The following changes since commit 273131c08857464fe7a140331afc864b7ae752f8:
Draft: finished new DXF importer - fixes #2205 (2016-01-04 18:01:34 -0200)
are available in the git repository at:
https://github.com/f3nix/FreeCAD.git qt4-qt5-neutral-1
for you to fetch changes up to ee78b4720c46dc63e02d31edf673f763f91fd8f2:
Change includes in Spreadsheet to be compatible with Qt5. (2016-01-04 22:35:32 +0100)
Mateusz Skowroński (10):
QString::toAscii() is obsolete in Qt5. Replace it with toLatin1().
QString::fromAscii() is obsolete in Qt5. Replace it with fromLatin1().
Qt::WFlags is obsolete in Qt5. Replace it with Qt::WindowFlags.
Make Base::Quantity known to QMetaType.
Qt4's qglobal.h defined TRUE and FALSE. Qt5 does not do it anymore. Replace it with true and false.
QKeySequence::operator QString() is obsolete in Qt5. Use toString(QKeySequence::NativeText) instead.
QObject::accessibleName() is not available in Qt5. Replace it with objectName().
QAbstractItemModel::reset() is obsolete in Qt5. Use beginResetModel() and endResetModel() instead.
Change includes in Quarter to be compatible with Qt5.
 src/App/Application.cpp                            |   2 +-
 src/App/Branding.cpp                               |   2 +-
 src/Base/FileInfo.h                                |   6 +-
 src/Base/Quantity.h                                |   3 +
 src/Base/Tools2D.cpp                               |  18 ++--
 src/Base/UnitsApi.cpp                              |   2 +-
 src/Base/Uuid.cpp                                  |   6 +-
 src/Gui/Action.cpp                                 |  16 +--
 src/Gui/Application.cpp                            |  32 +++---
 src/Gui/BitmapFactory.cpp                          |  20 ++--
 src/Gui/BlenderNavigationStyle.cpp                 |  58 +++++------
 src/Gui/CADNavigationStyle.cpp                     |  66 ++++++------
 src/Gui/CallTips.cpp                               |  12 +--
 src/Gui/Command.cpp                                |   8 +-
 src/Gui/CommandDoc.cpp                             |  12 +--
 src/Gui/CommandStd.cpp                             |   6 +-
 src/Gui/CommandTest.cpp                            |   4 +-
 src/Gui/CommandView.cpp                            |  42 ++++----
 src/Gui/DemoMode.cpp                               |   2 +-
 src/Gui/DemoMode.h                                 |   2 +-
 src/Gui/DlgActionsImp.cpp                          |  20 ++--
 src/Gui/DlgActivateWindowImp.cpp                   |   4 +-
 src/Gui/DlgActivateWindowImp.h                     |   2 +-
 src/Gui/DlgCommandsImp.cpp                         |   4 +-
 src/Gui/DlgCustomizeImp.cpp                        |   4 +-
 src/Gui/DlgCustomizeImp.h                          |   2 +-
 src/Gui/DlgCustomizeSpaceball.cpp                  |  22 ++--
 src/Gui/DlgDisplayPropertiesImp.cpp                |  10 +-
 src/Gui/DlgDisplayPropertiesImp.h                  |   2 +-
 src/Gui/DlgEditFileIncludeProptertyExternal.cpp    |   4 +-
 src/Gui/DlgEditFileIncludeProptertyExternal.h      |   2 +-
 src/Gui/DlgEditorImp.cpp                           |  46 ++++----
 src/Gui/DlgGeneralImp.cpp                          |  22 ++--
 src/Gui/DlgInputDialogImp.cpp                      |   4 +-
 src/Gui/DlgInputDialogImp.h                        |   2 +-
 src/Gui/DlgKeyboardImp.cpp                         |  23 ++--
 src/Gui/DlgMacroExecuteImp.cpp                     |   8 +-
 src/Gui/DlgMacroExecuteImp.h                       |   2 +-
 src/Gui/DlgMacroRecordImp.cpp                      |   4 +-
 src/Gui/DlgMacroRecordImp.h                        |   2 +-
 src/Gui/DlgMaterialPropertiesImp.cpp               |   4 +-
 src/Gui/DlgMaterialPropertiesImp.h                 |   2 +-
 src/Gui/DlgOnlineHelpImp.cpp                       |   2 +-
 src/Gui/DlgParameterImp.cpp                        | 112 ++++++++++----------
 src/Gui/DlgParameterImp.h                          |   2 +-
 src/Gui/DlgPreferencesImp.cpp                      |   6 +-
 src/Gui/DlgPreferencesImp.h                        |   2 +-
 src/Gui/DlgProjectInformationImp.cpp               |  22 ++--
 src/Gui/DlgProjectInformationImp.h                 |   2 +-
 src/Gui/DlgProjectUtility.cpp                      |   2 +-
 src/Gui/DlgProjectUtility.h                        |   2 +-
 src/Gui/DlgPropertyLink.cpp                        |   2 +-
 src/Gui/DlgPropertyLink.h                          |   2 +-
 src/Gui/DlgReportViewImp.cpp                       |   2 +-
 src/Gui/DlgRunExternal.cpp                         |   4 +-
 src/Gui/DlgRunExternal.h                           |   2 +-
 src/Gui/DlgSettings3DViewImp.cpp                   |  14 +--
 src/Gui/DlgSettingsColorGradientImp.cpp            |   2 +-
 src/Gui/DlgSettingsColorGradientImp.h              |   2 +-
 src/Gui/DlgSettingsDocumentImp.cpp                 |  18 ++--
 src/Gui/DlgTipOfTheDayImp.cpp                      |  10 +-
 src/Gui/DlgTipOfTheDayImp.h                        |   2 +-
 src/Gui/DlgToolbarsImp.cpp                         |  36 +++----
 src/Gui/DlgUnitsCalculatorImp.cpp                  |   8 +-
 src/Gui/DlgUnitsCalculatorImp.h                    |   2 +-
 src/Gui/DlgWorkbenchesImp.cpp                      |  16 +--
 src/Gui/DockWindowManager.cpp                      |   6 +-
 src/Gui/Document.cpp                               |   6 +-
 src/Gui/DownloadDialog.cpp                         |   2 +-
 src/Gui/DownloadItem.cpp                           |   6 +-
 src/Gui/EditorView.cpp                             |   2 +-
 src/Gui/ExpressionBinding.cpp                      |   4 +-
 src/Gui/ExpressionCompleter.cpp                    |  10 +-
 src/Gui/FileDialog.cpp                             |  26 ++---
 src/Gui/FileDialog.h                               |   2 +-
 src/Gui/GestureNavigationStyle.cpp                 |  44 ++++----
 src/Gui/GraphvizView.cpp                           |  12 +--
 src/Gui/HelpView.cpp                               |  14 +--
 src/Gui/InputField.cpp                             |  20 ++--
 src/Gui/InputVector.cpp                            |   4 +-
 src/Gui/InputVector.h                              |  10 +-
 src/Gui/InventorNavigationStyle.cpp                |  58 +++++------
 src/Gui/Language/Translator.cpp                    |   6 +-
 src/Gui/MDIView.cpp                                |   4 +-
 src/Gui/MDIView.h                                  |   2 +-
 src/Gui/Macro.cpp                                  |  16 +--
 src/Gui/MainWindow.cpp                             |  98 ++++++++---------
 src/Gui/MainWindow.h                               |   2 +-
 src/Gui/ManualAlignment.cpp                        |   6 +-
 src/Gui/MayaGestureNavigationStyle.cpp             |  42 ++++----
 src/Gui/MenuManager.cpp                            |  18 ++--
 src/Gui/MouseSelection.cpp                         |   8 +-
 src/Gui/NavigationStyle.cpp                        |  64 ++++++------
 src/Gui/NetworkRetriever.cpp                       |  56 +++++-----
 src/Gui/OnlineDocumentation.cpp                    |  22 ++--
 src/Gui/OpenCascadeNavigationStyle.cpp             |  46 ++++----
 src/Gui/Placement.cpp                              |  16 +--
 src/Gui/Placement.h                                |   4 +-
 src/Gui/PrefWidgets.cpp                            |   2 +-
 src/Gui/ProgressBar.cpp                            |   2 +-
 src/Gui/PythonConsole.cpp                          |  28 ++---
 src/Gui/PythonConsolePy.cpp                        |   2 +-
 src/Gui/QListWidgetCustom.cpp                      |   4 +-
 src/Gui/QuantitySpinBox.cpp                        |   8 +-
 src/Gui/Quarter/ContextMenu.cpp                    |   2 +-
 src/Gui/Quarter/DragDropHandler.cpp                |   1 +
 src/Gui/Quarter/ImageReader.cpp                    |   4 +-
 src/Gui/Quarter/KeyboardP.cpp                      |   2 +-
 src/Gui/Quarter/QuarterWidget.cpp                  |   6 +-
 src/Gui/Quarter/QuarterWidget.h                    |   2 +-
 src/Gui/Quarter/QuarterWidgetP.cpp                 |   4 +-
 src/Gui/Quarter/SensorManager.cpp                  |   6 +-
 src/Gui/Quarter/SoQTQuarterAdaptor.cpp             |  28 ++---
 src/Gui/Quarter/SpaceNavigatorDevice.cpp           |   4 +-
 src/Gui/ReportView.cpp                             |   2 +-
 src/Gui/SceneInspector.cpp                         |   6 +-
 src/Gui/SceneInspector.h                           |   2 +-
 src/Gui/Selection.cpp                              |   8 +-
 src/Gui/SelectionView.cpp                          |  50 ++++-----
 src/Gui/SoAxisCrossKit.cpp                         |  28 ++---
 src/Gui/SoAxisCrossKit.h                           |   2 +-
 src/Gui/SoFCBoundingBox.cpp                        |   4 +-
 src/Gui/SoFCDB.cpp                                 |   6 +-
 src/Gui/SoFCInteractiveElement.cpp                 |   4 +-
 src/Gui/SoFCOffscreenRenderer.cpp                  |  12 +--
 src/Gui/SoFCSelection.cpp                          |  58 +++++------
 src/Gui/SoFCSelectionAction.cpp                    |  14 +--
 src/Gui/SoFCSelectionAction.h                      |   2 +-
 src/Gui/SoFCUnifiedSelection.cpp                   |  20 ++--
 src/Gui/SoNavigationDragger.cpp                    |  56 +++++-----
 src/Gui/SoNavigationDragger.h                      |   2 +-
 src/Gui/SoTextLabel.cpp                            |  16 +--
 src/Gui/SpinBox.cpp                                |  30 +++---
 src/Gui/Splashscreen.cpp                           |  92 ++++++++--------
 src/Gui/Splashscreen.h                             |   2 +-
 src/Gui/SplitView3DInventor.cpp                    |  12 +--
 src/Gui/SplitView3DInventor.h                      |   4 +-
 src/Gui/TaskView/TaskAppearance.cpp                |   6 +-
 src/Gui/TaskView/TaskSelectLinkProperty.cpp        |   2 +-
 src/Gui/TextEdit.cpp                               |   6 +-
 src/Gui/TextureMapping.cpp                         |   4 +-
 src/Gui/TextureMapping.h                           |   2 +-
 src/Gui/Thumbnail.cpp                              |   2 +-
 src/Gui/ToolBarManager.cpp                         |   4 +-
 src/Gui/ToolBox.cpp                                |   4 +-
 src/Gui/ToolBoxManager.cpp                         |   2 +-
 src/Gui/TouchpadNavigationStyle.cpp                |  52 ++++-----
 src/Gui/Transform.cpp                              |   2 +-
 src/Gui/Transform.h                                |   2 +-
 src/Gui/Tree.cpp                                   |  14 +--
 src/Gui/View3DInventor.cpp                         |  10 +-
 src/Gui/View3DInventor.h                           |   2 +-
 src/Gui/View3DInventorExamples.cpp                 |   4 +-
 src/Gui/View3DInventorViewer.cpp                   |  20 ++--
 src/Gui/View3DInventorViewer.h                     |   2 +-
 src/Gui/ViewProvider.cpp                           |   4 +-
 src/Gui/ViewProviderAnnotation.cpp                 |   6 +-
 src/Gui/ViewProviderGeometryObject.cpp             |   8 +-
 src/Gui/WidgetFactory.cpp                          |  32 +++---
 src/Gui/Widgets.cpp                                |  14 +--
 src/Gui/Widgets.h                                  |   4 +-
 src/Gui/Workbench.cpp                              |   2 +-
 src/Gui/propertyeditor/PropertyItem.cpp            | 116 ++++++++++-----------
 src/Gui/propertyeditor/PropertyItem.h              |   5 +-
 src/Gui/propertyeditor/PropertyModel.cpp           |  15 +--
 src/Main/FreeCADGuiPy.cpp                          |   4 +-
 src/Main/MainGui.cpp                               |  16 +--
 src/Main/MainPy.cpp                                |   2 +-
 src/Mod/Complete/Gui/Workbench.h                   |   2 +-
 src/Mod/Drawing/Gui/Command.cpp                    |  10 +-
 src/Mod/Fem/Gui/TaskFemConstraint.cpp              |   2 +-
 src/Mod/Fem/Gui/TaskFemConstraintBearing.cpp       |   2 +-
 src/Mod/Fem/Gui/TaskFemConstraintForce.cpp         |   2 +-
 src/Mod/Fem/Gui/TaskFemConstraintGear.cpp          |   2 +-
 src/Mod/Fem/Gui/TaskFemConstraintPressure.cpp      |   2 +-
 src/Mod/Fem/Gui/TaskFemConstraintPulley.cpp        |   2 +-
 src/Mod/Fem/Gui/TaskObjectName.cpp                 |   2 +-
 src/Mod/Image/Gui/GLImageBox.cpp                   |   2 +-
 src/Mod/Image/Gui/GLImageBox.h                     |   2 +-
 src/Mod/Image/Gui/ImageView.cpp                    |  20 ++--
 src/Mod/Import/Gui/AppImportGuiPy.cpp              |  10 +-
 src/Mod/Inspection/Gui/ViewProviderInspection.cpp  |   2 +-
 src/Mod/Inspection/Gui/VisualInspection.cpp        |  16 +--
 src/Mod/Inspection/Gui/VisualInspection.h          |   2 +-
 src/Mod/Mesh/App/Core/Grid.h                       |   2 +-
 src/Mod/Mesh/App/Core/Helpers.h                    |  10 +-
 src/Mod/Mesh/App/Core/MeshIO.cpp                   |   4 +-
 src/Mod/Mesh/App/Core/tritritest.h                 |  14 +--
 src/Mod/Mesh/App/WildMagic4/Wm4LinearSystem.h      |  12 +--
 src/Mod/Mesh/Gui/Command.cpp                       |   6 +-
 src/Mod/Mesh/Gui/DlgEvaluateMeshImp.cpp            |  22 ++--
 src/Mod/Mesh/Gui/DlgEvaluateMeshImp.h              |   4 +-
 src/Mod/Mesh/Gui/DlgRegularSolidImp.cpp            |   8 +-
 src/Mod/Mesh/Gui/DlgRegularSolidImp.h              |   4 +-
 src/Mod/Mesh/Gui/DlgSmoothing.cpp                  |   2 +-
 src/Mod/Mesh/Gui/DlgSmoothing.h                    |   2 +-
 src/Mod/Mesh/Gui/RemoveComponents.cpp              |   4 +-
 src/Mod/Mesh/Gui/RemoveComponents.h                |   4 +-
 src/Mod/Mesh/Gui/Segmentation.cpp                  |   2 +-
 src/Mod/Mesh/Gui/Segmentation.h                    |   2 +-
 src/Mod/Mesh/Gui/SoFCIndexedFaceSet.cpp            |  22 ++--
 src/Mod/Mesh/Gui/SoFCMeshObject.cpp                |  38 +++----
 src/Mod/Mesh/Gui/SoPolygon.cpp                     |   6 +-
 src/Mod/Mesh/Gui/ViewProviderCurvature.cpp         |   6 +-
 src/Mod/Mesh/Gui/Workbench.cpp                     |  24 ++---
 src/Mod/MeshPart/App/MeshAlgos.cpp                 |  20 ++--
 src/Mod/MeshPart/Gui/Tessellation.cpp              |  14 +--
 src/Mod/Part/Gui/Command.cpp                       |  34 +++---
 src/Mod/Part/Gui/CommandParametric.cpp             |  10 +-
 src/Mod/Part/Gui/CrossSections.cpp                 |  14 +--
 src/Mod/Part/Gui/CrossSections.h                   |   2 +-
 src/Mod/Part/Gui/DlgBooleanOperation.cpp           |   4 +-
 src/Mod/Part/Gui/DlgExtrusion.cpp                  |  30 +++---
 src/Mod/Part/Gui/DlgExtrusion.h                    |   2 +-
 src/Mod/Part/Gui/DlgFilletEdges.cpp                |  46 ++++----
 src/Mod/Part/Gui/DlgFilletEdges.h                  |   6 +-
 src/Mod/Part/Gui/DlgPartBoxImp.cpp                 |   4 +-
 src/Mod/Part/Gui/DlgPartBoxImp.h                   |   2 +-
 src/Mod/Part/Gui/DlgPartCylinderImp.cpp            |   4 +-
 src/Mod/Part/Gui/DlgPartCylinderImp.h              |   2 +-
 src/Mod/Part/Gui/DlgPartImportIgesImp.cpp          |   4 +-
 src/Mod/Part/Gui/DlgPartImportIgesImp.h            |   2 +-
 src/Mod/Part/Gui/DlgPartImportStepImp.cpp          |   4 +-
 src/Mod/Part/Gui/DlgPartImportStepImp.h            |   2 +-
 src/Mod/Part/Gui/DlgPrimitives.cpp                 |  74 ++++++-------
 src/Mod/Part/Gui/DlgRevolution.cpp                 |  20 ++--
 src/Mod/Part/Gui/DlgRevolution.h                   |   2 +-
 src/Mod/Part/Gui/Mirroring.cpp                     |  16 +--
 src/Mod/Part/Gui/SoBrepEdgeSet.cpp                 |  12 +--
 src/Mod/Part/Gui/SoBrepFaceSet.cpp                 |  44 ++++----
 src/Mod/Part/Gui/SoBrepPointSet.cpp                |  12 +--
 src/Mod/Part/Gui/SoFCShapeObject.cpp               |   2 +-
 src/Mod/Part/Gui/TaskCheckGeometry.cpp             |   6 +-
 src/Mod/Part/Gui/TaskDimension.cpp                 |  40 +++----
 src/Mod/Part/Gui/TaskFaceColors.cpp                |  12 +--
 src/Mod/Part/Gui/TaskLoft.cpp                      |  22 ++--
 src/Mod/Part/Gui/TaskOffset.cpp                    |   2 +-
 src/Mod/Part/Gui/TaskShapeBuilder.cpp              |  24 ++---
 src/Mod/Part/Gui/TaskSweep.cpp                     |  18 ++--
 src/Mod/Part/Gui/TaskThickness.cpp                 |   2 +-
 src/Mod/Part/Gui/ViewProviderCurveNet.cpp          |   2 +-
 src/Mod/Part/Gui/ViewProviderMirror.cpp            |   2 +-
 src/Mod/PartDesign/Gui/FeaturePickDialog.cpp       |   4 +-
 src/Mod/PartDesign/Gui/TaskDraftParameters.cpp     |   2 +-
 src/Mod/PartDesign/Gui/TaskGrooveParameters.cpp    |   4 +-
 .../PartDesign/Gui/TaskLinearPatternParameters.cpp |  12 +--
 src/Mod/PartDesign/Gui/TaskMirroredParameters.cpp  |  12 +--
 .../Gui/TaskMultiTransformParameters.cpp           |  12 +--
 src/Mod/PartDesign/Gui/TaskPadParameters.cpp       |   2 +-
 src/Mod/PartDesign/Gui/TaskPocketParameters.cpp    |   2 +-
 .../PartDesign/Gui/TaskPolarPatternParameters.cpp  |  10 +-
 .../PartDesign/Gui/TaskRevolutionParameters.cpp    |   2 +-
 src/Mod/PartDesign/Gui/TaskScaledParameters.cpp    |   6 +-
 .../PartDesign/Gui/TaskTransformedParameters.cpp   |   4 +-
 src/Mod/PartDesign/Gui/ViewProviderTransformed.cpp |   2 +-
 src/Mod/Path/Gui/AppPathGuiPy.cpp                  |  18 ++--
 src/Mod/Path/Gui/TaskDlgPathCompound.cpp           |   8 +-
 src/Mod/Path/libarea/kurve/Finite.cpp              |   2 +-
 src/Mod/Points/Gui/DlgPointsReadImp.cpp            |   2 +-
 src/Mod/Points/Gui/DlgPointsReadImp.h              |   2 +-
 src/Mod/Raytracing/Gui/Command.cpp                 |   4 +-
 src/Mod/Raytracing/Gui/ViewProvider.cpp            |   8 +-
 .../ReverseEngineering/Gui/FitBSplineSurface.cpp   |   2 +-
 src/Mod/ReverseEngineering/Gui/Poisson.cpp         |   2 +-
 src/Mod/Robot/Gui/CommandTrajectory.cpp            |  12 +--
 src/Mod/Robot/Gui/TaskEdge2TracParameter.cpp       |   4 +-
 src/Mod/Robot/Gui/TaskRobot6Axis.cpp               |   4 +-
 src/Mod/Robot/Gui/TaskTrajectory.cpp               |  16 +--
 .../Robot/Gui/TaskTrajectoryDressUpParameter.cpp   |   2 +-
 src/Mod/Robot/Gui/TrajectorySimulate.cpp           |  14 +--
 src/Mod/Robot/Gui/ViewProviderRobotObject.cpp      |  12 +--
 src/Mod/Robot/Gui/Workbench.cpp                    |   6 +-
 src/Mod/Sketcher/Gui/CommandCreateGeo.cpp          |   2 +-
 src/Mod/Sketcher/Gui/CommandSketcherTools.cpp      |   4 +-
 src/Mod/Sketcher/Gui/DrawSketchHandler.cpp         |  12 +--
 src/Mod/Sketcher/Gui/SoDatumLabel.cpp              |   2 +-
 src/Mod/Sketcher/Gui/TaskSketcherConstrains.cpp    |  12 +--
 src/Mod/Sketcher/Gui/TaskSketcherElements.cpp      |   6 +-
 src/Mod/Sketcher/Gui/ViewProviderSketch.cpp        |  50 ++++-----
 src/Mod/Spreadsheet/Gui/AppSpreadsheetGui.cpp      |   5 +
 src/Mod/Spreadsheet/Gui/SpreadsheetView.cpp        |   4 +-
 .../Spreadsheet/Gui/ViewProviderSpreadsheet.cpp    |   2 +-
 src/Mod/Spreadsheet/Gui/Workbench.cpp              |  10 +-
 src/Mod/Spreadsheet/Gui/qtcolorpicker.cpp          |  22 ++--
 src/Mod/Spreadsheet/Gui/qtcolorpicker.h            |   4 +-
 src/Mod/Test/Gui/UnitTestImp.cpp                   |   6 +-
 src/Mod/Test/Gui/UnitTestImp.h                     |   2 +-
 src/Mod/Test/Gui/UnitTestPy.cpp                    |   2 +-
 src/Mod/Web/Gui/AppWebGuiPy.cpp                    |   2 +-
 src/Mod/Web/Gui/BrowserView.h                      |   2 +-
 290 files changed, 1741 insertions(+), 1725 deletions(-)
Cheers,
Mateusz
Site Admin
Re: Qt4/Qt5 neutral compilation fixes
Postby wmayer » Tue Jan 05, 2016 2:42 pm
Are you sure that this method doesn't exist in Qt5? When looking at the Qt5 docs this method is still listed: http://doc.qt.io/qt-5/qwidget.html#accessibleName-prop
Can you explain why this is needed, please?
Site Admin
Postby wmayer » Tue Jan 05, 2016 4:23 pm
The following commits are merged:
Waiting for comments on:
Thanks for your great work so far!
f3nix
Postby f3nix » Tue Jan 05, 2016 11:31 pm
Hi!
wmayer wrote:The following commits are merged:
Thank you! :)
It fixes this build error with Qt5:
[ 13%] Building CXX object src/Gui/CMakeFiles/FreeCADGui.dir/QListWidgetCustom.cpp.o
/home/f3nix/devel/freecad/my_freecad_qt5/FreeCAD/src/Gui/QListWidgetCustom.cpp: In member function ‘virtual void QListWidgetCustom::dragMoveEvent(QDragMoveEvent*)’:
/home/f3nix/devel/freecad/my_freecad_qt5/FreeCAD/src/Gui/QListWidgetCustom.cpp:50:26: error: ‘class QObject’ has no member named ‘accessibleName’
         if (e->source()->accessibleName() == disabled_wbs) {
src/Gui/CMakeFiles/FreeCADGui.dir/build.make:3076: polecenia dla obiektu 'src/Gui/CMakeFiles/FreeCADGui.dir/QListWidgetCustom.cpp.o' nie powiodły się
make[2]: *** [src/Gui/CMakeFiles/FreeCADGui.dir/QListWidgetCustom.cpp.o] Błąd 1
CMakeFiles/Makefile2:4637: polecenia dla obiektu 'src/Gui/CMakeFiles/FreeCADGui.dir/all' nie powiodły się
make[1]: *** [src/Gui/CMakeFiles/FreeCADGui.dir/all] Błąd 2
Makefile:127: polecenia dla obiektu 'all' nie powiodły się
make: *** [all] Błąd 2
Maybe there is some better fix for it?
As far as I can tell it is only used for drag and drop support for enabling/disabling workbenches. And it needs some more love.
I can do something like this with current implementation:
With Qt5 and first compilation I got:
[ 13%] Building CXX object src/Gui/CMakeFiles/FreeCADGui.dir/DlgUnitsCalculatorImp.cpp.o
In file included from /usr/include/x86_64-linux-gnu/qt5/QtCore/qcoreapplication.h:37:0,
                 from /usr/include/x86_64-linux-gnu/qt5/QtWidgets/qapplication.h:37,
                 from /usr/include/x86_64-linux-gnu/qt5/QtWidgets/QApplication:1,
                 from /home/f3nix/devel/freecad/my_freecad_qt5/FreeCAD/src/Gui/DlgUnitsCalculatorImp.cpp:26:
/usr/include/x86_64-linux-gnu/qt5/QtCore/qmetatype.h: In instantiation of ‘int qMetaTypeId() [with T = Base::Quantity]’:
/usr/include/x86_64-linux-gnu/qt5/QtCore/qmetatype.h:1732:26:   required from ‘int qRegisterMetaType() [with T = Base::Quantity]’
/home/f3nix/devel/freecad/my_freecad_qt5/FreeCAD/build-test/src/Gui/moc_DlgUnitsCalculatorImp.cpp:104:86:   required from here
/usr/include/x86_64-linux-gnu/qt5/QtCore/qmetatype.h:1725:5: error: invalid application of ‘sizeof’ to incomplete type ‘QStaticAssertFailure<false>’
     Q_STATIC_ASSERT_X(QMetaTypeId2<T>::Defined, "Type is not registered, please use the Q_DECLARE_METATYPE macro to make it known to Qt's meta-object system");
src/Gui/CMakeFiles/FreeCADGui.dir/build.make:2260: polecenia dla obiektu 'src/Gui/CMakeFiles/FreeCADGui.dir/DlgUnitsCalculatorImp.cpp.o' nie powiodły się
make[2]: *** [src/Gui/CMakeFiles/FreeCADGui.dir/DlgUnitsCalculatorImp.cpp.o] Błąd 1
After applying changes to: src/Base/Quantity.h only (https://github.com/f3nix/FreeCAD/commit ... cbfe63aa43)
[ 13%] Building CXX object src/Gui/CMakeFiles/FreeCADGui.dir/CommandDoc.cpp.o
In file included from /usr/include/x86_64-linux-gnu/qt5/QtCore/qobject.h:48:0,
                 from /usr/include/x86_64-linux-gnu/qt5/QtCore/qcoreapplication.h:40,
                 from /home/f3nix/devel/freecad/my_freecad_qt5/FreeCAD/src/Gui/CommandDoc.cpp:26:
/home/f3nix/devel/freecad/my_freecad_qt5/FreeCAD/src/Gui/propertyeditor/PropertyItem.h:46:1: error: redefinition of ‘struct QMetaTypeId<Base::Quantity>’
 Q_DECLARE_METATYPE(Base::Quantity)
/home/f3nix/devel/freecad/my_freecad_qt5/FreeCAD/src/Base/Quantity.h:193:1: error: previous definition of ‘struct QMetaTypeId<Base::Quantity>’
src/Gui/CMakeFiles/FreeCADGui.dir/build.make:2020: polecenia dla obiektu 'src/Gui/CMakeFiles/FreeCADGui.dir/CommandDoc.cpp.o' nie powiodły się
make[2]: *** [src/Gui/CMakeFiles/FreeCADGui.dir/CommandDoc.cpp.o] Błąd 1
Commenting out Q_DECLARE_METATYPE(Base::Quantity) in PropertyItem.h fixed it for Qt5.
But for Qt4:
[ 19%] Building CXX object src/Gui/CMakeFiles/FreeCADGui.dir/propertyeditor/PropertyItem.cpp.o
In file included from /home/f3nix/devel/freecad/my_freecad_qt5/FreeCAD/src/Gui/propertyeditor/PropertyItem.cpp:2603:0:
/home/f3nix/devel/freecad/my_freecad_qt5/FreeCAD/build-test-qt4/src/Gui/propertyeditor/moc_PropertyItem.cpp:222:10: error: ‘staticMetaObject’ is not a member of ‘Base’
         &Base::staticMetaObject,
/home/f3nix/devel/freecad/my_freecad_qt5/FreeCAD/build-test-qt4/src/Gui/propertyeditor/moc_PropertyItem.cpp:547:10: error: ‘staticMetaObject’ is not a member of ‘Base’
src/Gui/CMakeFiles/FreeCADGui.dir/build.make:4441: polecenia dla obiektu 'src/Gui/CMakeFiles/FreeCADGui.dir/propertyeditor/PropertyItem.cpp.o' nie powiodły się
make[2]: *** [src/Gui/CMakeFiles/FreeCADGui.dir/propertyeditor/PropertyItem.cpp.o] Błąd 1
CMakeFiles/Makefile2:4487: polecenia dla obiektu 'src/Gui/CMakeFiles/FreeCADGui.dir/all' nie powiodły się
So I have applied the second change to src/Gui/propertyeditor/PropertyItem.h.
Cheers,
Mateusz
UPDATE:
Qt4: QDragMoveEvent source() const : QWidget *
Qt5: QDragMoveEvent source() const : QObject *
So this change is Qt5 specific.
Site Admin
Postby wmayer » Wed Jan 06, 2016 4:04 pm
I have fixed this. In git commit 0b3f60a68c6533 it is checked if the list view has defined a property "OnlyAcceptFrom". If not, it allows all drag and drop events, otherwise it checks if the name of the source object is part of the whitelist.
Site Admin
Postby wmayer » Wed Jan 06, 2016 4:17 pm
With Qt5 and first compilation I got:...
Could you test if adding these lines to DlgUnitsCalculatorImp.h solves the problem, too?
#include <Base/Quantity.h>
#include "ui_DlgUnitsCalculator.h"
#ifdef Q_MOC_RUN
#endif
For me the above works for Qt4.
f3nix
Postby f3nix » Wed Jan 06, 2016 11:02 pm
#ifdef Q_MOC_RUN
#endif
diff --git a/src/Gui/DlgUnitsCalculatorImp.h b/src/Gui/DlgUnitsCalculatorImp.h
index 6afbc66..6dc897d 100644
--- a/src/Gui/DlgUnitsCalculatorImp.h
+++ b/src/Gui/DlgUnitsCalculatorImp.h
@@ -24,11 +24,16 @@
 #ifndef GUI_DIALOG_DlgActivateWindowImp_H
 #define GUI_DIALOG_DlgActivateWindowImp_H
+#include <Base/Quantity.h>
 namespace Gui {
 namespace Dialog {
+#ifdef Q_MOC_RUN
+Q_DECLARE_METATYPE(Base::Quantity)
+#endif
  * The DlgUnitsCalculator provides a unit conversion dialog
  * \author Juergen Riegel
Gives:
/home/f3nix/devel/freecad/my_freecad_qt5/FreeCAD/build-qt5-debug/src/Gui/moc_DlgUnitsCalculatorImp.cpp:104:86:   required from here
CMakeFiles/Makefile2:4639: polecenia dla obiektu 'src/Gui/CMakeFiles/FreeCADGui.dir/all' nie powiodły się
Cheers,
Mateusz
f3nix
Postby f3nix » Thu Jan 07, 2016 5:37 am
Neat solution!
Works great both with Qt4 and Qt5. Thanks.
Cheers,
Mateusz
f3nix
Postby f3nix » Thu Jan 07, 2016 5:55 am
Here is the latest branch rebased on current master:
https://github.com/f3nix/FreeCAD/tree/qt5-transition-2
This version compiles and links under LInux (Qt4/Qt5). Windows version needs some more changes which I have not pushed yet.
It may be built without PySide2 (but then it does not start):
- comment out stuff Regarding PySide2 from main CMakeLists.txt
- # ifdef HAVE_PYSIDE from src/Gui/WidgetFactory.cpp needs to be commented out as well
This is not totally accurate since I'm writing it from my head. Will write something more this evening.
Usage:
$ cmake -DCMAKE_BUILD_TYPE=Debug -DFREECAD_USE_QT=1 ..    // this is for Qt5
                               (@2014 by peterl94) :)
$ cmake -DCMAKE_BUILD_TYPE=Debug ..    // this is for Qt4
Cheers,
Mateusz
Site Admin
Postby wmayer » Thu Jan 07, 2016 11:15 am
What else must be done for the Qt5 port other than that? Maybe we should leave the current master as is and do the complete porting to Qt5 in a separate branch (e.g. yours) but remove all old Qt4 stuff. What do you think?
