#619 Made TreeView stable
realthunder
Re: #619 Made TreeView stable
Postby realthunder » Mon Apr 03, 2017 8:31 pm
Okay, the problem is confirmed. QTreeWidgetItem::takeChildren is an expensive operation under Windows, but cheap on Linux. However, without takeChildren, the treeview can't easily reflect order change in claimChildren. I'll think a better way to handle this later. It's 4am here, I'd better take some rest now.
Postby wmayer » Mon Apr 03, 2017 8:45 pm
realthunder wrote:How to check?
In the preferences under Edit > Preferences > Viewer > 3D-Viewer. There you will find the entry Use OpenGL Vertex Buffer Object (experimental)
But it's unlikely that this has an impact on the issue because at this point it doesn't go through the GLRender method of the Inventor nodes.
Jom official download server is down. What are the odds of that! Care to post the binarry here?
Alternatively you can create vcxproj files with cmake and then use msbuild. I just can't remember the exact arguments to start a parallel build.
BTW, I am having trouble with Windows debug build. I am getting a bunch of unfound reference when linking OCC. Release build is fine. Any tricks on that?
Which errors do you get?
sgrogan
Postby sgrogan » Mon Apr 03, 2017 9:32 pm
wmayer wrote:Alternatively you can create vcxproj files with cmake and then use msbuild. I just can't remember the exact arguments to start a parallel build.
/m or /m:n where n is the number of worker threads. /m uses maximum available by default. Verbosity can also effect build performance. I use
$msbuild "$buildDir\FreeCAD_trunk.sln" /m /nologo /verbosity:minimal /p:Configuration=Release "/p:Platform=$platform"
Postby NormandC » Tue Apr 04, 2017 1:16 am
realthunder wrote:I can see that the logic does have some problem. You should definitely bring this up to PartDesign, the original thread you posted. But, you can be assured that this is not Tree View's problem, and the developer of PartDesign will understand that.
OK then. Thanks.
Postby wmayer » Tue Apr 04, 2017 11:14 am
realthunder wrote:Okay, the problem is confirmed. QTreeWidgetItem::takeChildren is an expensive operation under Windows, but cheap on Linux. However, without takeChildren, the treeview can't easily reflect order change in claimChildren. I'll think a better way to handle this later. It's 4am here, I'd better take some rest now.
I can't confirm that it's fast on Linux. When running it under Ubuntu 14.04 as a Virtual box guest I stopped it after waiting a couple of minutes. Also commenting out the block as in PR670 doesn't make a difference.
OS: Ubuntu 14.04.5 LTS
Version: 0.17.10681 (Git)
Build type: Unknown
Hash: d7d7aa238f2cbfd10a9682e7213e6ef5dc990368
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.7.0
realthunder
Postby realthunder » Tue Apr 04, 2017 4:48 pm
wmayer wrote:I can't confirm that it's fast on Linux. When running it under Ubuntu 14.04 as a Virtual box guest I stopped it after waiting a couple of minutes. Also commenting out the block as in PR670 doesn't make a difference.
Please try my branch at https://github.com/realthunder/FreeCAD/ ... eeViewFix2. This is a simple fix I tried last night. It avoid using takeChildren and addChild back each time on object change. And I tested it fine on my Windows. The problem with this fix is that it may not reflect the order change in claimChildren, which I think is a minor problem.
realthunder
Postby realthunder » Tue Apr 04, 2017 7:52 pm
I have just submitted a new PR for the fix, which still keeps track of the order of claimed children. This fix is more complicated than the simple fix I mentioned above. My own test shows it's fine. But It better be thoroughly tested by others as well.
My branch https://github.com/realthunder/FreeCAD/ ... ewFixOrder
Postby wmayer » Wed Apr 05, 2017 5:35 pm
Yes, that fixes the problem. The load is again as fast as it has been. Thanks!
