tanderson69 wrote: ↑Sun Aug 12, 2018 11:28 pm
wmayer wrote: ↑Sun Aug 12, 2018 10:47 pm
I'd really like to see progress indicators with cancel options used more in freecad
The problem with OCCT is that there are only a few algorithms where a progress indicator can be set.
BopAlgo_Options will take a progress indicator and the BopAlgo_ArgumentAnalyzer is a subclass. So it looks like there is a chance that it works(occt 7.3), but I haven't tried.
https://dev.opencascade.org/doc/refman/ ... lyzer.html
I'm not sure if it's implemented. Here is the relevant source code from BOPAlgo_Options.cxx:
130 //=======================================================================
131 //function : SetProgressIndicator
132 //purpose :
133 //=======================================================================
134 void BOPAlgo_Options::SetProgressIndicator
135 (const Handle(Message_ProgressIndicator)& theObj)
136 {
137 if (!theObj.IsNull()) {
138 myProgressIndicator = theObj;
139 }
140 }
141 //=======================================================================
142 //function : UserBreak
143 //purpose :
144 //=======================================================================
145 void BOPAlgo_Options::UserBreak() const
146 {
147 if (myProgressIndicator.IsNull()) {
148 return;
149 }
150 if (myProgressIndicator->UserBreak()) {
151 throw Standard_NotImplemented("BOPAlgo_Options::UserBreak(), method is not implemented");
152 }
153 }
UserBreak() simply returns void if the pi is null and throws a not implemented exception otherwise. Could be subclasses, such as BOPalgo_ArgumentAnalyzer are expected to override and implement this themselves?
Here is the implementation of UserBreak() in Message_ProgressIndicator.cxx:
165 //=======================================================================
166 //function : UserBreak
167 //purpose :
168 //=======================================================================
169
170 Standard_Boolean Message_ProgressIndicator::UserBreak ()
171 {
172 return Standard_False;
173 }
174
It returns false in all cases and makes no effort to check if the user canceled.
Seems to me you should be able to call BOPCheck_ArgumentAnalyzer::SetProgressIndicator() passing it the handle to the progress indicator and it would update it periodically during Perform(), but I don't see any code (maybe I'm just missing it) that would do any such thing. A call *is* made to UserBreak() between each check during the Perform() operation, but its return value is ignored. Maybe the expectation is it throws an exception to stop the operation? Otherwise the only thing it could do to stop Perform() would be to put something in myResult and set myStopOnFirst to true, which is the kind of hackery I might would do, but not professional coders. I'm thinking (and hoping to be wrong) it's just incomplete code, but I think it has been 2 years, so not much hope of it getting completed any time soon.
Here is the Perform() function from BOPAlgo_ArgumentAnalyzer.cxx:
152 // function: Perform
153 // purpose:
154 // ================================================================================
155 void BOPAlgo_ArgumentAnalyzer::Perform()
156 {
157 try {
158 OCC_CATCH_SIGNALS
159 myResult.Clear();
160 //
161 UserBreak();
162 //
163 // 1. Prepare
164 Prepare();
165 //
166 UserBreak();
167 //
168 // 2. Test types
169 if(myArgumentTypeMode) {
170 TestTypes();
171 }
172 //
173 UserBreak();
174 //
175 // 3. Test self-interference
176 if(mySelfInterMode) {
177 TestSelfInterferences();
178 }
179 //
180 UserBreak();
181 //
182 // 4. Test small edges
183 if(mySmallEdgeMode) {
184 if(!(!myResult.IsEmpty() && myStopOnFirst))
185 TestSmallEdge();
186 }
187 //
188 UserBreak();
189 //
190 // 5. Test possibility to rebuild faces
191 if(myRebuildFaceMode) {
192 if(!(!myResult.IsEmpty() && myStopOnFirst))
193 TestRebuildFace();
194 }
195 //
196 UserBreak();
197 //
198 // 6. Test tangent
199 if(myTangentMode) {
200 if(!(!myResult.IsEmpty() && myStopOnFirst))
201 TestTangent();
202 }
203 //
204 UserBreak();
205 //
206 // 7. Test merge vertices
207 if(myMergeVertexMode) {
208 if(!(!myResult.IsEmpty() && myStopOnFirst))
209 TestMergeVertex();
210 }
211 //
212 UserBreak();
213 //
214 // 8. Test merge edges
215 if(myMergeEdgeMode) {
216 if(!(!myResult.IsEmpty() && myStopOnFirst))
217 TestMergeEdge();
218 }
219 //
220 UserBreak();
221 //
222 // 9. Test shapes continuity
223 if(myContinuityMode) {
224 if(!(!myResult.IsEmpty() && myStopOnFirst))
225 TestContinuity();
226 }
227 //
228 UserBreak();
229 //
230 // 10. Test validity of the curves on the surfaces
231 if(myCurveOnSurfaceMode) {
232 if(!(!myResult.IsEmpty() && myStopOnFirst))
233 TestCurveOnSurface();
234 }
235 }
236 catch(Standard_Failure) {
237 BOPAlgo_CheckResult aResult;
238 aResult.SetCheckStatus(BOPAlgo_CheckUnknown);
239 myResult.Append(aResult);
240 }
241 }
As a sidenote:
Notice: myStopOnFirst refers to the stopOnFirstFaulty() option, so I think that option really does halt the check on finding the first fault. (Stands to reason since we wouldn't be getting fewer results with it enabled.) Problem could be, that first check is the one that is consuming the most time (just a hunch, nothing to back that up with except for your findings earlier than using the option wasn't speeding things up any). If the first check is the costly one, then stopping after that check doesn't really speed things up. And if no faults are found at all, then obviously it won't help in those cases, either.
Another sidenote: I experimented with removing the copy operation and everything still worked. Could be an older version of occt needed it? I'm not really seeing any performance benefits from removing it, but maybe the objects I tested it don't take long to copy. Should be faster if we remove the copy stuff, I can't see how it wouldn't be (unless maybe something in the copy process makes the bopcheck run faster) but the risk would be it might break things for some users.
I didn't see UserBreak() defined in BOPAlgo_Analzyer.cxx, so I guess the parent class (BOPAlgo_Options) is the one that gets run. But if that's the case I did try creating an instance of a progress indicator and passing the handle to SetProgressIndicator():
Handle(Message_ProgressIndicator) pi = new Part::ProgressIndicator(100);
BOPCheck.SetProgressIndicator(pi);
BOPCheck.Perform()
Seems to me I should have gotten a not implemented exception unless my handle is null that I'm passing in, (but I'm pretty sure that's not the case, read on.)
I removed that code and tried another tactic: showing progress in between checks for cases where multiple objects have been selected to be checked. I do have a (semi-working) progress indicator that updates as each check finishes, so that's why I don't think I was passing a null handle. Relevant code in TaskGeometryCheck.cpp:
#include "../App/ProgressIndicator.h"
#include <QApplication>
void TaskCheckGeometryResults::goCheck()
Gui::WaitCursor wc;
int selectedCount(0), checkedCount(0), invalidShapes(0);
std::vector<Gui::SelectionSingleton::SelObj> selection = Gui::Selection().getSelection();
std::vector<Gui::SelectionSingleton::SelObj>::iterator it;
ResultEntry *theRoot = new ResultEntry();
Handle(Message_ProgressIndicator) pi = new Part::ProgressIndicator(selection.size());
for (it = selection.begin(); it != selection.end(); ++it)
std::string msg = std::string("Checking ") + selection[selectedCount].DocName + std::string(".") + selection[selectedCount].FeatName+std::string("...");
pi->NewScope(selectedCount, msg.c_str());
qApp->processEvents();
pi->Show();
selectedCount++;
Part::Feature *feature = dynamic_cast<Part::Feature *>((*it).pObject);
if (!feature)
continue;
/*remaining code is unchanged until the bottom of the for loop, where I have this: */
pi->EndScope();
- bopcheck-pi.gif (224.13 KiB) Viewed 1947 times
