Purtroppo quando lo carico in Windows si pianta su PartShape68.brp, mi blocca completamente il sistema e mi obbliga a riavviare il PC.
In Linux sono riuscito a ottenere una schermata e il log che allego
Msg: FreeCAD 0.16, Libs: 0.16R6712 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2015
Log: Time = Mon Sep 25 22:17:33 2017
Log: AppDataSkipVendor = true
Log: AppHomePath = /usr/lib/freecad/
Log: AppIcon = freecad
Log: AppTempPath = /tmp/
Log: BinPath = /usr/lib/freecad/bin/
Log: BuildRepositoryURL = git://github.com/FreeCAD/FreeCAD.git releases/FreeCAD-0-16
Log: BuildRevision = 6712 (Git)
Log: BuildRevisionBranch = releases/FreeCAD-0-16
Log: BuildRevisionDate = 2017/07/17 17:27:47
Log: BuildRevisionHash = da2d364457257a7a8c6fb2137cea12c45becd71a
Log: BuildVersionMajor = 0
Log: BuildVersionMinor = 16
Log: CopyrightInfo = © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2015
Log: Debug = 0
Log: DocPath = /usr/lib/freecad/doc/
Log: ExeName = FreeCAD
Log: ExeVendor = FreeCAD
Log: ExeVersion = 0.16
Log: LoggingFile = 1
Log: LoggingFileName = /home/renato/.FreeCAD/FreeCAD.log
Log: MaintainerUrl = http://www.freecadweb.org/wiki/index.php?title=Main_Page
Log: PATH = /home/renato/anaconda2/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
Log: PYTHONPATH =
Log: PythonSearchPath = :/usr/bin/../lib/python2.7/:/usr/bin/../lib/python2.7/plat-x86_64-linux-gnu:/usr/bin/../lib/python2.7/lib-tk:/usr/bin/../lib/python2.7/lib-old:/usr/bin/../lib/python2.7/lib-dynload
Log: RunMode = Gui
Log: SplashAlignment = Bottom|Left
Log: SplashInfoColor = #c8c8c8
Log: SplashScreen = freecadsplash
Log: SplashTextColor = #ffffff
Log: StartWorkbench = StartWorkbench
Log: SystemParameter = /home/renato/.FreeCAD/system.cfg
Log: UserAppData = /home/renato/.FreeCAD/
Log: UserHomePath = /home/renato
Log: UserParameter = /home/renato/.FreeCAD/user.cfg
Log: Verbose =
Log: Create Application
Log: Run App init script
Log: Init: starting App::FreeCADInit.py
Log: Init: Searching for modules...
Log: Init: Initializing /usr/lib/freecad/Mod/Sketcher... done
Log: Init: Initializing /usr/lib/freecad/Mod/dxfLibrary.py(Init.py not found)... ignore
Log: Init: Initializing /usr/lib/freecad/Mod/ReverseEngineering... done
Log: Init: Initializing /home/renato/.FreeCAD/Mod/USBTerminal... done
Log: Init: Initializing /usr/lib/freecad/Mod/Image... done
Log: Init: Initializing /usr/lib/freecad/Mod/PartDesign... done
Log: Init: Initializing /home/renato/.FreeCAD/Mod/fasteners... done
Log: Init: Initializing /usr/lib/freecad/Mod/plugins(Init.py not found)... ignore
Log: Init: Initializing /usr/lib/freecad/Mod/Ship(Init.py not found)... ignore
Log: Init: Initializing /usr/lib/freecad/Mod/Robot... done
Log: Init: Initializing /usr/lib/freecad/Mod/Complete... done
Log: Init: Initializing /home/renato/.FreeCAD/Mod/assembly2(Init.py not found)... ignore
Log: Init: Initializing /usr/lib/freecad/Mod/Plot(Init.py not found)... ignore
Log: Init: Initializing /usr/lib/freecad/Mod/MeshPart... done
Log: Init: Initializing /usr/lib/freecad/Mod/OpenSCAD... done
Log: Init: Initializing /usr/lib/freecad/Mod/Fem... done
Log: Init: Initializing /home/renato/.FreeCAD/Mod/workfeature(Init.py not found)... ignore
Log: Init: Initializing /usr/lib/freecad/Mod/Spreadsheet... done
Log: Init: Initializing /usr/lib/freecad/Mod/Start... done
Log: Init: Initializing /usr/lib/freecad/Mod/Animation... done
Log: Init: Initializing /usr/lib/freecad/Mod/Draft... done
Log: Init: Initializing /usr/lib/freecad/Mod/Test... done
Log: Init: Initializing /usr/lib/freecad/Mod/Import... done
Log: Init: Initializing /home/renato/.FreeCAD/Mod/parts_library(Init.py not found)... ignore
Log: Init: Initializing /home/renato/.FreeCAD/Mod/FCGear(Init.py not found)... ignore
Log: Init: Initializing /home/renato/.FreeCAD/Mod/FCAD_script_generator(Init.py not found)... ignore
Log: Init: Initializing /home/renato/.FreeCAD/Mod/bolts(Init.py not found)... ignore
Log: Init: Initializing /usr/lib/freecad/Mod/Web... done
Log: Init: Initializing /usr/lib/freecad/Mod/dxfColorMap.pyc(Init.py not found)... ignore
Log: Init: Initializing /usr/lib/freecad/Mod/Material... done
Log: Init: Initializing /usr/lib/freecad/Mod/dxfImportObjects.pyc(Init.py not found)... ignore
Log: Init: Initializing /usr/lib/freecad/Mod/PartsLibrary.FCMacro(Init.py not found)... ignore
Log: Init: Initializing /usr/lib/freecad/Mod/Raytracing... done
Log: Init: Initializing /usr/lib/freecad/Mod/Macro_screw_maker1_2.FCMacro(Init.py not found)... ignore
Log: Init: Initializing /usr/lib/freecad/Mod/Mesh... done
Log: Init: Initializing /home/renato/.FreeCAD/Mod/sheetmetal... done
Log: Init: Initializing /usr/lib/freecad/Mod/dxfReader.pyc(Init.py not found)... ignore
Log: Init: Initializing /usr/lib/freecad/Mod/Part... done
Log: Init: Initializing /usr/lib/freecad/Mod/Arch... done
Log: Init: Initializing /usr/lib/freecad/Mod/start_bolts.FCMacro(Init.py not found)... ignore
Log: Init: Initializing /usr/lib/freecad/Mod/dxfReader.py(Init.py not found)... ignore
Log: Init: Initializing /home/renato/.FreeCAD/Mod/flamingo... done
Log: Init: Initializing /usr/lib/freecad/Mod/dxfLibrary.pyc(Init.py not found)... ignore
Log: Init: Initializing /usr/lib/freecad/Mod/dxfColorMap.py(Init.py not found)... ignore
Log: Init: Initializing /usr/lib/freecad/Mod/start_WF.FCMacro(Init.py not found)... ignore
Log: Init: Initializing /home/renato/.FreeCAD/Mod/drawing_dimensioning(Init.py not found)... ignore
Log: Init: Initializing /usr/lib/freecad/Mod/dxfImportObjects.py(Init.py not found)... ignore
Log: Init: Initializing /usr/lib/freecad/Mod/Points... done
Log: Init: Initializing /usr/lib/freecad/Mod/Idf... done
Log: Init: Initializing /usr/lib/freecad/Mod/Path... done
Log: Init: Initializing /usr/lib/freecad/Mod/Inspection... done
Log: Init: Initializing /usr/lib/freecad/Mod/Drawing... done
Log: Init: Initializing /usr/lib/freecad/Mod/Macro_ForceRecompute.FCMacro(Init.py not found)... ignore
Log: Using /usr/lib/freecad/Mod as module path!
Log: System path after init:
Log: /usr/lib/freecad/bin
Log: /usr/lib/freecad/Mod/Sketcher
Log: /usr/lib/freecad/Mod/dxfLibrary.py
Log: /usr/lib/freecad/Mod/ReverseEngineering
Log: /home/renato/.FreeCAD/Mod/USBTerminal
Log: /usr/lib/freecad/Mod/Image
Log: /usr/lib/freecad/Mod/PartDesign
Log: /home/renato/.FreeCAD/Mod/fasteners
Log: /usr/lib/freecad/Mod/plugins
Log: /usr/lib/freecad/Mod/Ship
Log: /usr/lib/freecad/Mod/Robot
Log: /usr/lib/freecad/Mod/Complete
Log: /home/renato/.FreeCAD/Mod/assembly2
Log: /usr/lib/freecad/Mod/Plot
Log: /usr/lib/freecad/Mod/MeshPart
Log: /usr/lib/freecad/Mod/OpenSCAD
Log: /usr/lib/freecad/Mod/Fem
Log: /home/renato/.FreeCAD/Mod/workfeature
Log: /usr/lib/freecad/Mod/Spreadsheet
Log: /usr/lib/freecad/Mod/Start
Log: /usr/lib/freecad/Mod/Animation
Log: /usr/lib/freecad/Mod/Draft
Log: /usr/lib/freecad/Mod/Test
Log: /usr/lib/freecad/Mod/Import
Log: /home/renato/.FreeCAD/Mod/parts_library
Log: /home/renato/.FreeCAD/Mod/FCGear
Log: /home/renato/.FreeCAD/Mod/FCAD_script_generator
Log: /home/renato/.FreeCAD/Mod/bolts
Log: /usr/lib/freecad/Mod/Web
Log: /usr/lib/freecad/Mod/dxfColorMap.pyc
Log: /usr/lib/freecad/Mod/Material
Log: /usr/lib/freecad/Mod/dxfImportObjects.pyc
Log: /usr/lib/freecad/Mod/PartsLibrary.FCMacro
Log: /usr/lib/freecad/Mod/Raytracing
Log: /usr/lib/freecad/Mod/Macro_screw_maker1_2.FCMacro
Log: /home/renato/.FreeCAD/Mod/sheetmetal
Log: /usr/lib/freecad/Mod/dxfReader.pyc
Log: /usr/lib/freecad/Mod/Arch
Log: /usr/lib/freecad/Mod/start_bolts.FCMacro
Log: /home/renato/.FreeCAD/Mod/flamingo
Log: /usr/lib/freecad/Mod/dxfLibrary.pyc
Log: /usr/lib/freecad/Mod/start_WF.FCMacro
Log: /home/renato/.FreeCAD/Mod/drawing_dimensioning
Log: /usr/lib/freecad/Mod/Points
Log: /usr/lib/freecad/Mod/Idf
Log: /usr/lib/freecad/Mod/Path
Log: /usr/lib/freecad/Mod/Inspection
Log: /usr/lib/freecad/Mod/Drawing
Log: /usr/lib/freecad/Mod/Macro_ForceRecompute.FCMacro
Log: /home/renato/anaconda2/bin
Log: /usr/local/sbin
Log: /usr/local/bin
Log: /usr/sbin
Log: /usr/bin
Log: /sbin
Log: /bin
Log: /usr/games
Log: /usr/local/games
Log: /snap/bin
Log: Init: App::FreeCADInit.py done
Log: Init: Creating Gui::Application and QApplication
Log: Local server 'FreeCAD' started
Log: OpenGL version 3.0 or higher is present
Log: Run Gui init script
Log: Init: Running FreeCADGuiInit.py start script...
Log: Init: Searching modules...
Log: Init: Initializing /usr/lib/freecad/Mod/dxfLibrary.py(InitGui.py not found)... ignore
Msg: Mod pluginloader InitGui.py starting ...
Log: Could not parse stylesheet of widget 0x1479ba0
Log: Loading GUI of Web module... done
Msg: pluginmanager config file /usr/lib/freecad-daily//Mod/plugins/pluginloaderconfig.yaml
Msg: pluginmanager userconfig file /usr/lib/freecad/Mod/plugins/myconfig.yaml
Msg: Mod pluginloader InitGui.py done
Log: Cannot open file '/home/renato/.FreeCAD/Mod/FreeCAD_SheetMetal/Resources/icons/AddWall.svg', because: No such file or directory
Log: Cannot open file '/home/renato/.FreeCAD/Mod/FCGear-master/Resources/icons/gearworkbench.svg', because: No such file or directory
Log: Cannot open file '/home/renato/.FreeCAD/Mod/PCB/data/board.svg', because: No such file or directory
Log: Cannot open file '/usr/lib/freecad/Mod/JoinFeatures/PyResources/icons/Part-joinCutout.svg', because: No such file or directory
Log: Cannot open file '/usr/lib/freecad/Mod/JoinFeatures/PyResources/icons/Part-joinConnect.svg', because: No such file or directory
Log: Cannot open file '/usr/lib/freecad/Mod/JoinFeatures/PyResources/icons/Part-joinEmbed.svg', because: No such file or directory
Log: Cannot open file '/home/renato/.FreeCAD/Mod/FreeCAD_FastenersWB/Icons/EN1665.svg', because: No such file or directory
Log: Init: Initializing /usr/lib/freecad/Mod/plugins... done
Log: Init: Initializing /usr/lib/freecad/Mod/Ship... done
Log: Module: Part
Log: Loading Part module... done
Log: Init: Initializing /home/renato/.FreeCAD/Mod/assembly2... done
Log: Init: Initializing /usr/lib/freecad/Mod/Plot... done
Log: Init: Initializing /home/renato/.FreeCAD/Mod/workfeature(InitGui.py not found)... ignore
Log: Loading GUI of Part module... done
Log: Loading Drawing module... done
Log: Init: Initializing /home/renato/.FreeCAD/Mod/parts_library(InitGui.py not found)... ignore
Log: Init: Initializing /home/renato/.FreeCAD/Mod/FCGear... done
Log: Init: Initializing /home/renato/.FreeCAD/Mod/FCAD_script_generator(InitGui.py not found)... ignore
Log: Init: Initializing /home/renato/.FreeCAD/Mod/bolts(InitGui.py not found)... ignore
Log: Init: Initializing /usr/lib/freecad/Mod/dxfColorMap.pyc(InitGui.py not found)... ignore
Log: Init: Initializing /usr/lib/freecad/Mod/dxfImportObjects.pyc(InitGui.py not found)... ignore
Log: Init: Initializing /usr/lib/freecad/Mod/PartsLibrary.FCMacro(InitGui.py not found)... ignore
Log: Init: Initializing /usr/lib/freecad/Mod/Macro_screw_maker1_2.FCMacro(InitGui.py not found)... ignore
Log: Init: Initializing /usr/lib/freecad/Mod/dxfReader.pyc(InitGui.py not found)... ignore
Log: Init: Initializing /usr/lib/freecad/Mod/start_bolts.FCMacro(InitGui.py not found)... ignore
Log: Init: Initializing /usr/lib/freecad/Mod/dxfReader.py(InitGui.py not found)... ignore
Log: Init: Initializing /usr/lib/freecad/Mod/dxfLibrary.pyc(InitGui.py not found)... ignore
Log: Init: Initializing /usr/lib/freecad/Mod/dxfColorMap.py(InitGui.py not found)... ignore
Log: Init: Initializing /usr/lib/freecad/Mod/start_WF.FCMacro(InitGui.py not found)... ignore
Log: Init: Initializing /home/renato/.FreeCAD/Mod/drawing_dimensioning... done
Log: Init: Initializing /usr/lib/freecad/Mod/dxfImportObjects.py(InitGui.py not found)... ignore
Log: Init: Initializing /usr/lib/freecad/Mod/Idf(InitGui.py not found)... ignore
Log: Init: Initializing /usr/lib/freecad/Mod/Macro_ForceRecompute.FCMacro(InitGui.py not found)... ignore
Log: Init: Loading FreeCAD GUI
Log: Show main window
Log: Init: Running FreeCADGuiInit.py start script... done
Log: Init: Activating default workbench StartWorkbench
Log: Loading GUI of Start module... done
Log: Loading Start module... done
Log: [31mvoid DBusMenuExporterPrivate::addAction(QAction*, int)[0m: Already tracking action "Mostra/Nascondi" under id 230
Msg: gentoolbars ...
Log: Active view is Start page (at 0x38a4010)
Log: Init: Showing main window
Log: Main window restored
Log: Toolbars restored
Log: Couldn't connect to spacenav daemon
Log: Init: Entering event loop
Log: Init: Processing command line files
Log: Active view is Unnamed : 1[*] (at 0x39b2350)
Log: Active document is Senza_nome (at 0x3994000)
Log: Sel : Clear selection
Log: No active document
Log: Active view is Senza nome : 1[*] (at 0x39b2350)
Log: Active view is Unnamed : 1[*] (at 0x3a3b1a0)
Log: Active document is TCU_160650M_Filtro_rotante_montaggio_7 (at 0x5499200)
Log: Loading Sketcher module... done
Log: Loading PartDesign module... done
Log: Loading GUI of Sketcher module... done
Log: Loading GUI of PartDesign module... done
Err: Reading failed from embedded file: PartShape68.brp (857650 bytes, 231647 bytes compressed)
Forse qualcuno ha istruzioni su come editare l'attuale progetto per eliminare l'elemento difettoso.
Renato
