Blocco generale icone
Buongiorno,
dopo aver installato freeCAD e averlo usato qualche giorno per semplici modelli 3D col moudulo "Part", si sono spente le icone delle lavorazioni prima,
poi tutte compre quelle "Nuovo e Apri" nel menu File.
Anche dopo aver disinstallato e reinstallato il SW il difetto continua e non mi permette di eseguire nemmeno il raggio di uno spigolo di un cubo.
Allego info versione installata:
OS: Windows 7
Version: 0.16.6712 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
Qualcuno cortesemente sa dirmi se ci sono log di errori da cancellare da qualche parte e come risolvere il problema?
Grazie
OS: Windows 7
Grazie
Re: Blocco generale icone
If someone would like to translate this, the problem is he has changed a setting, probably by accident, this is stored in the configuration file, so uninstall/reinstall is a total waste of time as the configuration file will still be there. All he has to do is delete the configuration file then start FreeCAD again, when FreeCAD can not find the configuration file it will just create a new one with all default settings.
Hi jmaustpc,
thank you very much for your quick reply, but where can i find the configuration file and how is it called exactly?
Linux only household here, I haven't had to put up with Windows for years but I believe on Windows config files and your local Addons should live in the directory "%APPDATA%\FreeCAD". I recommend that you should backup it before deleting.
If you have installed custom modules manually under the Mod directory of your FreeCAD, you should backup them as well.
Once you resolve this, could you please make a new post in Italian telling someone else reading this who may not understand English how you fixed it. Generally posting in non-native forum language is considered not polite, but in this case I hoped, seemingly correctly, that my wrong language response might be more useful than me not responding at all.
@jmaustpc Thank you!
I file di configurazione sono i file system.cfg e user.cfg e si trovano in C:\Users\User\AppData\Roaming\FreeCAD.
Nella disinstallazione automatica non vengono eliminati, ma bisogna farlo a mano.
Non è però necessario disinstallare, basta cancellare, o meglio per sicurezza rinominare questi file, es system.old e poi riavviare FreeCAD. Vengono creati due file di configurazione nuovi.
Vedere anche alla fine di https://forum.freecadweb.org/viewtopic. ... 8&start=10
Se con questo non risolvi rinnova la richiesta
Renato
Renato
Ok grazie mille, è quello che ha scritto anche l'amico dall'Australia, così ora è anche tradotto come chiedeva lui
Purtroppo però cancellando i due file indicati il difetto sparisce ma alla prima operazione di nuovo le icone diventano tutte grigie e non più disponibili... quindi il problema è generato da qualcosa d'altro?
Puoi specificare quale operazione e magari allegare una schermata?
basta selezionare lo spigolo del cubo e cercare di raggiarlo per far spegnere tutte le icone...
