intersezione fra rette
calculon
Postby calculon » Wed May 29, 2019 1:23 pm
Ciao a tutti, qualcuno ha elaborato uno script per rilevare le coordinate esatte in cui due rette si intersecano?
un'altra richiesta: esiste un comando python per valutare se un punto appartiene ad una retta?
grazie mille!
renatorivo
Re: intersezione fra rette
Postby renatorivo » Wed May 29, 2019 9:00 pm
Ciao.
La soluzione per lo script sembra essere in questi due post:
https://forum.freecadweb.org/viewtopic.php?t=26650
https://forum.freecadweb.org/viewtopic.php?t=19698
io però n Windows ottengo sempre un errore 'DraftGeomUtils' is not defined anche con FreeCAD 0.19
non ho ancora provato in Ubuntu.
Puoi vedere altri post in inglese cercando con Script intersection
mario52
Postby mario52 » Sat Jun 01, 2019 11:35 am
saluti
prova cosi:
seleziona le due linee
import DraftGeomUtils
sel=Gui.Selection.getSelection()
print(DraftGeomUtils.findIntersection(sel[0].Shape.Edges[0],sel[1].Shape.Edges[0]))
intersection between two lines
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Dialog creation. My macros on Gist.github.
renatorivo
Postby renatorivo » Sat Jun 01, 2019 12:19 pm
Grazie Mario, funziona:
pl = FreeCAD.Placement()
>>> pl.Rotation.Q = (0.0,0.0,0.0,1.0)
>>> pl.Base = FreeCAD.Vector(0.0,0.0,0.0)
>>> points = [FreeCAD.Vector(0.0,0.0,0.0),FreeCAD.Vector(0.0,-40.0,0.0)]
>>> line = Draft.makeWire(points,placement=pl,closed=False,face=True,support=None)
>>> Draft.autogroup(line)
>>> pl.Base = FreeCAD.Vector(-20.0,-20.0,0.0)
>>> points = [FreeCAD.Vector(-20.0,-20.0,0.0),FreeCAD.Vector(20.0,-20.0,0.0)]
[Vector (0.0, -20.0, 0.0)]
OS: Windows 8.1
Version: 0.18.16117 (Git)
Branch: releases/FreeCAD-0-18
Hash: dbb4cc6415bac848a294f03b80f65e888d531742
Python version: 3.6.6
Qt version: 5.6.2
Locale: Italian/Italy (it_IT)
