[Solved] IDF import: error import "<class 'ModuleNotFoundError'>: No module named '__builtin__'
fiffo
Postby fiffo » Wed Jun 12, 2019 10:55 am
Ciao a tutti,
provo ad importare un file IDF (.emn file) ma mi compare questo errore... come se mancasse il modulo "builtin" ...
qualcuno mi può aiutare?
"Traceback (most recent call last):
File "C:\Users\floriano\Desktop\freecad\FreeCAD_0.19.16944_x64_LP_12.1.2_PY3QT5-WinVS2015\FreeCAD_0.19.16944_x64_LP_12.1.2_PY3QT5-WinVS2015\Mod\Idf\Idf.py", line 25, in <module>
import FreeCAD, Part, os, FreeCADGui, __builtin__
<class 'ModuleNotFoundError'>: No module named '__builtin__' "
I used this version of Freecad = 0.19 ...
OS: Windows 10 (10.0)
Version: 0.19.16945 (Git)
Hash: d818a9638424a934bd9da74d187a1af4cb773f05
Python version: 3.6.8
Qt version: 5.12.1
Reason: Added [Solved] to this thread
renatorivo
Re: IDF import: error import "<class 'ModuleNotFoundError'>: No module named '__builtin__'
Postby renatorivo » Fri Jun 14, 2019 7:20 pm
Ciao.
Il problema è dovuto al passaggio a Python3:
Renamed module __builtin__ to builtins (removing the underscores, adding an ‘s’). The __builtins__ variable found in most global namespaces is unchanged. To modify a builtin, you should use builtins, not __builtins__!
Puoi vedere altro in https://docs.python.org/3.0/whatsnew/3.0.html
Correggendo le righe 25 e 57 di C:\Program Files\FreeCAD 0.18\Mod\Idf\Idf.py, o dove-si-trova il tuo Mod\Idf, dovrebbe funzionare.
fiffo
Postby fiffo » Mon Jun 17, 2019 12:25 pm
Grazie mille per la risposta...
sai per caso come le devo modificare?
renatorivo
Postby renatorivo » Mon Jun 17, 2019 8:08 pm
riga 25 di Idf.py
import FreeCAD, Part, os, FreeCADGui, builtins
e poi riga 57
pythonopen = builtins.open # to distinguish python built-in open function from the one declared here
provato, funziona in
OS: Windows 8.1
Version: 0.18.16117 (Git)
Branch: releases/FreeCAD-0-18
Hash: dbb4cc6415bac848a294f03b80f65e888d531742
Python version: 3.6.6
Qt version: 5.6.2
Locale: Italian/Italy (it_IT)
easyw-fc
Postby easyw-fc » Mon Jun 17, 2019 8:29 pm
it could be a Pull Request then :D
fiffo
Postby fiffo » Tue Jun 18, 2019 1:48 pm
Grazie mille Renato.
Avevo postato lo stesso quesito anche nel forum in inglese dove anche là mi avevano risposto.
renatorivo
Re: [Solved] IDF import: error import "<class 'ModuleNotFoundError'>: No module named '__builtin__'
Postby renatorivo » Tue Jun 18, 2019 7:55 pm
Dato che propone una soluzione diversa si può consultare in https://forum.freecadweb.org/viewtopic.php?f=3&t=36983
