problema fem
Luixx
problema fem
Postby Luixx » Mon Sep 09, 2019 8:53 pm
Salve, sto guardando un tutorial e lo sto seguendo.. come mai ad certo punto ad questo passaggio https://youtu.be/A6jJemyVdl8?t=273
a me mi viene fuori:
questo e l'esempio:
fem.FCStd
(358.8 KiB) Downloaded 14 times
Avete idea?
Grazie mille.
EDIT: E poi perché a me mi viene un attenzione in rosso ad questo passaggio:
0.0: We are going to start ...
0.0: Start Gmsh ...
0.6: Gmsh had warnings ...
0.6: Warning : Unknown element type for UNV export (MSH type 15) - output file might be invalid Warning : Unknown element type for UNV export (MSH type 15) - output file might be invalid Warning : Unknown element type for UNV export (MSH type 15) - output file might be invalid Warning : Unknown element type for UNV export (MSH type 15) - output file might be invalid Warning : Unknown element type for UNV export (MSH type 15) - output file might be invalid Warning : Unknown element type for UNV export (MSH type 15) - output file might be invalid Warning : Unknown element type for UNV export (MSH type 15) - output file might be invalid Warning : Unknown element type for UNV export (MSH type 15) - output file might be invalid Warning : Unknown element type for UNV export (MSH type 15) - output file might be invalid Warning : Unknown element type for UNV export (MSH type 15) - output file might be invalid Warning : Unknown element type for UNV export (MSH type 15) - output file might be invalid Warning : Unknown element type for UNV export (MSH type 15) - output file might be invalid Warning : Unknown element type for UNV export (MSH type 15) - output file might be invalid Warning : Unknown element type for UNV export (MSH type 15) - output file might be invalid Warning : Unknown element type for UNV export (MSH type 15) - output file might be invalid Warning : Unknown element type for UNV export (MSH type 15) - output file might be invalid Warning : Unknown element type for UNV export (MSH type 15) - output file might be invalid Warning : Unknown element type for UNV export (MSH type 15) - output file might be invalid Warning : Unknown element type for UNV export (MSH type 15) - output file might be invalid Warning : Unknown element type for UNV export (MSH type 15) - output file might be invalid
0.6: Gmsh done!
renatorivo
Re: problema fem
Postby renatorivo » Tue Sep 10, 2019 9:35 am
Luixx
Re: problema fem
Postby Luixx » Tue Sep 10, 2019 12:49 pm
va bè lascio perdere.. era solamente per vedere cosa faceva "fem". ma mi sa che in windows non posso utilizzarlo.
grazie lo stesso.
Luixx
Re: problema fem
Postby Luixx » Tue Sep 10, 2019 2:05 pm
scusa, ma cosa devo installare in windows ?. grazie mille esiste qualcosa di open source che vada in windows.?
renatorivo
Re: problema fem
Postby renatorivo » Tue Sep 10, 2019 5:28 pm
L'albero della tua analisi contiene più vincoli rispetto al tutorial. Eliminando i vincoli in eccesso sembra funzionare.
OS: Windows 8.1
Version: 0.18.16131 (Git)
Branch: releases/FreeCAD-0-18
Hash: 3129ae4296e40ed20e7b3d460b86e6969acbe1c3
Python version: 3.6.6
Qt version: 5.6.2
Locale: Italian/Italy (it_IT)
Luixx
Re: problema fem
Postby Luixx » Wed Sep 11, 2019 9:58 am
ok. ma hai installato qualcosa?, mi protesti passarmi il file modificato? .
Grazie mille.
renatorivo
Re: problema fem
Postby renatorivo » Wed Sep 11, 2019 10:38 am
Nessuna istallazione.
Il file è troppo grande per essere allegato.
Cancella ElementGeometry1D e ElementGeometry2D
Doppio clic su Analysis
Clic su CalculiXccxTools
Clic su Esegui i calcoli con il solutore
Appare la nuova voce Calculix_static_results, espandila e vedi se Result-mesh è nascosta attivala.
Per valutare lo spostamento seleziona Calculix_static_results e poi dal menu principale Results->Mostra rsultato
Luixx
Re: problema fem
Postby Luixx » Wed Sep 11, 2019 12:05 pm
ok, ci sono riuscito ... non so da dove sono venuti fuori quei due oggetti.
vedi allegato:
Una cosa mi e apparsa una finestra dos cosa è stato?
Grazie mille.
renatorivo
Re: problema fem
Postby renatorivo » Wed Sep 11, 2019 6:50 pm
Tutto normale, è ccx.exe che si trova in /FreeCAD/bin che viene eseguito nel terminale/finestra dos
Luixx
Re: problema fem
Postby Luixx » Wed Sep 11, 2019 6:52 pm
ok, ultima cosa ma questo workbench visto che vado su internet ad cercare esempi sui vari workbench ,
ma per caso da quello che ho capito e per calcolare la forza del pezzo meccanico ?
hai informazioni su come impostare freecad per meccanica?.
grazie mille.
