Origin Planes and Datum plane size - PartDesign
cram
Post by cram »
Have done a bit of a search and couldn't seem to work out if there is away to resize the planes. Firstly with the orgin planes XY, XZ, YZ and any datum planes the user adds?
For if I select the Origin , in the combo view under view tab there is 'size' and reads values 14.4, 14.4, 12.0 with respect to x,y,z however there are not selectable to change.
OS: Windows 7
Version: 0.18.16093 (Git)
Branch: releases/FreeCAD-0-18
Hash: 690774c0effe4fd7b8d2b5e2fb2b8c8d145e21ce
Python version: 2.7.14
OCC version: 7.2.0
Re: Origin Planes and Datum plane size - PartDesign
In the properties of the DatumPlane you can switch ResizeMode to manual and set length and width.
cram
Post by cram »
chrisb wrote: Mon Mar 18, 2019 7:39 am In the properties of the DatumPlane you can switch ResizeMode to manual and set length and width.
Cool, what about the origin planes, are they resizeable?
ickby
Post by ickby »
Everything should automatically update to be always slightly larger than your model. So as you go designing you always have them visible.
cram
Post by cram »
ickby wrote: Mon Mar 18, 2019 9:57 am Everything should automatically update to be always slightly larger than your model. So as you go designing you always have them visible.
The scenario I have is I have a imported model in step file format of a shipping container. When I create new body the origin planes are microscopic in comparison to the imported model. Thus if I zoom out to see the whole model, I cannot see the planes at all as it appears as small as a dot/pixel if that.
kisolre
Post by kisolre »
Why do yo need to see them? Just select the proper one from the list and draw the first rectangular sketch, constraint to those 40ft and they will become as big as the body.
ickby
Post by ickby »
ah yes that is true, body (and part) only scale to the content within it, not to other things in the scene.
cram wrote: Mon Mar 18, 2019 8:52 am what about the origin planes, are they resizeable?
No, I don't think so. They should resize according to the size of the model.
cram
Post by cram »
kisolre wrote: Mon Mar 18, 2019 11:38 am Why do yo need to see them? Just select the proper one from the list and draw the first rectangular sketch, constraint to those 40ft and they will become as big as the body.
To use as a visual aid.
cram
Post by cram »
chrisb wrote: Mon Mar 18, 2019 6:05 pm
Ok will go ahead and try that.
