Yes, I managed but the result is not good because the holes get capped.schupin wrote: ↑Sun Jun 23, 2019 10:24 amI'm trying to make cuts in your part to do a slice render and I'm having some issues : I can't manage to do a boolean substraction with a cube to have a cut... Did you succeed doing such a cut in FreeCAD before render it ?paoligno90 wrote: ↑Sat Jun 22, 2019 4:53 pm It's only one single part. I tried with various cuts to see the differences in the .pov file. It seems that the number of meshes increases reducing the cut size and then it goes down losing some and therefore losing details and faces. I guess I will have to redo the part keeping different pieces and render them not as single piece, but still this is a very weird behavior
In any case, I tried a fresh install of FreeCAD 0.18.2, I always get only 232 meshes in the .pov file and the part is not complete. I tried FreeCAD 0.19 but I get the same result. It seems that something goes wrong during the creation of the .pov file. What's your procedure to create it?
