I notice 2 mesh issues:
A:
- open this example file:
- select in the tree the feature "Kanülenlöcher" (that holds the tip)
- Use the Mesh menu to tesselate it (use the standard mesher and default settings)
result: You get 2 meshes, and both are identical. This must have been introduced recently. Up to now one only got one mesh of the body up to the tip.
B:
- take the same example and try to export the mesh you created in case A to a file
- as filename use "Balgwand.FCStd" and press save
result: you get a warning that the file exists. But the logic should be that the dialog takes the given filename and adds the extension ".stl". So expected to end up with a file named "Balgwand.FCStd.stl"
Maybe I am wrong and the file dialog doesn't allow purposely filenames with 2 dots.
OS: Windows 10 (10.0)
Version: 0.19.18498 (Git)
Hash: bfe968138218089ba6614ee81ae109b775a7b01a
Python version: 3.6.8
Qt version: 5.12.1
