I created a box model for laser cutting so I need the only "top" of every detail. I inserted them all to the TechDraw page and located them with small gaps between them all. However, when I change the original box dimensions to make it bigger, all part on the TechDraw became overlapped.
My question: Is it possible in the TechDraw to place details' views parametrically
I mean is it possible to make the location of one view be related to the boundaries of another, so that when size of the first view will be changed, the location of the second one will accordingly be shifted to stay next to the first view with the desired gap?
Parametric view locations in the TechDraw
Re: Parametric view locations in the TechDraw
Yu can use Expressions for the X and Y properties.
And one more piece of advice, please.
I have the box walls as a polar array. When I insert an array to the TD it's inserting as one combined image. And I did not find a way to insert each array element that I need, because some walls have unique holes.
And in general - is there any way to put all(selected) objects to the TD and later "rotate" each of them in TD individually to locate them "face to top"?
I'm afraid I don't understand. If you have holes in some of the instances, then you have a cut at top level of the tree, and you should insert that into the TechDraw page
It should be possible by editing the properties, but that was for me too much fiddling around, so I am faster turning it in 3D view and add it then to the TechDraw page.And in general - is there any way to put all(selected) objects to the TD and later "rotate" each of them in TD individually to locate them "face to top"?
