I'm having problems placing a door (and generally most things if I'm honest) so that they snap properly to other things in my drawing.
As you can see in the video I've taken of my screen it appears that the door is snapping to the correct place and will be placed in the correct position, but when I press the mouse button it moves the door to the wrong place.
I'm sure I'm doing something wrong but I wouldn't have a clue what it is?
Note that I'm pressing X so that the door moves along the X axis only.
I'm using FreeCAD 0.19 as follows and I've attached the file I'm using.
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Door not being placed in the right location
- Studio - tk2 - rev2.FCStd
- My FreeCAD File
- (376.33 KiB) Downloaded 23 times
Re: Door not being placed in the right location
Moved to Arch forum.
- thomas-neemann
- thomas-neemann
sometimes e.g. even with dowgrade you can get the desired result with undo. so here too
https://www.youtube.com/watch?v=7VQu1ZbhQB4
Thanks, I stumbled upon this work around a short time ago, but thanks for posting.thomas-neemann wrote: ↑Sat Jul 31, 2021 6:47 am sometimes e.g. even with dowgrade you can get the desired result with undo. so here too
Why does it work like this sometimes and other times it works as expected? Is there some way of turning this behaviour off?
- thomas-neemann
zan wrote: ↑Sat Jul 31, 2021 8:10 amThanks, I stumbled upon this work around a short time ago, but thanks for posting.thomas-neemann wrote: ↑Sat Jul 31, 2021 6:47 am sometimes e.g. even with dowgrade you can get the desired result with undo. so here too
I guess you are using partdesign. I prevent that by not using partdesign.
