Navigation cube quite small
un1corn
Post by un1corn »
Hi fellow Cadders.
Is it possible to increase the size slightly of the navigation cube, sometimes I try several times to say, pick the corner or occasionally rotate the cube?
The text on the cube is very small in normal use and almost unreadable.
So I resort to dragging the images/parts around with the mouse.
The attached image might give an idea of the issue, Icons are sized at 24px, It was OK in V0.18.
Your comments appreciated.
Thanks
OS: Windows 10 (10.0)
Version: 0.19.23546 (Git)
Hash: 6b017f9a16b15b0e628c8d874c4058442dee5548
Python version: 3.6.8
Qt version: 5.12.1
Cube size.JPG (63.64 KiB) Viewed 2381 times
937
Re: Navigation cube quite small
Post by 937 »
Here are the preferences of the navigation cube under Edit>Preferences:
UR_
Post by UR_ »
If you install CubeMenu from addon manager, you will get much more adjustabilities
Screenshot 001.png (20.13 KiB) Viewed 2333 times
un1corn
Post by un1corn »
Many thanks 937.
I kept looking in preferences, but the cube size is not shown in my case (see screen snip)
However I downloaded the Cube Menu and was able to adjust the size from the settings.
Now looking good, as in screen snip .
Thanks again.
Cube size 2.JPG (230.64 KiB) Viewed 2301 times
GeneFC
Post by GeneFC »
un1corn wrote: Mon Jun 21, 2021 4:03 pm I kept looking in preferences, but the cube size is not shown in my case
I think that option was added in version 0.20.
I don't see it in 0.19 either.
Gene
user1234
Post by user1234 »
Yes, 0.20dev (master) only. Added on 2021-03-09
https://github.com/FreeCAD/FreeCAD/comm ... 88c436a6d8
Greetings
user1234
Shalmeneser
Post by Shalmeneser »
You should learn shortcut (Std_View_Menu) :
4 5 6
1 2 3
0
v3 v7 vf
onekk
Post by onekk »
Same problem here:
OS: Artix Linux (openbox)
Version: 0.20.26155 (Git) AppImage
Hash: 0926a4148bcff11249fd4f56bc30256102ffe105
Python version: 3.9.7
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.5.3
Locale: Italian/Italy (it_IT)
Latest AppImage.
Plus Cube Menu will crash with an error.
I think that adding a simple font size box to the main preferences will be a more useful modification.
Regards
Carlo D.
- Various other stuffs.
M4x
Post by M4x »
onekk
Post by onekk »
M4x wrote: Mon Oct 25, 2021 5:52 pm Here you go Release_notes_0.20#User_interface
Here what, font size is not cited in any place, I have also an installation of realthunder's ls3 version and I have succeeded to change the font size,
using "Label" setting on the cube menu, but this setting is not in stock FC version.
The point is relying on an addon to make such simple change is not a clever way, this weird behaviour is also in latest 0.19 Appimage, but in past version everything will show correctly, I don't remember well but in 0.19 this behaviour was not present in former versions, I have noticed when I have updated 0.19 to the latest AppImage.
Maybe I have to set some font preferences elsewhere, maybe in the system Qt settings, but how to know what font size (and eventually what Qt font specification name) navigation cube is using?
EDIT: I have read some discussion speaking for a missing font, on some installations, but there were (or maybe I've not seen) the missing font name . Does anyone know something about it?
Regards
Carlo D.
