Clone or Shapebinder of sketch to be referenced as external geometry?
Lupin
Post by Lupin »
If I want to reference edges of a sketch in a different body as external geometry in a sketch, is there any reason not to just use a clone of the sketch added to the body? At least when I don't need the "trace support" (shapebinder) or "relative" (sub-object shapebinder) options? The clone also has the advantage that it can be moved around inside the body (normal shapebinder can't) or even "supported" by a feature of the body (can't be done with either shapebinder).
If none of these features are needed (just a plain reference to another sketch at the origin), is there any difference between picking one or the other?
It is sometimes a little bit confusing when there are different functions achieving very similar things and you can't tell which one is the "right" one.
bambuko
Re: Clone or Shapebinder of sketch to be referenced as external geometry?
Post by bambuko »
subshape binder (green one) has placement property and can be moved?
I have used it to bind sketches.
I am using Link branch and Assembly3
you can also download ... and try it here
excellent Assembly3 tutorials here
Lupin
Post by Lupin »
bambuko wrote: Sun Jan 23, 2022 2:38 pm subshape binder (green one) has placement property and can be moved?
Yes, as I said can't be done with the "normal" shapebinder (the blue one), but neither shapebinder (blue or green) can be mapped ("Support"/"Map Mode") onto a surface for example, but a clone can.
You can use a clone. You should drag it into the body before mapping it to a surface inside its new home.
