(WORKAROUND) Sketcher limit?
thomas-neemann
Post by thomas-neemann »
I can't set a constraint when building inclined railroad tracks in a curve. Am I exceeding a limit in Sketcher?
1054.FCStd
(6.69 KiB) Downloaded 26 times
these dimensions
should be 213mm
when i try i get this result
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 0.20.28873 (Git) AppImage
Branch: (HEAD detached at 4366c2f)
Hash: 4366c2faecae2c5326c12bbe8cbd230ec817eb0c
Python 3.9.12, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
Last edited by thomas-neemann on Wed May 18, 2022 11:03 am, edited 1 time in total.
bambuko
Re: Sketcher limit?
Post by bambuko »
You are not showing the whole picture of your file (and the reason for your problem) ...
Screenshot from 2022-05-18 10.13.18.png (23.36 KiB) Viewed 745 times
get rid of the vertical constraint and you will stop confusing FreeCAD ;)
Screenshot from 2022-05-18 10.15.35.png (5.34 KiB) Viewed 745 times
I am using Link branch and Assembly3
you can also download ... and try it here
excellent Assembly3 tutorials here
thomas-neemann
Re: Sketcher limit?
bambuko wrote: Wed May 18, 2022 9:17 am ...
thanks for the addition. how to solve the problem?
thomas-neemann
Re: Sketcher limit?
bambuko wrote: Wed May 18, 2022 9:17 am ...and the reason for your problem...
a task can be the problem ?
Shalmeneser
Re: Sketcher limit?
Post by Shalmeneser »
50m & 0.2m -> R=6250m
6250 / 0.2 = 31250
The radius will be around 31250 times the small dimension.
Do you really need a circle ? a line is not enough ?
(the circle is the straigth upper line.)
Annotation 2022-05-18 115618.jpg (19.71 KiB) Viewed 701 times
DimensionsCircleLine_SHALM.FCStd
(5.42 KiB) Downloaded 16 times
thomas-neemann
Re: Sketcher limit?
Shalmeneser wrote: Wed May 18, 2022 10:00 am ..
thanks for the tip, will test it and measure the difference in track length
bambuko
Re: Sketcher limit?
Post by bambuko »
Shalmeneser wrote: Wed May 18, 2022 10:00 am ...Do you really need a circle ? a line is not enough ?
actually in rail engineering it's neither straight line nor the circle, search:
https://duckduckgo.com/?q=rail+transiti ... 7-1&ia=web
and yes... it matters (even in railway scale models)
In Thomas's case if he insist on circle it is easily done, as I have shown.
thomas-neemann
Re: Sketcher limit?
I can't measure the difference because fcinfo drops out for me. here is a workaraund in draft from min 0:37
edit final version
https://www.youtube.com/watch?v=HbFAzExyqk4
phpBB [video]
Last edited by thomas-neemann on Thu May 19, 2022 4:14 am, edited 2 times in total.
Shalmeneser
Re: Sketcher limit?
bambuko wrote: Wed May 18, 2022 9:17 am You are not showing the whole picture of your file (and the reason for your problem) ...
Don't understand, the vertical constraint is needed.
thomas-neemann
Re: Sketcher limit?
bambuko wrote: Wed May 18, 2022 10:14 am ..
can you upload the file?
