Cannot Pad Sketch - getWireDirection Error
code-surfer-dev
Post by code-surfer-dev »
I am a noob at FreeCAD, and am running the following:
OS: macOS 10.16
Version: 0.20.1.29410 (Git)
Branch: (HEAD detached at 0.20.1)
Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563
Python 3.10.5, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.2
Locale: C/Default (C)
My sketch is fully constrained and closed, and when I try to pad my sketch, I get the following error:
getWireDirection: Failed to create face from wire, Internal name: Pad
I have tried searching the forums for different variations on the error message, but cannot find any other posts, although I figure someone else must have had the same problem before, so apologies in advance for that. I have attached a screenshot and a copy of my file. Any help is greatly appreciated.
Many thanks!
construction-geometry-training.FCStd
(20.65 KiB) Downloaded 18 times
Screenshot 2022-11-29 at 3.43.54 PM.png (827.15 KiB) Viewed 887 times
Be curious, not judgemental. Ted Lasso, falsely attributed to Walt Whitman
drmacro
Re: Cannot Pad Sketch - getWireDirection Error
Post by drmacro »
The sketch is WAY too complicated. Make multiple sketches.
And, as it is would create multiple solids with Pad.
When you create a PD Body, you have defined a container that will contain a single, solitary, cumulative solid. Each feature (Pad/Pocket/etc. operation) in the Body is cumulative (and the result of each feature is NOT an atomic solid). The result of each feature MUST result in a single solitary solid (that is an accumulation of it's predecessors).
Roy_043
Post by Roy_043 »
In the notch on the right there is a circle with R=0.
Bance
Post by Bance »
That sketch is so complex so as to be useless for anything as can be seen by the fact that you can't figure out where the error is.
Can you tell me where circle no 42 is and why it has a 0mm radius?
GeneFC
Post by GeneFC »
If the zero-radius circle is removed the sketch pads without error.
Yes, the sketch is rather complex, but otherwise there is no real error.
Gene
code-surfer-dev
Thank you Roy_043, Bance, & Gene!
I thought the dot (the circle with a radius of 0) was a point that was showing up due to a glitch in the view LOL.
If @Bance hadn't mentioned that it was Circle 42, I would never have found it. I tried looking through all of the constraints to find a radius constraint of zero, but couldn't see one. If any circle is missing a radius constraint wouldn't that come up as an error, or was the circles radius constrained by it's center?
I'm confused, any advice on how I would locate the zero radius circle on my own in the future would be greatly appreciated.
Shalmeneser
Post by Shalmeneser »
This sketch kills FC multiple time.
Suppress the 'point' at the right side.
construction-geometry-training_SHALMM.FCStd
(348.07 KiB) Downloaded 16 times
drmacro
Post by drmacro »
As it happens a point would not have caused the issue, but, as noted a 0 radius circle does.
I would reiterate what I and others said.
Doing this in a single sketch is WAY too complicated. Hundreds of constraints are too extremely tedious to create and difficult to maintain. And making a modification is bound to be a headache.
There are symmetries which also would lighten your work.
Shalmeneser
I'm such a noob trying to use Draft_PointLinkArray.
Part wb is not my best wb.
construction-geometry-training_SHALM2.FCStd
(198.79 KiB) Downloaded 11 times
code-surfer-dev
drmacro wrote: Tue Nov 29, 2022 11:37 pm There are symmetries which also would lighten your work.
Many thanks drmacro, I agree on using symmetries and will try that the next time I do something this complex.
Many thanks to everyone else for your feedback.
