Is there a way to disable the auto-rotate?
bhs67
Postby bhs67 » Tue Mar 24, 2015 4:57 pm
Sometimes the display starts to rotate on its own (don't know what sequence causes that). Is there a way to disable the auto-rotate?
NormandC
Re: Is there a way to disable the auto-rotate?
Postby NormandC » Tue Mar 24, 2015 5:05 pm
The only way this can happen is when you were just rotating the view and release the mouse button.
Go to Edit --> Preferences / Display / 3D View and uncheck "Enable animation". I believe it should fix it.
bhs67
Postby bhs67 » Tue Mar 24, 2015 6:54 pm
Thanks.
flachyjoe
Postby flachyjoe » Tue Mar 24, 2015 8:57 pm
Thanks too, I nightmared about this feature...
- Flachy Joe -
alias FFW @ irc.freenode.net #freecad et #freecad-fr
"Puisqu’on ne peut changer la direction du vent, il faut apprendre à orienter les voiles." Anonyme
OakLD
Postby OakLD » Tue Jan 30, 2018 11:01 am
Thanks for solution. If our heros developing FreeCAD made a reliable way to stop the auto-rotation, the feature could be OK. But it often times resist any attempts to stop it... So at the moment it's a bit of headache.
Regards,
Oak
Postby chrisb » Tue Jan 30, 2018 11:08 am
Which version are you talking about? I hope it's not 0.15 as the necrobumped thread might suggest.
OakLD
Postby OakLD » Tue Jan 30, 2018 1:22 pm
It's 0.16 / 6712. The Pan and Zoom do sometimes the same: Looks like you cannot end the command, but it also may be that in some circumstances it takes a lot of time to quit it... This happens on 2 different computers I used on Windows7 and 10. I had no chance to test it with OpenSUSE Linux I have on my other PC yet.
Regards,
Oak
bejant
Postby bejant » Wed Jan 31, 2018 8:35 pm
I use CAD navigation Style, and for me a right-click anywhere in the 3D view terminates Spinning.
OS: Ubuntu 16.04.3 LTS
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.16.6712 (Git)
Build type: None
Branch: releases/FreeCAD-0-16
Python version: 2.7.12
OCC version: 6.8.0.oce-0.17
