DXF export of sketch is incomplete
tom
Postby tom » Sun Mar 29, 2015 9:46 pm
first a big thank you to all developers for that great piece of software. I know that the software is still in an early development state. Nevertheless I used it for designing a cut-out sheet for a paperboard. I used the solver of the sketcher in order to get some computational support while designing the outline of the paperboard. I could finish that task successfully. Next I wanted to export the sketch to DXF so that the paperboard manufacturer can use it. So, I selected the sketch and pressed File / Export. Unfortunately the resulting DXF is incomplete. It contains only a few lines.
Then I tried another way: I converted the sketch into draft objects and then exported the draft objects to DXF. I got exactly the same result.
Can you tell me what is going wrong here?
Regards,
Thomas
OS: Mac OS X
Version: 0.16.4712 (Git)
Hash: 7e21806c210fccf78158ba9f2abe5fa1c985fe53
Python version: 2.7.9
Qt version: 4.8.6
Coin version: 3.1.3
OCC version: 6.8.0.oce-0.17
inlay.dxf
(1.65 KiB) Downloaded 35 times
inlay.FCStd
(12.95 KiB) Downloaded 16 times
bejant
Re: DXF export of sketch is incomplete
Postby bejant » Mon Mar 30, 2015 4:38 am
Greetings tom and welcome here.
tom wrote:exported the draft objects to DXF. I got exactly the same result.
I'm sorry but I can't tell you any more than you already know about this. There's an export problem; I get the same result you did and much of the left side geometry failed to export for me as well.
For the dev's, here's a cut and paste from the report view of the error message I get when exporting to .dxf:
  File "<string>", line 4, in <module>
<type 'exceptions.TypeError'>: Export of this object type is not supported by Drawing module
Stack Trace: Traceback (most recent call last):
OS: Ubuntu 14.04.2 LTS
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.16.4701 (Git)
Hash: f6d50e6f33d71a533d18707aa3d74d0d45a5fc28
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.7.1
NormandC
Postby NormandC » Mon Mar 30, 2015 4:54 am
Hello Thomas,
I'm not sure why exporting your Sketch is problematic, but here's a method that worked for me: select the Sketch then use Image Draft Downgrade to downgrade it into primitive edges. Then select all, and export to DXF.
Be advised that this process destroys your sketch, so you might want to make a copy of the sketch, then downgrade the copy.
Also, the construction lines will not be downgraded, nor will they be exported.
Version: 0.16.4706 (Git)
Hash: 5d9b7a4e03496c0d854951eebad45bd6542ed3fc
Qt version: 4.8.6
OCC version: 6.7.1
inlay2.dxf
(5.39 KiB) Downloaded 36 times
tom
Postby tom » Mon Mar 30, 2015 4:34 pm
Thank you NormandC. Your proposed work-around worked for me too.
