please verify: FreeCAD crashes when applying thickness
Postby chrisb » Thu Apr 02, 2015 9:33 am
FreeCAD crashes when applying thickness to the selected surface of a lofted part. Could someone please verify, just to make sure it is not my system.
To reproduce: open the attached file, select part workbench, select the surface and click the thickness icon.
OS: Ubuntu 14.04.2 LTS
Version: 0.16.4733 (Git)
Hash: 5b27b3194e7c03b5f58f033e9803dde6452bb044
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
errorThickness.FCStd
(5.74 KiB) Downloaded 103 times
DeepSOIC
Re: please verify: FreeCAD crashes when applying thickness
Postby DeepSOIC » Thu Apr 02, 2015 9:41 am
I get a soft crash on:
OS: Windows 8.1
Version: 0.15.4654 +27 (Git)
Branch: testing_touch+unlim+sketchfix
Hash: 9c600991340904aadab91a7a79a735f4091c88b0
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.7.1
shoogen
Postby shoogen » Thu Apr 02, 2015 9:45 am
I get a BRepAlgo_Image::Bind exception on
OS: Debian GNU/Linux 7.8 (wheezy)
Version: 0.16.4739 +354 (Git)
Branch: danfalck/path-module,dev-skiprecompute,dev-fuzzyboolean
Hash: 5fc6e36803a85b9f875cf9092af3c219ad57025a
Python version: 2.7.3
Qt version: 4.8.2
OCC version: 6.8.1.dev-c1e0171
mario52
Postby mario52 » Thu Apr 02, 2015 7:16 pm
hi
no crash but
ACCESS VIOLATION at adress 0xFEFD0000 during 'READ' operation
OS: Windows Vista
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.15.4664 (Git)
Hash: 4e41e535ff01d39b650add123f42629e1a8d6b05
Qt version: 4.8.6
OCC version: 6.7.1
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Dialog creation. My macros on Gist.github.
PrzemoF
Postby PrzemoF » Thu Apr 02, 2015 8:29 pm
Fedora linux, hard crash.
backtrace: http://www.pasteall.org/57628
OS: Linux
Version: 0.16.4740 +6 (Git)
Branch: fem <- not from the main tree
Hash: XXXXXXXXXXXXXXXXXXX <- not from the main tree
Qt version: 4.8.6
Coin version: 3.1.3
shoogen
Postby shoogen » Fri Apr 03, 2015 8:41 am
color=#BFFFBF is barely distinguishable from the background of the default color scheme.
PrzemoF wrote:Branch: fem <- not from the main tree
The question is if the branch is publicly available. A capable developer will use "git diff --stat" to check if relevant files had been changed.
PrzemoF
Postby PrzemoF » Fri Apr 03, 2015 9:47 am
I wanted to "hide" that info to avoid distraction and that branch is not publicly available. I tested the crash on my private, dirty devel branch.
shoogen
Postby shoogen » Fri Apr 03, 2015 9:58 am
OCE 0.9.1 from debian wheezy outputs:
An exception was caught 0xb5f47ebc : Standard_NullObject: Attempt to access to null object
** Exception ** 0xb5f47ebc : Standard_NullObject: Attempt to access to null object
In comparrsion to
ERROR. offsetperform operation not done.
in Open CASCADE Technology 6.8.1.dev-2230d1b
Postby chrisb » Fri Apr 03, 2015 6:09 pm
So it actually seems to be an error and I should create a bug report?
Chris
Postby Kunda1 » Mon Jan 23, 2017 9:49 pm
soft bump for ticket issue #2041
