please verify: FreeCAD crashes when applying thickness
Re: please verify: FreeCAD crashes when applying thickness
Postby chrisb » Mon Jan 23, 2017 11:10 pm
Not crashing in 0.17. It shows an alert instead:
BRepAlgo_Image::Bind.
OS: Mac OS X
Version: 0.17.9586 (Git)
Branch: (detached from 0e2cf2e)
Hash: 0e2cf2ebcaaa50723de608cf030af740cb6ad548
Python version: 2.7.13
Coin version: 3.1.3
OCC version: 7.0.0
bejant
Postby bejant » Tue Jan 24, 2017 1:10 am
chrisb wrote:Not crashing in 0.17. It shows an alert instead:
OS: Mac OS X
I got a crash too and wasn't going to reply until I read that you got an alert instead.
Faces 5 and 6 are made from the Sketches, so applying the Thickness tool to those faces results in success. Applying Thickness to faces 1 through 4 causes FreeCAD to blink out of existence. I suspect that because Loft never produces planar faces between Sketches this is an OCC problem, but if it is a known FreeCAD problem then FreeCAD should contain the error without a crash.
OS: Ubuntu 16.04.1 LTS
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.17.9747 (Git)
Build type: None
Hash: f5c0f579cbd7ce668727f8835946e4e9abc0eec6
Python version: 2.7.12
OCC version: 6.8.0.oce-0.17
Postby chrisb » Tue Jan 24, 2017 3:15 pm
On my Linux box I get a crash as well, same FreeCAD version as your's.
Postby Kunda1 » Tue Jan 24, 2017 3:26 pm
OS: Mac OS X
Build type: None
chrisb wrote:On my Linux box I get a crash as well, same FreeCAD version as your's.
Guys I think the point is to test this with OCC 7.0 right?
bejant
Postby bejant » Tue Jan 24, 2017 5:51 pm
Yes.
NormandC
Postby NormandC » Wed Jan 25, 2017 3:32 am
We really, really need to get OCCT 7 in the daily PPA. :(
user1234
Postby user1234 » Thu Jan 26, 2017 12:41 am
I got an errormessage like other users:
or the CPU works forever.
But when i make a a surface with the shapebinder and make a Pad, it makes the offset in one direction and in the other direction it goes - rectangular to the sketch - to the BodyOrigin Plane:
Or when i make a a surface with the shapebinder and make a Offset with the option "Fill == true" it makes the offset right:
Btw. When i fuse both, it makes a correct shape.
But in both workarounds it have no tangenty joins with the boundarysurfaceses (is this spelled right?). And i think this the problem by the thinknessoperation:
My machine:
OS: Debian GNU/Linux 8.7 (jessie)
Version: 0.17.9797 (Git)
Build type: Unknown
Hash: 9a6191f5726d6588c650ffab4c65fdfb835bc2da
Python version: 2.7.9
Qt version: 4.8.6
OCC version: 7.1.0
I hope, this helped.
sgrogan
Postby sgrogan » Thu Jan 26, 2017 1:33 am
NormandC wrote:We really, really need to get OCCT 7 in the daily PPA. :(
We need a hero, I'm both skill and time challenged. I think I captured gdo35's work here: https://git.launchpad.net/~freecad-main ... -packaging
I'd contribute to a crowd funding/bounty effort, but I don't think I can do it.
Postby Kunda1 » Fri Mar 24, 2017 3:04 pm
Any OCC 7.1 testers available?
NormandC
Postby NormandC » Sat Mar 25, 2017 5:15 am
That's odd. Using freecad-daily with OCCT 7.1.0, no crash and no error: the Thickness completes, but the result is unchanged from the Loft (no shelling operation is done). Part Check geometry reports the solid as invalid.
OS: Ubuntu 16.04.2 LTS
Version: 0.17.10611 (Git)
Build type: None
Hash: 44a9ecd25f27ec3efe52c9de9c95ef2b3e19dd17
OCC version: 7.1.0
