Problem Sweep
mario52
Problem Sweep
Post by mario52 »
hi
I would like to know if this is normal behavior
A = with a tilted rectangle rotated 30 degrees in the X-axis
B = with a tilted rectangle rotated 90 degrees in the X-axis
the behavior is different
Sweep00.FCStd
(80.65 KiB) Downloaded 36 times
thanks
mario
shoogen
Re: Problem Sweep
Post by shoogen »
mario52
Re: Problem Sweep
Post by mario52 »
hi
thank you for the answer
I use the method of wmayer viewtopic.php?f=3&t=3186&p=25040&hilit=Spine#p25040 ,
how can I adapt the macro ?
                ###create sweep
                # http://forum.freecadweb.org/viewtopic.php?f=3&t=3186&p=25040&hilit=Spine#p25040
                sweepKnurlingD            = App.activeDocument().addObject('Part::Sweep','SweepKnurlingD')
                sweepKnurlingD.Sections   = [dentKnurling]           # object
                sweepKnurlingD.Spine      = HelixG                   # trajectory
                sweepKnurlingD.Solid      = True
                sweepKnurlingD.Frenet     = True
                sweepKnurlingD.Transition = 2                        # number objects
                sweepKnurlingD.Label = "SweepKnurlingD"
mario
