Stretching shapes
JR
Stretching shapes
Post by JR »
I would like to make a shape that is a circle in the bottom and an ellipse on the top. I thought of making it by making a cylinder and then stretching one of its faces in one direction, but I don't seem to find that option. How would you use FreeCAD to make this shape? Thanks very much in advance. JR
Founder
Re: Stretching shapes
Post by wmayer »
With the GUI you currently can't do it but it's possible via Python scripting. Here is the code snippet you can use:
import Part
from FreeCAD import Base
c=Part.makeCircle(5.0,Base.Vector(0,0,0))
e=Part.makeCircle(5.0,Base.Vector(0,0,10))
m=Base.Matrix()
m.A11=2.0
e=e.transformGeometry(m)
cw=Part.Wire(c)
ew=Part.Wire(e)
l=Part.makeLoft([cw,ew])
Part.show(l)
As you can see the trick to make an ellipse is by stretching a circle and to make the surface is done by makeLoft().
JR
Post by JR »
wmayer,
Thank you very much. How do I make this surface into a filled solid? I tried for a bit using the makeSolid command from the Part API (http://sourceforge.net/apps/mediawiki/f ... e=Part_API) but I wasn't able to get it.
JR
Founder
Post by wmayer »
import Part
m=Base.Matrix()
m.A11=2.0
bot=Part.Face(Part.Wire(c))
top=Part.Face(Part.Wire(e))
top=Part.Face(top.transformGeometry(m))
cw=Part.Wire(c)
ew=Part.Wire(e)
shell=Part.Shell(l.Faces)
shell.add(top)
shell.add(bot)
solid=Part.Solid(shell)
Part.show(solid)
Founder
Post by wmayer »
The loft function of our cad kernel also offers a parameter to build directly a solid. So, I have now added an optional parameter (default: False) to makeLoft() to create directly the solid. This change will be available with the next release, then.
JR
Post by JR »
Excellent, thank you very much. Thanks for the feature addition too.
NormandC
Post by NormandC »
wmayer wrote:I have now added an optional parameter (default: False) to makeLoft() to create directly the solid. This change will be available with the next release, then.
Hi Werner,
How do we set the parameter to true in Python to create the solid directly?
Thanks!
jr22
Post by jr22 »
wmayer,
The solid you made from the stretched circle and the normal circle works pretty well when trying to apply boolean operations (cut, fuse, common, ...etc.). I tried my own version of that, trying to make a solid between a circle and a rectangle, and while it looks pretty swell, it will not work for boolean operations, so there must be something wrong with it. Is there something I am missing? Or I am just asking the loft/solid commands too much? Thank you very much. Here is my version of your code:
import Part
# make a circle and a rectangle
e=Part.makePolygon([Base.Vector(-8,-2,-8),Base.Vector(8,-2,-8),Base.Vector(8,2,-8),Base.Vector(-8,2,-8),Base.Vector(-8,-2,-8)])
# make shapes into wires
cw=Part.Wire(c)
ew=Part.Wire(e)
# make faces from wires
bot=Part.Face(cw)
top=Part.Face(ew)
# make loft
# make shell from loft's faces
# add top and bottom to make closed shell
shell.add(top)
shell.add(bot)
# make into a solid and close
Part.show(solid)
Founder
Post by wmayer »
Hi Werner,
Thanks!
import Part
m=Base.Matrix()
m.A11=2.0
cw=Part.Wire(c)
ew=Part.Wire(e)
l=Part.makeLoft([cw,ew],True) ## <<<============
Part.show(solid)
Founder
Post by wmayer »
Indeed your shape is broken. When selecting the object and setting "Lightning" to "One side" in the property editor you'll see that your shape is inverted, i.e. it has the wrong orientation and thus appears black. Since boolean operations must rely on a proper orientation it will (often) fail if it's incorrect. To fix this just call this additional line:
solid.reverse()
Nevertheless, IMO boolean operations is still one of the weakest points of the actually great OCC kernel. It is a constant point of trouble where it often fails with rather simple models.
