Freecad locls up on invocation
frecd
Postby frecd » Sun May 24, 2015 12:49 pm
Howdy;
Whether I click on the menu/panel icon, Freecad comes up, but locks up within seconds. Clicking on a menu item locks it up sooner. This also happens when I type it in a terminal window. It's happeniing whether its the stable, or the daily version, too. This tells me there may be a missing dependency, but I can't really say for sure. When I type it into a terminal, I get:
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2015
QInotifyFileSystemWatcherEngine::addPaths: inotify_add_watch failed: No such file or directory
This is on 64 bit Kubuntu 12.04.
Bill
frecd
Re: Freecad locls up on invocation
Postby frecd » Sun May 24, 2015 6:09 pm
Well I'll be dipped in *bleep*, it just up and finally started working.
OS: Kubuntu 12.04.5 LTS
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.16.4928 (Git)
Hash: d8f63bcfd10301f3d1e141cced4370f0782238d0
Python version: 2.7.3
Qt version: 4.8.1
Coin version: 3.1.3
OCC version: 6.8.0.oce-0.17
frecd
Postby frecd » Mon May 25, 2015 2:01 am
And now it's locking up again. This is just weird.
Bill
quick61
Postby quick61 » Mon May 25, 2015 2:12 am
Hi Bill, can you run it with gdb and provide the backtrace from it? That might help provide more of a clue as to what is going on.
Mark
frecd
Postby frecd » Mon May 25, 2015 5:48 am
I've never played with gdp, what do I do with it? Many hours ago I started Freecad and left it up, even though, again, locked up. Looking at it now, it seems to be working again. __STRANGE__.
quick61
Postby quick61 » Mon May 25, 2015 7:28 am
frecd wrote:I've never played with gdp, what do I do with it? Many hours ago I started Freecad and left it up, even though, again, locked up. Looking at it now, it seems to be working again. __STRANGE__.
http://www.gnu.org/software/gdb/
You can install it with -
sudo apt-get install gdb
Then from the command line type gdb FreeCAD, and after gdb starts type run. FreeCAD will start and run as usual and if/when a crash happens, type bt for the backtrace output.
But if it's not crashing and just taking a coons age to start, maybe try renaming your ./FreeCAD/system.cfg file in your home directory, (or moving it / deleting it), and start FreeCAD again and see it that helps. A new system.cfg file will be created with all the default settings.
Mark
frecd
Postby frecd » Tue May 26, 2015 1:29 am
Ok, here's the results.
# gdb freecad
GNU gdb (Ubuntu/Linaro 7.4-2012.04-0ubuntu2.1) 7.4-2012.04
Copyright (C) 2012 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "i686-linux-gnu".
For bug reporting instructions, please see:
<http://bugs.launchpad.net/gdb-linaro/>...
Reading symbols from /usr/bin/freecad...(no debugging symbols found)...done.
(gdb) run
Starting program: /usr/bin/freecad
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/i386-linux-gnu/libthread_db.so.1".
File "/usr/lib/debug/usr/lib/i386-linux-gnu/libstdc++.so.6.0.16-gdb.py", line 62, in <module>
from libstdcxx.v6.printers import register_libstdcxx_printers
ImportError: No module named libstdcxx.v6.printers
FreeCAD 0.16, Libs: 0.16R4928 (Git)
[New Thread 0xadf00b40 (LWP 7158)]
[New Thread 0xad6ffb40 (LWP 7159)]
[New Thread 0xacefeb40 (LWP 7160)]
[New Thread 0xac6fdb40 (LWP 7161)]
[New Thread 0xabefcb40 (LWP 7162)]
[New Thread 0xab6fbb40 (LWP 7163)]
[New Thread 0xaaefab40 (LWP 7164)]
[New Thread 0xaa6f9b40 (LWP 7165)]
[New Thread 0xa92b9b40 (LWP 7166)]
[New Thread 0xa793fb40 (LWP 7167)]
[New Thread 0xa701eb40 (LWP 7168)]
[New Thread 0xa59d7b40 (LWP 7169)]
[New Thread 0xa4fffb40 (LWP 7170)]
[New Thread 0xa45ffb40 (LWP 7171)]
[Thread 0xa45ffb40 (LWP 7171) exited]
[Thread 0xa4fffb40 (LWP 7170) exited]
[New Thread 0xa4fffb40 (LWP 7175)]
bt
[Thread 0xaaefab40 (LWP 7164) exited]
[Thread 0xa793fb40 (LWP 7167) exited]
[Thread 0xabefcb40 (LWP 7162) exited]
[Thread 0xac6fdb40 (LWP 7161) exited]
[Thread 0xacefeb40 (LWP 7160) exited]
[Thread 0xad6ffb40 (LWP 7159) exited]
[Thread 0xadf00b40 (LWP 7158) exited]
[Thread 0xa4fffb40 (LWP 7175) exited]
[Thread 0xa59d7b40 (LWP 7169) exited]
[Thread 0xa92b9b40 (LWP 7166) exited]
[Thread 0xaa6f9b40 (LWP 7165) exited]
[Thread 0xab6fbb40 (LWP 7163) exited]
[Thread 0xb168a740 (LWP 7147) exited]
Program terminated with signal SIGKILL, Killed.
The program no longer exists.
(gdb) bt
No stack.
Something to also be noted: In a previous post in this thread, I had managed to get it working enough to get the, "about freecad", thing working enough to get the info into the clipboard. It says I'm running a 32 bit version, on a 32 bit OS. It just happens that this is a 64 bit machine with quad processors, running the 64 bit version of the OS. Something is grossly out of kilter here.
Also, (two tries), no new system.cfg file.
Bill
bejant
Postby bejant » Tue May 26, 2015 2:04 am
Hi Bill, this post might help, it's about a standalone (portable) FreeCAD version:
viewtopic.php?f=4&t=10133&start=10#p85164
frecd
Postby frecd » Tue May 26, 2015 3:02 am
Is that a windows version? I'm running linux.
Bill
bejant
Postby bejant » Tue May 26, 2015 11:59 am
My apologies, Bill, I posted in the wrong topic...
