DXF export has flipped arc's even with recent PPA
jpieper
Postby jpieper » Sat Jun 06, 2015 7:00 pm
I have a sheet metal part, that when exported to DXF, has a random subset of 180 degree circular arcs flipped. I've found a number of references to this problem in the past, each of which has had some kind of fix applied. I don't know if this is exactly a regression or some new problem. The dxf stuff is set to auto-download in the Draft preferences, and has a timestamp of today, 2015-06-06, in my .FreeCAD directory.
Am I doing something wrong, or is there a workaround I can use?
Previous bugs describing a seemingly identical issue all of which are documented as being fixed.
* http://www.freecadweb.org/tracker/view.php?id=1653
* http://www.freecadweb.org/tracker/view.php?id=1590
* http://www.freecadweb.org/tracker/view.php?id=1513
OS: Ubuntu 14.04.2 LTS
Version: 0.16.4928 (Git)
Hash: d8f63bcfd10301f3d1e141cced4370f0782238d0
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
gimbal_bracket.dxf
(7.67 KiB) Downloaded 19 times
gimbal_bracket.fcstd
(141.85 KiB) Downloaded 17 times
triplus
Re: DXF export has flipped arc's even with recent PPA
Postby triplus » Sat Jun 06, 2015 9:53 pm
As for fixing this probably Yorik will take a look. As for workaround you can still use workaround i mentioned in issue report.
  • Select Shape2DView object in Tree View and use Draft Downgrade tool on it.
  • Select all edges and use Draft Convert to Sketch tool.
  • Part Design -> Part Design -> Merge sketches tool
Try to export that crated sketch to DXF. Probably 4 horizontal lines should be removed first for DXF export and 4 vertical ones will need to be repaired as it looks like are lost at conversion.
yorik
Site Admin
Postby yorik » Sun Jun 07, 2015 8:37 pm
This is a recurrent problem... Fir some reason I never manage to fix it completely...
Another workaround is to separate everything into single edges with the Draft Downgrade tool.
triplus
Postby triplus » Sun Jun 07, 2015 8:47 pm
yorik wrote:This is a recurrent problem... Fir some reason I never manage to fix it completely...
Sometimes this does work but often the conversion to sketcher geometry fixes it. For example only using Draft Downgrade tool on Shape2DView object won't fix the issue in attached file. I was thinking what could be that difference involved that would affect DXF library in a way it flips Draft Arc in one direction and then again the same converted Draft Arc to Sketcher geometry in the other direction? Is there any additional check involved or what could be the cause? Does sketcher geometry (arc) have any additional info DXF library (or something else affecting DXF library) does use? I am not sure sketcher is "perfect" as in the past if i remember correctly i did get flipped arcs (sketcher geometry) but usually this is how i "workaround" the issue. Or is this more or less a question of "luck" and sometimes one method works and then again the other one?
cox
Postby cox » Mon Jun 08, 2015 6:50 am
I know the path module is not ready for testing, but might this shed som light on some common library having a problem.
Flipping seams random and resizing the pocket has in many occasions flipped the circles the correct way
OS: "Arch Linux"
Version: 0.16.5465 (Git)
Build type: Unknown
Branch: makepkg
Hash: 347fe6217111569866fd83a4796d3d65e4e75dfe
Python version: 2.7.10
Coin version: 3.1.3
OCC version: 6.9.0
yorik
Site Admin
Postby yorik » Tue Jun 09, 2015 3:49 pm
oh no, inverted arcs in Path too!!!! :cry:
f3nix
Postby f3nix » Wed Jun 10, 2015 5:36 pm
Hi!
I'm having the same problem:
OS: Debian GNU/Linux 8.1 (jessie)
Version: 0.16.5070 (Git)
Build type: Unknown
Hash: 418cefd7ee4d02d584c5a871f07104683606787b
Python version: 2.7.9
Qt version: 4.8.6
OCC version: 6.9.0
Cheers,
Mateusz
frame-xz.FCStd
(113.35 KiB) Downloaded 13 times
ickby
Postby ickby » Wed Jun 10, 2015 7:03 pm
Yorik, is there somewhere a collection of all files which have shown this inverted arc problem?
cox
Postby cox » Wed Jun 10, 2015 7:35 pm
Just a thought, could this be a variable type (signed / unsigned) problem.
Looks like there could be a 50-50 chance of having the arcs invert
f3nix
Postby f3nix » Wed Jun 10, 2015 8:12 pm
I've tested the export in:
Word size: 64-bit
Version: 0.14.3702 (Git)
Branch: releases/FreeCAD-0-14
Hash: b3368125c63289ec8ce9faec2b2ae4c78d436406
Python version: 2.7.8
Qt version: 4.8.6
SoQt version: 1.6.0a
OCC version: 6.7.0
And the arcs are ok.
Cheers,
Mateusz
