Sheet Metal Workbench
shaise
Re: Sheet Metal Workbench
Postby shaise » Sat Jul 25, 2020 11:46 am
The tree system is the old freecad system. If you start an object outside a body (like in part workbench) it will be in a tree.
easyw-fc
Postby easyw-fc » Tue Sep 01, 2020 8:15 am
shaise wrote: ping
jaisejames wrote: ping
Hi, I'm trying to use the SM WB with the miter angle function, but it seems it is not working anymore...
a test file:
bend-mitered-not-working.FCStd
(14.17 KiB) Downloaded 11 times
my SMWB version: 0.2.43
and my FC version:
OS: Windows 10 (10.0)
Version: 0.19.22284 (Git)
Hash: bf1e8e48389f5e9e25bd77b67fe98da4213e797c
Python version: 3.6.8
Qt version: 5.12.1
Postby chrisb » Tue Sep 01, 2020 8:34 am
easyw-fc
Postby easyw-fc » Tue Sep 01, 2020 9:16 am
The linked solution is only a workaround for a function that is now broken but it was working before...
even more the miterangle are available in the bend, but it doesn't affect the result
Here an old release that is working correctly:
An old GH release that is working:
SheetMetal-GitHub on Sep 4, 2018
and a more recent one:
SheetMetal-GitHub on May 15, 2019
Postby chrisb » Tue Sep 01, 2020 11:26 am
You are right, I may better have linked from the other post to this topic.
jaisejames
Postby jaisejames » Thu Sep 03, 2020 11:39 am
shaise wrote: ping
a test file:
and my FC version:
Qt version: 5.12.1
Set automiter to false to add mitre angle manually.
easyw-fc
Postby easyw-fc » Fri Sep 04, 2020 10:35 am
:oops: sorry ... I missed that option :)
thanks a lot :D
C_Adrian
Half circle pad unfold with sheet metal v0.2.31
Postby C_Adrian » Thu Oct 08, 2020 11:31 pm
Hello, I just can't unfold this simple project.
Please suggest a workaround.
circle_line.FCStd
(21.79 KiB) Downloaded 16 times
papyblaise
Re: Half circle pad unfold with sheet metal v0.2.31
Postby papyblaise » Fri Oct 09, 2020 7:14 am
inded I constat that , i can't unfold a half moon :?:
C_Adrian
Postby C_Adrian » Fri Oct 09, 2020 11:11 am
I saw that by adding a second line trim I can do the unfold.
I use Freecad 0.18 on MAC 10.13.
2 cuts.jpeg (81.25 KiB) Viewed 262 times
circle two cuts.FCStd
(23.98 KiB) Downloaded 6 times
