Sheet Metal Workbench
Re: Sheet Metal Workbench
new feature added
Corner relief feature
https://github.com/shaise/FreeCAD_SheetMetal/pull/147
select two of edges of a face where corner relief required select relief to create the feature.
then adjust other parameters Limitation : size should greater than corner to neutral radius size
Testing required.
Testing required.
Awesome!
Great feature jaisejames!
I have no time to test it, if people here can do some tests, I will then merge it. (at least test if nothing else is broken)
Thanks a lot for this great feature!
Works fine for me, I was not able to get any error while modeling or modifying those test models:
OS: Debian GNU/Linux 10 (buster) (LXDE/LXDE-pi)
Version: 0.19.23069 (Git)
Build type: Unknown
Hash: 20649ec5292a31279f5593eccee2c5cd106bb099
Python version: 3.7.3
Qt version: 5.11.3
Locale: French/France (fr_FR)
Build type: Unknown
Qt version: 5.11.3
Disclaimer: comments here are related to FreeCAD Linkstage3 branch of @realthunder.
Those above test parts doesn't unfold in Linkstage3 branch of FC.
CornerRelief feature works fine, but unfolding fails with warning
Tests performed on both parts above in previous post (recomputation for FC_link migration accepted).
Same error on a similar part modeled from scratch with FC_link.
Thanks for your attention.
Version: 0.19.25935 (Git)
Build type: Unknown
Branch: LinkStage3
Hash: a491be7f04516e65647d77ceb2547fbd0adac1df
Qt version: 5.11.3
JFYIrealthunder wrote:ping
and error:Unfold is failing.
Please try to select a different face to unfold your object
18:55:36 Engineering mode is not enabled.
18:55:39 Manual K-factor is being used: 0.40 (din)
18:55:39 15StdFail_NotDone BRep_API: command not done
18:55:39 exception at line 2876('15StdFail_NotDone BRep_API: command not done',)
18:55:39 ('15StdFail_NotDone BRep_API: command not done',)
18:55:39 Traceback (most recent call last):
18:55:39 File "/home/pi/.FreeCAD/Mod/sheetmetal/SheetMetalUnfolder.py", line 1688, in unbendFace
theFace = Part.Face(myWire)
18:55:39 Part.OCCError: Failed to create face from wire
18:55:39
During handling of the above exception, another exception occurred:
18:55:40 Traceback (most recent call last):
18:55:40 File "/home/pi/.FreeCAD/Mod/sheetmetal/SheetMetalUnfolder.py", line 2876, in accept
s, foldComp, norm, thename, err_cd, fSel, obN = getUnfold(k_factor_lookup)
18:55:40 File "/home/pi/.FreeCAD/Mod/sheetmetal/SheetMetalUnfolder.py", line 2180, in getUnfold
theFaceList, foldLines = TheTree.unfold_tree2(TheTree.root) # traverses the tree-structure
18:55:40 File "/home/pi/.FreeCAD/Mod/sheetmetal/SheetMetalUnfolder.py", line 2049, in unfold_tree2
shell, foldLines = self.unfold_tree2(n_node)
18:55:40 File "/home/pi/.FreeCAD/Mod/sheetmetal/SheetMetalUnfolder.py", line 2062, in unfold_tree2
nodeShell, nodeFoldLines = self.generateBendShell2(node)
18:55:40 File "/home/pi/.FreeCAD/Mod/sheetmetal/SheetMetalUnfolder.py", line 1938, in generateBendShell2
bFace = self.unbendFace(i, bend_node, nullVec)
18:55:40 File "/home/pi/.FreeCAD/Mod/sheetmetal/SheetMetalUnfolder.py", line 1699, in unbendFace
theFace = Part.makeFilledFace(thirdWireList)
18:55:40 Part.OCCError: 15StdFail_NotDone BRep_API: command not done
18:55:40
Build type: Unknown
Branch: LinkStage3
Qt version: 5.11.3
I have just made a new release. Fixed a few problems related to this. I also found out a more reliable way solve this face orientation problem. With this PR, sheetmetal can now unfold your previous offset shape with hole.
wow thank you very much, can't wait to try thisrealthunder wrote: ↑Wed Dec 02, 2020 2:11 pm Fixed a few problems related to this. I also found out a more reliable way solve this face orientation problem. With this PR, sheetmetal can now unfold your previous offset shape with hole.
I've sync ur branch, now it's compiling, then upgrade sheetmetal WB, then I'll report here.
Edit: test done but unfolding still fails. Something is broken for me, on both master and Linkstage3 branches
I synchronized your branch:
Version: 0.19.25950 (Git)
Build type: Unknown
Branch: LinkStage3
Hash: f45215c049a756a8d5f072535eafbb308113f2b1
Qt version: 5.11.3
I've updated sheetmetal WB with SheetMetalUnfolder.py file up to date:
While unfolding this part: I get following warnings and error:
Analysis: Type of surface not supported for sheet metal parts
Unfold is failing.
01:07:30 Manual K-factor is being used: 0.30 (din)
01:07:30 got error code: 17 at Face23
01:07:30 Error Analysis: Type of surface not supported for sheet metal parts at Face23
01:07:49 exception at line 2872("'NoneType' object has no attribute 'Edges'",)
01:07:49 ("'NoneType' object has no attribute 'Edges'",)
01:07:49 Traceback (most recent call last):
01:07:49 File "/home/pi/.FreeCAD/Mod/sheetmetal/SheetMetalUnfolder.py", line 2872, in accept
foldLines = foldComp.Edges
01:07:49 AttributeError: 'NoneType' object has no attribute 'Edges'
01:07:49
01:23:06 Manual K-factor is being used: 0.30 (din)
01:23:06 got error code: 17 at Face11
01:23:06 Error Analysis: Type of surface not supported for sheet metal parts at Face11
01:23:09 exception at line 2872("'NoneType' object has no attribute 'Edges'",)
01:23:09 ("'NoneType' object has no attribute 'Edges'",)
01:23:09 Traceback (most recent call last):
01:23:09 File "/home/pi/.FreeCAD/Mod/sheetmetal/SheetMetalUnfolder.py", line 2872, in accept
01:23:09 AttributeError: 'NoneType' object has no attribute 'Edges'
01:23:09
On master branch:
Build type: Unknown
Qt version: 5.11.3
While unfolding none native SMWB part I get following warnings and error:
Unfold is failing.
01:14:58 Manual K-factor is being used: 0.30 (din)
01:14:58 exception at line 2871('list indices must be integers or slices, not NoneType',)
01:14:58 ('list indices must be integers or slices, not NoneType',)
01:14:58 Traceback (most recent call last):
01:14:58 File "/home/pi/.FreeCAD/Mod/sheetmetal/SheetMetalUnfolder.py", line 2871, in accept
01:14:58 File "/home/pi/.FreeCAD/Mod/sheetmetal/SheetMetalUnfolder.py", line 2169, in getUnfold
TheTree.Bend_analysis(f_number, None) # traverses the shape and builds the tree-structure
01:14:58 File "/home/pi/.FreeCAD/Mod/sheetmetal/SheetMetalUnfolder.py", line 1324, in Bend_analysis
self.Bend_analysis(child_info[0], t_node, child_info[1])
01:14:58 [Previous line repeated 1 more time]
01:14:58 File "/home/pi/.FreeCAD/Mod/sheetmetal/SheetMetalUnfolder.py", line 1315, in Bend_analysis
t_node = self.make_new_face_node(face_idx, parent_node, parent_edge, wires_edge_lists)
01:14:58 File "/home/pi/.FreeCAD/Mod/sheetmetal/SheetMetalUnfolder.py", line 1098, in make_new_face_node
oppVertIndexes = range(len(self.__Shape.Faces[newNode.c_face_idx].Vertexes))
01:14:58 TypeError: list indices must be integers or slices, not NoneType
01:14:58
While unfolding native SMWB part I get following warnings and error:
Unfold is failing.
01:18:04 Manual K-factor is being used: 0.30 (din)
01:18:04 exception at line 2871("'SheetTree' object has no attribute '_SheetTree__thickness'",)
01:18:04 ("'SheetTree' object has no attribute '_SheetTree__thickness'",)
01:18:04 Traceback (most recent call last):
01:18:04 File "/home/pi/.FreeCAD/Mod/sheetmetal/SheetMetalUnfolder.py", line 2871, in accept
01:18:04 File "/home/pi/.FreeCAD/Mod/sheetmetal/SheetMetalUnfolder.py", line 2167, in getUnfold
TheTree = SheetTree(o.Object.Shape, f_number, k_factor_lookup) # initializes the tree-structure
01:18:04 File "/home/pi/.FreeCAD/Mod/sheetmetal/SheetMetalUnfolder.py", line 523, in __init__
if (self.__thickness < estimated_thickness) or (self.__thickness > 1.9 * estimated_thickness):
01:18:04 AttributeError: 'SheetTree' object has no attribute '_SheetTree__thickness'
01:18:04
Thank you for your attention and your efforts, hope you can fix it.
Wall extrude improved
https://github.com/shaise/FreeCAD_SheetMetal/pull/150
* added extrude with sketch.
* extrude if intersect we can cut it with a offset. Testing needed.
Great new features!!!
Thank you for this feature
Works fine here (except to unfold sometimes, but that's another issue, see next post):
Just 2 comments:
- if the extend doesn't intersect the full thickness of the sheetmetal wall then the offset subtraction doesn't cut throught all the wall, then the unfold fails.
- the cut is colinear with the extend, so if the extend is not perpendicular to the intersected wall the cut is not normal to the sheetmetal neither.
Anyway, that's not a big deal. This feature is convenient as is.
Thank you again!
Build type: Unknown
Qt version: 5.11.3
