Sheet Metal Workbench
drmacro
Re: Sheet Metal Workbench
Postby drmacro » Mon Feb 17, 2020 1:40 pm
Any idea what this means when attempting unfold:
exception at line 2838("local variable 'nodeFace' referenced before assignment",)
  File "/home/mac/.FreeCAD/Mod/sheetmetal/SheetMetalUnfolder.py", line 2838, in accept
    s, foldComp, norm, thename, err_cd, fSel, obN  = getUnfold(k_factor_lookup)
  File "/home/mac/.FreeCAD/Mod/sheetmetal/SheetMetalUnfolder.py", line 2168, in getUnfold
    TheTree.Bend_analysis(f_number, None) # traverses the shape and builds the tree-structure
  File "/home/mac/.FreeCAD/Mod/sheetmetal/SheetMetalUnfolder.py", line 1315, in Bend_analysis
    t_node = self.make_new_face_node(face_idx, parent_node, parent_edge, wires_edge_lists)
  File "/home/mac/.FreeCAD/Mod/sheetmetal/SheetMetalUnfolder.py", line 1276, in make_new_face_node
    self.get_node_faces(newNode, wires_e_lists)
  File "/home/mac/.FreeCAD/Mod/sheetmetal/SheetMetalUnfolder.py", line 564, in get_node_faces
    if not self.is_sheet_edge_face(theEdge, theNode):
  File "/home/mac/.FreeCAD/Mod/sheetmetal/SheetMetalUnfolder.py", line 617, in is_sheet_edge_face
    self.divideEdgeFace(i, ise_edge, F_vert, tree_node)
  File "/home/mac/.FreeCAD/Mod/sheetmetal/SheetMetalUnfolder.py", line 715, in divideEdgeFace
    nFace = self.cutEdgeFace(1, fIdx, ise_edge, tree_node)
  File "/home/mac/.FreeCAD/Mod/sheetmetal/SheetMetalUnfolder.py", line 861, in cutEdgeFace
    return nodeFace #, residueFace
UnboundLocalError: local variable 'nodeFace' referenced before assignment
Sheetmetal WB 0.2.32
OS: Ubuntu 19.10 (XFCE/ubuntustudio)
Version: 0.19.
Python version: 3.7.5
Qt version: 5.12.4
mocowania_fj_spaw.FCStd
(92.09 KiB) Downloaded 10 times
My beginners, written treatise: Learning FreeCAD
wandererfan
Postby wandererfan » Sat Feb 29, 2020 5:12 pm
Could use some sheet metal expertise in responding to a post in Announcements & Features. https://forum.freecadweb.org/viewtopic. ... 20#p373031
Thanks,
wf
papyblaise
Postby papyblaise » Sat Feb 29, 2020 6:10 pm
The probleme comme from the hole between the L and extend
Do "refine" before drill the hole
Postby Kunda1 » Sun Mar 01, 2020 12:04 pm
wandererfan wrote:
Sat Feb 29, 2020 5:14 pm
KenSimmons wrote:
Sat Feb 29, 2020 4:21 pm
Hi there, new to FreeCAD. I have used TurboCAD in the past. My interest is in aircraft sheet metal work. Over the past 5-6 years TurboCAD has been improving with Bend / Unbend tools. But is still limited in data inputs. I noticed that FreeCAD sheet metal workbench has K factors. I would like to be able to add "rivet location" symbols to prints. Such as the NAS523 symbol. There are four quadrants, each quadrant will have a different code letter or code number. I believe Blocks allow for data inputs and symbols are fixed. How are they different from Balloons. With sheet metal work you deal with layout patterns, setbacks, Bend Allowances, Bend radius's, Rivet Edge Distances, Rivet Transverse Pitch distances.
Hi Ken, welcome to the forum. Full disclosure: I don't know much about the sheet metal work bench and I had never heard of the NAS523 symbol until I read this note. So thanks for expanding my horizons.
I see a couple of problems with using the existing Balloon feature as NAS523 symbol. Balloons don't do multiple lines easily and a Balloon only has one leader.
I've posted a request for input to the sheet metal folks here: https://forum.freecadweb.org/viewtopic. ... 49#p373049
Here are the specifics of the thread that @wandererfan was referring to.
Postby Kunda1 » Sun Mar 01, 2020 12:34 pm
Feature Request - STEP auto-unfolder (https://forum.freecadweb.org/viewtopic.php?f=8&t=43796)
hl037
Postby hl037 » Sat Mar 07, 2020 6:22 pm
I have struggle to understand the "radius" parameter of the "Create a sheetmetal wall from a sketch" feature, as explained in : https://forum.freecadweb.org/viewtopic. ... 56#p374956
(it was suggested to me to link it here)
fc_tofu
Postby fc_tofu » Sun Mar 08, 2020 6:05 pm
Dear shai, I just tried you Sheet Metal WB a little, very easy to use, thank you.
I'm a little curious, can this workbench be used in wire bending design and paper box design ?
I'm not expertise, just do some steel wire bending and paper box for fun at leisure time.
To be specific, wire bending has always a circle profile, paper box have some 180 degree bending.
papyblaise
Postby papyblaise » Sun Mar 08, 2020 8:40 pm
Wire or pipe square or circulaire don't works
sheet of paper (or metal) bended at 180° works whith condition : never use R less 0.01mm
fc_tofu
Postby fc_tofu » Mon Mar 09, 2020 7:11 am
Thank you, mr. saise.
I have very minor proposals about UI.
Could the toolbar name and context name use a better name, such as "Sheet Metal", instead of current "My Commands"? The current one is confusing in "user.cfg" file.
And the version number following workbench menutext looks weird, I guess it's there just for the sake of a beta verison?
Postby Kunda1 » Mon Mar 09, 2020 12:14 pm
Where do you see 'My Commands' in user.cfg ?
The version number is there because we haven't figured out https://github.com/FreeCAD/FreeCAD-addons/issues/105
