Sheet Metal Workbench
Tandini
Re: Sheet Metal Workbench
Postby Tandini » Wed Aug 31, 2016 4:41 pm
Shaise wrote:
For unfolding to work, you must first select a face that resides on the surface of the flattened sheet, then press unfold button.
Of course I did that ...
Here's an other example: Unfolding 'Bend' and 'Bend001' works, adding 'Bend002' still works (Unfold001) - always selecting the green marked face - but after adding 'Bend003' unfolding fails ... creating the red shape. The same when bending left and right of 'Bend' ...
I realized the issue, when working on that:
shaise
Postby shaise » Wed Aug 31, 2016 8:24 pm
Tandini,
Can you please attach the non-unfoladable example (in FreeCad FcStd format) ?
Also, please add your system info from the Help -> About -> Copy To Clipboard?
ulrich1a
Postby ulrich1a » Wed Aug 31, 2016 8:50 pm
Tandini wrote:Here's an other example: Unfolding 'Bend' and 'Bend001' works, adding 'Bend002' still works (Unfold001) - always selecting the green marked face - but after adding 'Bend003' unfolding fails
The unfolding code does not detect a situation, where it can not work reliable. The Bend003 needs on each side a small gap to work correctly. On my side it works, when I define those gaps in the bend.
Ulrich
Tandini
Postby Tandini » Wed Aug 31, 2016 9:12 pm
@ ulrich1a: Thanks, your hint solved the issue. I defined gaps with 0,5mm - unfolding works perfect!
efyx
Postby efyx » Wed Sep 07, 2016 5:37 am
Request for upgreade sheetmetal - again ;) .
Maybe some smart programmer will handle with some additional tools for sheet metal module?
This is what I found in bricscad - looks very nice and user-friendly: https://www.youtube.com/watch?v=iIJhYVW2f8I - Solidworks have little bit worse managing system.
Mostly needed is:
1) From solid by shell to showing which edges are bends and witch are to rip (from 0:25).
2) Making operations on unfolded sheet and option to fold it again.
3) Operations on cutouts (2:02 from movie).
4) 3 options or ripping edges. Both ripped equally, one edge to another and flipped (1:23 from movie).
Maybe
microelly2 wrote:...
- has already experience with good looking paper model module.
What do you think?
efyx
Postby efyx » Wed Sep 14, 2016 9:22 am
up^
efyx
Postby efyx » Tue Oct 04, 2016 6:56 am
Few links to inspire:
https://www.youtube.com/watch?v=eSfqk-n9iIs <-- from solid to sheetmetal
https://www.youtube.com/watch?v=cWhwsw6b8fI <-- from flat to 3d sheetmetal
https://www.youtube.com/watch?v=iIJhYVW2f8I <-- other from solid to sheetmetal +tears modification (2:20)
triplus
Postby triplus » Tue Oct 04, 2016 9:20 am
Hi @efyx.
If you proposed something i am sure developers took a look. The rest is up to them to decide what happens next.
P.S. And please edit your post and remove disrespectful image.
efyx
Postby efyx » Tue Oct 04, 2016 9:47 am
triplus wrote:And please edit your post and remove disrespectful image.
Thought that was quite funny :o but ok.
triplus
Postby triplus » Tue Oct 04, 2016 9:53 am
Thanks.
