Ok, it is a solution, and we can now work like 2 days ago. Abdullah your work is great, improvements in sketcher are needed, so those problems are normal in a programming process. No problem for me
Thank you
Sketcher in PartDesign breaks after Edit
Re: Sketcher in PartDesign breaks after Edit
Hello. I think that I'm facing the same bug:
I open freecad, create a new sketch, draw 3 lines and then try to remove one of them, result:
File
Installation info:
I hope this helps to solve the problem
Javier.
FreeCAD 0.16, Libs: 0.16R5086 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2015
My Sheet Metal Loaded
(freecad:4279): Gtk-CRITICAL **: IA__gtk_widget_get_direction: assertion 'GTK_IS_WIDGET (widget)' failed
*** Abort *** an exception was raised, but no catch was found.
... The exception is:SIGSEGV 'segmentation violation' detected. Address ffffffff
OS: Linux Mint 17.1 Rebecca
Version: 0.16.5086 (Git)
Build type: None
Hash: 4f5534a87a7e2d224022ff98729a341bf57e7f9e
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
Javier.
FreeCAD scripts, animations, experiments and more: http://linuxforanengineer.blogspot.com.es/
Open source CNC hot wire cutter project (NiCr): https://github.com/JMG1/NiCr
Exploded Assembly Workbench: https://github.com/JMG1/ExplodedAssembly
I know how to solve this problem (the crash upon deleting a line). And I also fixed another one (a fully constrained sketch was not shown green when entering into edit mode).
The thing is that there are more issues (fillet crashes even with Auto-Update checked, and trim does not crash but does not fully work either, the last constraint is not enforced). All of this appeared as a consequence of a last minute insertion that solved a minor issue but apparently inadvertently generated more. So, yes, I am very much to blame.
Except for the fillet issue, I think that with "Auto-Update" checked there are no crashes. Please work with Auto-Update checked. I am going to rest (I am now 20 hours awake) and tomorrow I will take my time to study all the the implications of some decisions I made and find an appropriate (hopefully definitive) solution.
My apologies.
My apologies.
Take your time @abdullah. After all this is about development release and not production release.
And the workaround is simple (one check box enabled in sketcher Task sidebar).
After sleeping one sees life different
I have submitted a pull request with several fixes:
https://github.com/abdullahtahiriyo/Fre ... constraint_
If you are in the testing mood, you may want to compile it and see if you make it crash. If you do, please report it, I will try to fix it for the next PPA.
Hopefully you will be able to work without recomputes again
