STP Export fail
mk2
STP Export fail
Postby mk2 » Thu Jun 18, 2015 9:02 am
the STEP export fail if i have a B_Spline constructed line on my Part. I opened the STP in Solid Edge, the screenshot is attached. STP Version is ap203, the same problem with the newer one ap214. is there a problem with the SE import, oder with FreeCAD export?
FreeCAD:
SolidEdge:
OS: Ubuntu 14.04.2 LTS
Version: 0.16.5086 (Git)
Build type: None
Hash: 4f5534a87a7e2d224022ff98729a341bf57e7f9e
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
Kind Regards
mk2
Drehteil_V002.step
(11.19 KiB) Downloaded 40 times
Drehteil_V002.fcstd
(4.96 KiB) Downloaded 27 times
jeno
Re: STP Export fail
Postby jeno » Thu Jun 18, 2015 12:06 pm
I tend to say it is a bug in freecad respectively in opencascade, because afaik the import/export stuff comes from oc.
I got a similar message with varicad (one missing face). The result is similar to SolidEdge
OS: Tanglu GNU/Linux 2 (Bartholomea Annulata)
Word size: 64-bit
Version: 0.14.3702 (Git)
Branch: releases/FreeCAD-0-14
Python version: 2.7.8
Qt version: 4.8.6
SoQt version: 1.6.0a
OCC version: 6.7.0
Step imort in varicad 2015-2.04
jakob
Re: STP Export fail
Postby jakob » Thu Jun 18, 2015 12:10 pm
Failed for me too, looks like a open box.
But if you use .iges it works perfect.
Site Admin
Re: STP Export fail
Postby wmayer » Fri Jun 19, 2015 11:48 am
For me it fails to import the attached STEP file. I get these error messages:
Cannot compute Inventor representation for the shape of Part__Feature.
Whenever something is wrong with import/export I use CADExchanger and this shows exactly the same behaviour, i.e. it doesn't show anything in the 3d view. So, very likely it's a problem with the STEP export.
To check whether it's related to the advanced STEP export in FreeCAD go to the Part workbench and use the command under Part > CAD Export and select the filter STEP (not "STEP with colors"!) which only exports the plain data.
jeno
Re: STP Export fail
Postby jeno » Fri Jun 19, 2015 5:14 pm
wmayer wrote:For me it fails to import the attached STEP file. I get these error messages:
Done as suggested, but no difference. It still fails with varicad - with the same failure message. :(
Hope that helps.
mk2
Re: STP Export fail
Postby mk2 » Fri Jun 19, 2015 6:42 pm
I tried it, ap203/214 with or without colors. There is the same problem... But i think only with parts which have b-splines or curves. If i have free time on the weekend i will try some different structures...
Kind regards
Site Admin
Re: STP Export fail
Postby wmayer » Fri Jun 19, 2015 9:39 pm
So, at least it's a problem with OpenCascade directly then and not FreeCAD.
mk2
Re: STP Export fail
Postby mk2 » Sat Jun 20, 2015 7:47 am
Ok, should we report it to OCC or to the OCC comunity edition? In OCC 6.9 are many bugfixes for STP and IGES but the OCE version is still on 6.8. What do you think? STP export is important for FreeCad...
cwstirk
Re: STP Export fail
Postby cwstirk » Sat Jun 20, 2015 7:57 pm
I think it should be reported to OCCT because I do not believe that OCE has done anything with the STEP translator.
mk2
Re: STP Export fail
Postby mk2 » Tue Jun 23, 2015 1:20 pm
Ok i reported the bug: http://tracker.dev.opencascade.org/view.php?id=26367
I'm curious about it. :)
Kind Regards
mk2
