Is there an interference checking tool to see if two or more 3D shapes overlap? Or does it have to be done visually? I have a complicated composite shape I want to put in a case and such a tool would be useful. I've looked at Help and can't find anything.
OS: Windows 8
Word size of FreeCAD: 32-bit
Version: 0.15.4671 (Git)
Branch: releases/FreeCAD-0-15
Hash: 244b3aef360841646cbfe80a1b225c8b39c8380c
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
Interference checker
Maavhamt
[/size]Re: Interference checker
Hello.
I would:
1) clone with draft workbench the two shapes in question
2) do a boolean intersection with the two clones (part module-workbench)
3) use one of these macros from the macro page in the wiki
ObjectInfo
FCInfo (Windows)
FCInfo (Linux)
to get the volume of your intersection. If it is >0 you have interference
[but anyway you are right, commercial 3D CAD's mostly have such a tool]
Roland
I would:
ObjectInfo
FCInfo (Windows)
FCInfo (Linux)
Roland
My GrabCAD FreeCAD-Projects
Native german speaker - so apologies for my english, no offense intended
Actually i just noticed @hamish added tool like that in his 3rd Party FreeCAD Assembly2 module. I did few basic tests with some cubes and cylinders and it worked fine. Check it out yourself on how it works for your use case if you are interested.
Here is a macro that does collision detection.
Collision Detect
A colllision occurs when two objects try to occupy the same space; just like an auto acccident.
It is recommended that you read and understand the tolerance section! This is dependent on the size of the objects you are checking!
I used it in an automated script to check all the parts in an assembly, over their entire range of motion.
Regards,
bill
Collision Detect
Regards,
bill
Thanks for your help. Sorry but being new to FreeCAD I don't understand Macros, but the Boolean intersection tool did the job. I have also learned about cloning, which will be useful.
Maavhamt
[/size]
