can not import dwg-file
I downloaded some dwg-files and wanted to import them into fc.
I got this error popup: fc-version:
OS: Debian GNU/Linux 8.1 (jessie)
Version: 0.16.5161 (Git)
Build type: Unknown
Hash: 48c25da133271a0caebec74427461f01c234c229
Python version: 2.7.9
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
//Edith:
I found a workaround and converted all dwg files with Teiga outside of FC to dxf. DXF-Import then works ...
So no more help required.
Build type: Unknown
Qt version: 4.8.6
//Edith:
OS: Linux Debian Jessie amd64 - FC: Git Master
Re: can not import dwg-file
Usually this happens when there are non-ASCII characters in your file paths.. Teigha is very picky on that...
Hi yorik,
thanks for that hint! You're right - path contains non-ASCII characters.
I use linux and utf-8 now for years and don't think about those limitations ...
... but yes, some apps (like meshlab and others) don't handle special characters right.
But ...
I had no problem with Teigha using the same path for conversion and Teigha did it.
Ah - I see
Just tried again - the log shows the problem:
The name of downloaded file has space inside :O
May be the non-ASCII character is not the problem.
AFAIK if you quote the path with single quotes, it should do the trick - and the shell is outside.
But ...
Ah - I see
importDWG.insert(u"/home/xx/yy/Fr\xe4se-Selbstbau/FC/UNP 65.dwg","Unbenannt")
Are you sure? I always thought in python there is no difference between single and double quotes...django013 wrote:AFAIK if you quote the path with single quotes, it should do the trick - and the shell is outside.
Hi yorik
I'm sure, I don't know anything about python :O
... but I know linux and shell programming and every system call on linux systems involves a shell.
No matter what you do in python or c++ ... at the end a shell gets the path will all arguments. If at that stage, the arguments are not quoted, the shell starts to interpret each argument - and of cause, a space inside an argument will increase the number of arguments for the command called.
To prohibit the shell from any interaction, its best to have each argument embedded in single quotes.
... but quoted paths must match character code page from filesystem. There's no more codepage conversion then.
From python may be a good try, first embed each command argument in single quotes and then embed it into double quotes?
Don't know, whether it works that way - just an idea ...
In any case, it's indeed worth trying to play with single/double quotes...
Hi yorik,
could you please tell me some pointers where the call of the dwg-importer happens?
I'd like to have a look at it and do some tests.
That should be a good starting point for you:
[przemo@localhost freecad]$ git grep dwg
Binary file src/Doc/freecad.qch matches
src/Mod/Arch/InitGui.py: FreeCADGui.addPreferencePage(":/ui/preferences-dwg.ui","Import-Export")
src/Mod/Draft/InitGui.py: FreeCADGui.addPreferencePage(":/ui/preferences-dwg.ui","Import-Export")
src/Mod/Draft/InitGui.py:App.addImportType("Autodesk DWG (*.dwg)","importDWG")
src/Mod/Draft/InitGui.py:App.addExportType("Autodesk DWG (*.dwg)","importDWG")
src/Mod/Draft/Resources/Draft.qrc: <file>ui/preferences-dwg.ui</file>
src/Mod/Draft/importDWG.py:def convertToDxf(dwgfilename):
src/Mod/Draft/importDWG.py: indir = os.path.dirname(dwgfilename)
src/Mod/Draft/importDWG.py: basename = os.path.basename(dwgfilename)
src/Mod/Draft/importDWG.py:def convertToDwg(dxffilename,dwgfilename):
src/Mod/Draft/importDWG.py: outdir = os.path.dirname(dwgfilename)
src/Mod/Draft/importDWG.py: return dwgfilename
Binary file src/Mod/Path/DemoParts/hole_puzzle.fcstd matches
Thanks!
so after first look - how can I get the output of the print-statements?
No matter whether I enable python message redirection in fc or not - no print-message shows up
