[Fixed!] Bug in Sketcher Distance/Radius Entry
f3nix
Re: Bug in Sketcher Distance/Radius Entry
Postby f3nix » Sun Sep 06, 2015 12:50 pm
this bug has been introduced in cb16fec6bb67cec15be3fc2aeb251ab524134073.
File: src/Gui/QuantitySpinBox.cpp
Line number: 70
Just comment it out and everything goes back to normal.
HTH.
Cheers,
Mateusz
quick61
Postby quick61 » Tue Sep 08, 2015 3:15 am
Thanks f3nix! The fix is in and all is back to working normally. :)
Mark
Re: [Fixed!] Bug in Sketcher Distance/Radius Entry
Postby wmayer » Wed Sep 09, 2015 1:37 pm
A bit more info on the problem of erasing the first digit in constraint value edit box. It happens when I try to do something that will make the first character to become a space. It doesn't matter what exactly: backspace, erase selection, delete, or even putting a space at the beginning. Sometimes, it prevents entering spaces anywhere (isn't a problem, I don't type spaces into numbers). Sometimes, it prevents me from entering a comma. Comma and space seem to be interacting with each other somehow...
All these problems are related to the weird setting that you define space as group separator. When you e.g. enter the value "24 mm" where space is set as group separator then of course it's logical that the SW forbids you to enter "2,4 mm" because a decimal separator can never ever come in front of a group separator. Btw, Qt built-in widgets like QDoubleSpinBox show the same behaviour.
