Object description field
lemonbug
Postby lemonbug » Sun Aug 30, 2015 10:25 pm
Is there a text field where I can write some notes about an object? My project keeps getting bigger and I stop working on it for long periods of time. It would be nice if I could click on the object and read any notes that I jotted down.
OS: Mac OS X
Version: 0.15.4671 (Git)
Branch: releases/FreeCAD-0-15
Hash: 244b3aef360841646cbfe80a1b225c8b39c8380c
Python version: 2.7.9
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
triplus
Re: Object description field
Postby triplus » Mon Aug 31, 2015 12:33 am
lemonbug wrote:Is there a text field where I can write some notes about an object? My project keeps getting bigger and I stop working on it for long periods of time. It would be nice if I could click on the object and read any notes that I jotted down.
OS: Mac OS X
Qt version: 4.8.6
I think there is no such feature available ATM.
P.S. What you could do is you could add spreadsheet (in first column add object name and in second column notes related to it).
mario52
Postby mario52 » Mon Aug 31, 2015 9:38 am
hi
This is a great easy function to build ex :
add one property in alls objects (quick example on a modified macro)
      obj.addProperty("App::PropertyString","Memo","Draft","Font name").Memo = "tyty"
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Topological_data_scripting, Dialog creation. My macros on Gist.github.
lemonbug
Postby lemonbug » Mon Aug 31, 2015 3:49 pm
Thanks. I am not at home right now. Would I be able to use this macro to add this field? that would be awesome.
mario52
Postby mario52 » Tue Sep 01, 2015 1:20 pm
hi
no is just an example i add :
the original macro Macro_Rectellipse
you can make a feature request, this a nice feature
mario
mario52
Postby mario52 » Wed Sep 02, 2015 7:10 pm
hi
I modified the Draft.py file:
I added these lines
        obj.addProperty("App::PropertyString","_Author","Draft","Author name")
        obj.addProperty("App::PropertyString","_Date","Draft","Date")
        obj.addProperty("App::PropertyString","_Memo","Draft","Memo")
go to C:\Program Files\FreeCAD 0.15\Mod\Draft copy your original file (for as backup) an unzip and copy my file modified in your directory
for test !!
Draft.zip
(42.99 KiB) Downloaded 41 times
OS: Windows 8
Version: 0.15.4671 (Git) same version you
Python version: 2.7.8
Qt version: 4.8.6
mario
lemonbug
Postby lemonbug » Wed Sep 02, 2015 7:57 pm
ill play around with it. thanks!
mario52
Postby mario52 » Thu Sep 03, 2015 1:55 pm
hi
it does not work ?
mario
Postby chrisb » Fri Sep 04, 2015 9:57 pm
I just used the code given here for a similar task in the Path WB.
Select an object in the tree to the left and execute the following code:
obj = FreeCADGui.Selection.getSelection()[0]
obj.addProperty("App::PropertyString","GComment","Draft","Font name").GComment = "Comment here"
App.activeDocument().recompute()
Then you have an additional field in the object GComment.
mario52
Postby mario52 » Mon Sep 28, 2015 9:53 am
Hi chrisb
i add your code in Code_snippets
thanks
mario
