Units of measure in dxf import
Roy_043
Re: Units of measure in dxf import
Post by Roy_043 »
In mm.dxf the MEASUREMENT variable is wrongly set to 0. It must be set to 1 for metric files. The INSUNITS variable is set to 4, which is correct, and this variable should actually have priority over MEASUREMENT.
This is all with the new DXF importer. The legacy DXF importer ignores units.
Nabilakroud
Post by Nabilakroud »
Roy_043 wrote: Sat Jul 02, 2022 8:32 pm In mm.dxf the MEASUREMENT variable is wrongly set to 0. It must be set to 1 for metric files...
✅ Well done,
I changed inside my file mm.dxf the following lines
$MEASUREMENT
70
   0
9
by
$MEASUREMENT
70
   1
9
and it worked correctly, maybe is a LibreCAD bug.
Thank you very much for your help.
