Unable to perform Boolean operations in mesh mode
tkatsuki
Postby tkatsuki » Sat Nov 28, 2015 12:26 am
Hi, I was trying to run a Boolean operation (e.g. difference) in Mesh Mode but FreeCAD gave me an error "Unknown error occurred while running OpenSCAD". The mesh objects were a simple cube and a sphere created in Part Mode and converted into mesh objects in Mesh Mode.
Here is my session info:
OS: Mac OS X
Version: 0.15.4671 (Git)
Branch: releases/FreeCAD-0-15
Hash: 244b3aef360841646cbfe80a1b225c8b39c8380c
Python version: 2.7.9
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
OpenSCAD version is 2015.03-2.
Python code looks like this:
import WebGui
from StartPage import StartPage
WebGui.openBrowserHTML(StartPage.handle(),'file://' + App.getResourceDir() + 'Mod/Start/StartPage/','Start page')
App.newDocument("Unnamed")
App.setActiveDocument("Unnamed")
App.ActiveDocument=App.getDocument("Unnamed")
Gui.ActiveDocument=Gui.getDocument("Unnamed")
Gui.activateWorkbench("PartWorkbench")
App.ActiveDocument.addObject("Part::Box","Box")
App.ActiveDocument.ActiveObject.Label = "Cube"
Gui.SendMsgToActiveView("ViewFit")
App.ActiveDocument.addObject("Part::Sphere","Sphere")
App.ActiveDocument.ActiveObject.Label = "Sphere"
Gui.activateWorkbench("MeshWorkbench")
import MeshPartGui, FreeCADGui
FreeCADGui.runCommand('MeshPart_Mesher')
import Mesh
import MeshPart
__doc__=FreeCAD.getDocument("Unnamed")
__mesh__=__doc__.addObject("Mesh::Feature","Mesh")
__mesh__.Mesh=MeshPart.meshFromShape(Shape=__doc__.getObject("Box").Shape,MaxLength=1)
__mesh__.Label="Cube (Meshed)"
__mesh__.ViewObject.CreaseAngle=25.0
del __doc__, __mesh__
import Mesh
import MeshPart
__mesh__.Mesh=MeshPart.meshFromShape(Shape=__doc__.getObject("Sphere").Shape,MaxLength=1)
__mesh__.Label="Sphere (Meshed)"
import OpenSCADUtils
mesh = OpenSCADUtils.meshoptempfile('difference',(App.ActiveDocument.Mesh.Mesh,App.ActiveDocument.Mesh001.Mesh))
App.ActiveDocument.addObject("Mesh::Feature","Difference")
App.ActiveDocument.Difference.Mesh = mesh
I'd appreciate your help to solve the problem.
Thanks,
Takeo
Site Admin
Re: Unable to perform Boolean operations in mesh mode
Postby wmayer » Sat Nov 28, 2015 12:59 pm
I have tried OpenSCAD 2015.03.2 on Windows and your script works perfectly there. Maybe the way how OpenSCAD is called on OSX inside the Python function OpenSCADUtils.meshoptempfile is wrong.
tkatsuki
Postby tkatsuki » Sun Nov 29, 2015 3:24 am
Thanks, wmayer. I'm not sure what fixed the problem but now Mesh Boolean also works on my Mac. What I did first was to go to OpenSCAD mode and run Mesh Boolean from there (I also checked path to the executable from Preference but it looked correct so I didn't change). After that even Boolean from Mesh Mode also worked.
Thanks again for developing such great software.
Takeo
s_hemer
Postby s_hemer » Tue May 28, 2019 9:05 pm
I just ran across the same issue with FreeCAD 18.1 in combination with 2015.03 on a Ubuntu 18.04. Boolean operation even on simple regular geometry meshes do not work neither in Mesh Design nor in OpenSCAD mode. I could not make OpenSCAD to finally render the Boolean operation on the imported meshes (only preview works), so I am not sure if this is a FreeCAD o OpenSCAD issue (or some misconfiguration).
  File "/usr/share/freecad/Mod/OpenSCAD/OpenSCADCommands.py", line 371, in doboolean
    newmesh,objsused = meshoponobjs(opname,FreeCADGui.Selection.getSelection())
  File "/usr/share/freecad/Mod/OpenSCAD/OpenSCADUtils.py", line 484, in meshoponobjs
    return (meshoptempfile(opname,meshes),objs)
  File "/usr/share/freecad/Mod/OpenSCAD/OpenSCADUtils.py", line 446, in meshoptempfile
    result = callopenscadmeshstring('%s(){%s}' % (opname,meshimports))
  File "/usr/share/freecad/Mod/OpenSCAD/OpenSCADUtils.py", line 410, in callopenscadmeshstring
    tmpfilename=callopenscadstring(scadstr,'stl')
  File "/usr/share/freecad/Mod/OpenSCAD/OpenSCADUtils.py", line 185, in callopenscadstring
    inputfile.write(scadstr)
TypeError: write() argument 1 must be unicode, not str
jmaustpc
Postby jmaustpc » Wed May 29, 2019 12:40 am
Your first post, welcome to FreeCAD.
Please post your FreeCAD version data in the manner explained in the Forum Rules link above, so that we know what we are dealing with.
Also which version of OpenSCAD did you install and from where?
Site Admin
Postby wmayer » Thu May 30, 2019 8:13 am
Using this Windows version:
OS: Windows 7
Version: 0.18.15998 (Git)
Hash: 5791c341be797ff2eee99eccac53df71db510fae
Python version: 3.6.6
Qt version: 5.6.2
The mesh boolean operations work flawlessly.
Now to test it on Ubuntu 18.04 I started my virtual installation and I realized that Ubuntu doesn't offer OpenSCAD for this version. I wonder where you got your OpenSCAD installation from.
So, I installed it from Launchpad https://launchpad.net/~openscad/+archiv ... u/releases and also using this version it works without problems.
Does your FreeCAD installation depend on Python2?
Site Admin
Postby wmayer » Thu May 30, 2019 9:35 am
When using a Python2-based FreeCAD -- also on Windows -- then I can confirm the failure.
import Mesh
mesh1=Mesh.createBox(10,10,10)
mesh2=Mesh.createCone()
mesh = OpenSCADUtils.meshoptempfile('union',(mesh1,mesh2))
After changing several things inside OpenSCADUtils.py I got it working for Python2. The changes affect the functions check_output2 and callopenscadstring. So replace the file of your FreeCAD installation with this one or switch to a Python3-based FreeCAD version.
OpenSCADUtils.py
(25.16 KiB) Downloaded 6 times
Postby Kunda1 » Thu May 30, 2019 11:42 am
@wmayer should we offer this as a viable workaround in the code?
jmaustpc
Postby jmaustpc » Thu May 30, 2019 12:13 pm
about a week ago a new version of OpenSCAD was released, 2019.05, the PPA Werner referenced still has an old version in it.
OpenSCAD news
http://www.openscad.org/news.html
the version list in the PPA see Werner's link
2015.03-2+dfsg-2~18.04
two versions are 4 years apart, by the way.
Apparently the dependencies have changed, I read that in a post on their forum the response to a question about dependencies was to read the "readme" file.
Perhaps to the question is does the new release version work? Perhaps their PPA will be updated soon.
s_hemer
Postby s_hemer » Thu May 30, 2019 9:30 pm
Thanks for the hints and sorry for not providing more details on the version. I just installed from the respective PPAs and did not realize that there is a freecad-python{2,3}. Seems that it installed freecad-python2 on my machine.
I really wonder that I did not saw the OpenSCAD news. I will check all that.
