Unable to perform Boolean operations in mesh mode
s_hemer
Re: Unable to perform Boolean operations in mesh mode
Postby s_hemer » Thu Jun 06, 2019 2:07 pm
Ok, I can report back that
a) Changing my install from freecad-python2 (which was chosen by default when installing freecad package on 18.04) to freecad-python3 (and of course removing freecad-python2 and all otherwise unused dependencies) works with the old OpenSCAD 2015.03-2+dfsg-2~18.04 from their PPA (which has not been updated yet, unfortunatelly)
b) it works with a simple example (cube/sphere difference) but with my initial meshes their seems to be another issue most likely with the mesh itself I assume (OpenSCADUtils.OpenSCADError: ' ERROR: CGAL error in CGAL_Nef_polyhedron3(): CGAL ERROR: assertion violation!\nExpr: e_below != SHalfedge_handle()\nFile: /usr/include/CGAL/Nef_3/SNC_FM_decorator.h\nLine: 426\nCurrent top level object is empty.\n'). Will further dig into that.
Two thing I'd suggest for improvement:
- Whether to fix the python2 variant or not (I understand that it might not be worth the effort) it would be nice that, if possible (depending on system), the python3 variant is installed by default.
- For the new error, it would be nice to not just see the same 'Unknown error' dialog in Mesh Design but a more telly one. OpenSCAD view shows the error on the output window which, I guess, was activate by myself otherwise it would have been quiet.
Just thoughts, trying to improve this cool piece of software.
Site Admin
Postby wmayer » Fri Jun 07, 2019 11:12 am
Site Admin
Postby wmayer » Fri Jun 07, 2019 11:15 am
Can you offer some test data so that we can check the behaviour of OpenSCAD?
s_hemer
Postby s_hemer » Thu Jul 18, 2019 8:21 pm
Sorry, I didn't find time in the last weeks to have a look on this problem. I checked another way as well: creating solids from the meshes and take the difference from them but it also fails (the one solid seems to have errors, removed them again as the file was to big).
Find the example attached. It is the CNC router base (from https://www.thingiverse.com/thing:3397013) where I want to remove the airchannel shape (Difference Base-Channel).
test.FCStd
(131.55 KiB) Downloaded 2 times
TheMarkster
Postby TheMarkster » Thu Jul 18, 2019 11:28 pm
When I open your file I see 2 different meshes, airchannel and makitabase. If you want to get rid of airchannel just delete it.
s_hemer
Postby s_hemer » Fri Jul 19, 2019 5:44 pm
Did you mean that serious? How else do you say when you do a boolean difference operation: remove mesh B from mesh A, so of course two meshes. After that binary boolean operation I assume a single mesh C to be the result (C = A && !B).
