3Dconnexion on Mac OS
legndlarry33
Postby legndlarry33 » Mon Dec 14, 2015 3:35 am
Apologies in advance
Just stumbled onto this site/software and it is awesome
Figuring it out, but would love to be able to use my spacenavigator to move around
Found the page below, but can't figure out if I need to "compile" the program to make it work, rather than just install it...? Is there any way to make it work without "building" the software?
http://www.freecadweb.org/wiki/index.ph ... ut_devices
I installed the 3dconnexion software and the device works fine within the 3dconnexion software, but on the two "space pilot" tabs in FreeCAD I just see "no spacebar present"
Any help is very much appreciated
Site Admin
Re: 3Dconnexion on Mac OS
Postby wmayer » Mon Dec 14, 2015 8:42 am
So, this means the OSX version is built without space mouse support. However, in the code we have at least rudimentary support for this device but I am not sure how well this works.
Maybe one of the package maintainers for OSX could enable space mouse support and upload a new package?
legndlarry33
Postby legndlarry33 » Sun Dec 20, 2015 2:20 pm
Thanks for the reply
That would be awesome if someone could do that...?
brusk
Postby brusk » Sun Dec 20, 2015 10:32 pm
legndlarry33 wrote:Apologies in advance
Can you try the build downloadable at https://github.com/bblacey/FreeCAD-MacOS-CI/releases?
I had to move the app to /usr/local/ to be able to use Part Design.
legndlarry33
Postby legndlarry33 » Mon Dec 21, 2015 2:01 am
I trashed the version I had been running, downloaded the FreeCAD_osx-6094-d6920a0.zip but am having the same problem running that as well. "No Spaceball Present"... am I doing something wrong?
Site Admin
Postby wmayer » Mon Dec 21, 2015 9:57 am
Is there a way to see which cmake switches were used to build the binaries?
blacey
Postby blacey » Mon Dec 21, 2015 12:17 pm
Mac OS X build 0.16_pre-19fd2c3 includes ian's 3DConnexion changes in commit eb5ec62c and the here is the TRAVIS build log
Would be great to get confirmation if it works or not and/or if you see any other problems with the build so we can tighten it down...
Cheers,
Bruce
Site Admin
Postby wmayer » Mon Dec 21, 2015 1:03 pm
But this doesn't answer the question if 3d mouse support is enabled or not. For Windows and OSX there is a cmake switch "FREECAD_USE_3DCONNEXION" that must be set. On Windows this is on by default but on OSX it depends.
Luckily, I now remember how to see if a build supports 3d mouse: go to Help > About FreeCAD and you should see a button "License" there.
Clicking on it should show a second dialog with this content:
3D Mouse Support:
Development tools and related technology provided under license from 3Dconnexion.
(c) 1992 - 2012 3Dconnexion. All rights reserved
If you can see this message then the 3d mouse support is activated and if you can't then it's not activated.
legndlarry33
Postby legndlarry33 » Mon Dec 21, 2015 3:57 pm
So I don't see an "About FreeCAD" in the Help menu, but I do see it under "FreeCAD" menu... unfortunately what I see there does not include a license button to get to that second dialog (see attached)...?
about.tiff
about.tiff (252.63 KiB) Viewed 1843 times
Site Admin
Postby wmayer » Mon Dec 21, 2015 5:40 pm
So, this means the OSX build doesn't have enabled 3d mouse support.
