[solved] question on Part->Cross Sections
piffpoof
Postby piffpoof » Wed Dec 30, 2015 9:35 pm
hi
I have a model that is 4m thick and would like to make 6 or so cross sections of it. That would imply a Distance between cross-sections of about 66cm. When I try and enter this in the Cross Sections control panel, I can not set the Distance between cross-sections greater than 99.99mm. Generating cross-sections at 99.99mm generates about 40 cross-sections.
Is there a way around this or is there a reason for this limitation?
I checked the Wiki page but it has nothing to say.
thanks
Dean
triplus
Re: question on Part->Cross Sections
Postby triplus » Wed Dec 30, 2015 10:11 pm
Probably QSpinBox is set at default value (max 99). If you want you can create feature request and hopefully higher value will be set soon.
murdic
Postby murdic » Wed Dec 30, 2015 10:17 pm
piffpoof
[solved] Re: question on Part->Cross Sections
Postby piffpoof » Thu Dec 31, 2015 8:27 am
triplus wrote:Probably QSpinBox is set at default value (max 99). If you want you can create feature request and hopefully higher value will be set soon.
Thanks, was able to trap and modify the Python Console code as listed below to work around, so your suggestion of the Input box limit is probably it.
Reported as a GUI issue on Mantis #2385
import Part
from FreeCAD import Base
wires=list()
shape=FreeCAD.getDocument("hull").Fusion.Shape
for i in shape.slice(Base.Vector(1,0,0),-1500.0):
     wires.append(i)
for i in shape.slice(Base.Vector(1,0,0),-1000.0):
     wires.append(i)
for i in shape.slice(Base.Vector(1,0,0),-500.0):
     wires.append(i)
for i in shape.slice(Base.Vector(1,0,0),0.0):
     wires.append(i)
for i in shape.slice(Base.Vector(1,0,0),500.0):
     wires.append(i)
for i in shape.slice(Base.Vector(1,0,0),1000.0):
     wires.append(i)
for i in shape.slice(Base.Vector(1,0,0),1500.0):
     wires.append(i)
comp=Part.Compound(wires)
slice=FreeCAD.getDocument("hull").addObject("Part::Feature","Fusion_cs")
slice.Shape=comp
slice.purgeTouched()
del slice,comp,wires,shape
Site Admin
Postby wmayer » Thu Dec 31, 2015 11:27 am
