[Fixed] Expressions: crash when object.Name == "Placement"
DeepSOIC
Postby DeepSOIC » Sat Jan 23, 2016 12:26 am
Hi!
The bug was narrowed down from a crash in Lattice wb reported by @Dim, here: viewtopic.php?f=3&t=13906&start=10
1. new document.
2. run:
o = App.ActiveDocument.addObject("Part::FeaturePython","Placement")
3. Select the new feature. FreeCAD hits an assert, then crashes.
Note: on Windows, it crashes only in debug build. Release build seems to swallow the problem, not sure why.
OS: Windows 8.1
Version: 0.16.6207 (Git)
Build type: Debug
Branch: (detached from abdullah/hyperbola_2016)
Hash: f80e07e04cc09cef611768a11fdbb7799460e336
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.7.1
Site Admin
Re: [bug] Expressions: crash when object.Name == "Placement"
Postby wmayer » Sat Jan 23, 2016 11:57 am
The assert is triggered in
void ExpressionBinding::bind(const App::ObjectIdentifier &_path)
    const Property * prop = _path.getProperty();
    Q_ASSERT(prop != 0);
    path = prop->canonicalPath(_path);
    //connect to be informed about changes
    DocumentObject * docObj = path.getDocumentObject();
    connection = docObj->ExpressionEngine.expressionChanged.connect(boost::bind(&ExpressionBinding::expressionChange, this, _1));
FYI, in a release build an assert is always a NOP (no operation).
eivindkvedalen
Postby eivindkvedalen » Sat Jan 23, 2016 3:02 pm
wmayer wrote:The assert is triggered in
But then we should have an immediate crash below, because prop is 0. Anyway, the issue is another case where the property is not resolved properly. I think I should be able to fix this during the weekend.
Eivind
eivindkvedalen
Postby eivindkvedalen » Sun Jan 24, 2016 12:18 am
DeepSOIC wrote:Hi!
1. new document.
2. run:
Please try https://github.com/eivindkv/free-cad-co ... ns_fixes_8
Eivind
DeepSOIC
Postby DeepSOIC » Sun Jan 24, 2016 1:15 am
Not surprisingly, Lattice Placement doesn't crash FreeCAD anymore! Thanks Eivind!!
Site Admin
Postby wmayer » Sun Jan 24, 2016 9:43 am
The funny thing is that when I comment out the assert it crashes in Debug build but according to DeepSOIC not in Release mode (I haven't tested it actually). However, in the past I read somewhere that it's allowed to invoke a method also of a null pointer or dangling pointer as long as you don't access any member variables inside this method. But I am not sure if this also applies to virtual methods.
Site Admin
Postby wmayer » Tue Jan 26, 2016 10:56 am
FYI, it crashes for me immediately in Release mode.
Site Admin
Postby wmayer » Tue Jan 26, 2016 11:18 am
